Reading: Calculate the 0%, 50%, and 100% Calibration Points
Inst Tools > Blog > Practical Questions > Calculate the 0%, 50%, and 100% Calibration Points
Calculate the 0%, 50%, and 100% calibration points for the DP transmitter to measure liquid level in this vessel.
Last updated: December 3, 2020 10:49 am
Practical Questions
1 Min Read
Calculate the 0%, 50%, and 100% calibration points for the DP transmitter to measure liquid level in this vessel, given a range of 0 to 30 feet and a process specific gravity of 0.85.
Note the “wet” leg filled with fluid different than the process (SG = 1.1), 35 feet tall:
In this example, the transmitter output loop current range is 10 to 50 mA.
DP transmitter Calibration Points
Calculate the equivalent ΔP range (inch H2O) and loop current (mA) for 0%, 50%, and 100% of process variable.
Answer:
ΔP range (inch H2O)
0% = -462
50% = -309
100% = -156
Loop Current (mA)
0% = 10
50% = 30
100% = 50
Share your answers and explanation with us through the below comments section.
  • Purge Level Transmitter
  • DP transmitter Calibration
  • Hydrostatic Pressure
  • Types of Limit Switches
  • Piping and Fittings
Credits: Tony R. Kuphaldt
Determine the Instrument Calibration Error
Problem on Tachogenerator
Identify Solenoid Valves Energized or de-energized?
Purge Type Level Transmitter Questions
Practical Process Control System Questions & Answers – 6
Resistance Temperature Detector (RTD) Questions – 2
Displacer Level Transmitter Question & Answer
Simple High Level Indicator Circuit
Level Measuring Instruments Velocities of Propagation
Question on Remote Seal with Capillary Tubing Transmitter
Practical Process Control System Questions & Answers – 11
What is the Purpose of Bourdon Tube Gauge Spiral Spring?
Instrument Salesperson Question
Pressure Switch Questions
Identify the Pressure Gauge Error
Calculate the Magnitude of Hydrostatic Pressure
Foxboro model 13 DP transmitter
Re-calibrate the Foxboro DP Pneumatic Transmitter
Dry Leg
Calculate 0%, 50%, and 100% Calibration Points for ΔP transmitter
Programmable Logic Controller (PLC) Questions and Answers – 5
A Question on Steam Drum Water Level Measurement
4-wire pH Transmitter Problem
Applications of Tilting Level Switch
How Tilt Level Switch Works ?
SCADA backup too has been configured
FactoryTalk Studio and SQL Server for Data Logging
Single Bearing Motor Stator Winding
Critical High KiloWatt Motor Winding Burnout Threats
Use Dumps to Ace Certbolt Microsoft AZ-204 Exam
Miniature Circuit Breakers Questions and Answers
PLC Examples for calling functions in SCL
Instrument Calibration Questions
