Reading: Calculate Incident Power in Radar Level Measurement
Inst Tools > Blog > Practical Questions > Calculate Incident Power in Radar Level Measurement
Calculate the percentage of incident power reflected back to the transmitter through the liquid in this radar level measurement application.
Last updated: January 7, 2021 11:00 am
Practical Questions
2 Min Read
Calculate the percentage of incident power reflected back to the transmitter, and the percentage of incident power transmitted (forward) through the liquid in this radar level measurement application:
Radar Level
Also, calculate the ullage for this vessel in both units of meters and units of feet/inches, given a reflected pulse (“echo”) time of 11.176 nanoseconds.
Note: the propagation velocity of radio waves in air is approximately 3 × 108 meters per second, the same as the speed of light in a vacuum.
Partial Answer:
Preflected = 63.45%
Ullage = 1.676 meters
More Questions
1. An effective problem-solving technique to apply to the calculation of ullage is to simplify the problem and solve that simplified problem.
In this case, an easy way to “simplify the problem” is to change the numerical values for echo time and speed of light until the solution for ullage becomes obvious even without using a calculator.
Then the formula we must use to calculate any time/speed/ullage echo problem will be apparent. Apply the “simplify the problem” technique to this ullage calculation.
2. Would you say this is an example of good signal reflection, or poor signal reflection? In general terms, what condition(s) make for strong reflected signals for a radar-based level instrument?
Share your answers and explanation with us through the below comments section.
  • Ultrasonic Level Measurement
  • Purpose of Tank Gauging Level Measurement
  • Guided Wave Radar Questions and Answers
  • Stilling Well in Interface Level
  • Level Instruments Specifications
Credits: Tony R. Kuphaldt
Smart DP Transmitter Flow Meter Calculations
DP Transmitter Problem
Determine the Pressure at Each Port of DP Transmitter
Problem with Sump Tank Level Transmitter
Calculate the Thermocouple Output millivolts
Identify Problem with Oily Water Filter Instrumentation
Calculate the Height of Glycerine
Motor Trip Logic using PLC Programming
DP Transmitter Block and Bleed Valves
How to Decrease Span of Pressure Gauge?
Calculate the Magnitude of Hydrostatic Pressure
Practical Process Control System Questions & Answers – 2
Programmable Logic Controller (PLC) Questions and Answers – 14
Solenoid Valves Questions
Solenoid Valves Questions & Answers – 3
Pitot tube
Pitot Tube Flowmeter Calculations
Problem on Weigh feeder
simple motor start-stop circuit
Liquid Level Switch Control Logic
Process Switches Normal Status
Programmable Logic Controller (PLC) Questions and Answers – 6
surface-mounted water pump
Surface-mounted Water Pump
Two solenoid valves circuit
Solenoid Valves Questions & Answers – 4
Lightning Arrester Basics and Terminology
Caliper Calibration
Concept of Interlocking in PLC
Difference Between Open Circuit and Close Circuit
Tank Gauging Measurement
Effect of Tank Design on Accuracy of Level Measurement
Installation & Commissioning Tips for Wireless HART Devices
Installation & Commissioning Tips for HART Devices
Calculate Temperature of Four Wire RTD
Calculate the Temperature of 4 Wire RTD
Safety Relief Valve
Safety Relief Valve Quiz: Test Your Knowledge
