Reading: Basics of Ball Valves
Inst Tools > Blog > Animation > Basics of Ball Valves
Last updated: March 21, 2019 11:22 pm
Animation Control Valves
A ball valve is a form of quarter-turn valve which uses a hollow, perforated and pivoting ball (called a “floating ball”) to control flow through it. It is open when the ball’s hole is in line with the flow and closed when it is pivoted 90-degrees by the valve handle.
Basics of Ball ValvesRecommended Uses :Advantages :Disadvantages :Applications :
The handle lies flat in alignment with the flow when open, and is perpendicular to it when closed, making for easy visual confirmation of the valve’s status.
Ball valves are durable, performing well after many cycles, and reliable, closing securely even after long periods of disuse. These qualities make them an excellent choice for shutoff applications, where they are often preferred to gates and globe valves, but they lack their fine control in throttling applications.
Ball valves are a quick opening valves that give a tight shutoff. When fully open, a ball valve creates little turbulence or resistance to flow.
The valve stem rotates a ball which contains an opening. The ball opening can be positioned in the fully open or fully closed position but must not be used to throttle flow as any abrasive wear to the ball will cause leakage when the valve is closed.
Ball Valve Principle Animation
Ball valves are considered high recovery valves, having a low pressure drop and relatively high flow capacity.
The ball valve’s ease of operation, repair, and versatility lend it to extensive industrial use, supporting pressures up to 1000 bar and temperatures up to 752°F (500°C), depending on design and materials used.
Sizes typically range from 0.2 to 48 inches (0.5 cm to 121 cm). Valve bodies are made of metal, plastic, or metal with a ceramic; floating balls are often chrome plated for durability.
Best Suited Control: Quick opening, linear
Recommended Uses :
  • Fully open/closed, limited-throttling
  • Higher temperature fluids
Advantages :
  • Low cost
  • High flow capacity
  • High pressure/temperature  capabilities
  • Low leakage and maintenance
  • Tight sealing with low torque
  • Easy quarter turn operation- desirable to most operators
  • Fairly easy to automate.
Disadvantages :
  • Limited throttling characteristics
  • Prone to cavitation
  • Not suitable for slurry applications due to cavities around the ball and seats. Slurries tend to solidify or clog inside the cavities, greatly increasing the operating torque of the valve and in some cases rendering the valve inoperable.
Applications :
  • Ball valves  are  excellent  in  chemical  applications,  including  the  most  challenging services (e.g. dry chlorine, hydrofluoric acid, oxygen).
  • General sizes available are 1/2″ to 12″.
  • Compliant with ASME is the flange rating, either 150, 300, 600, 900# or occasionally higher classes, enabling high performance ball valves to withstand up to 2250 psi.
  • The operating temperature which is primarily dependent on seats and seals may be rated as high as 550°F.
  • Standard valves comply with ASME face-to-face  dimensions,  making the ball valve easy to retrofit and replace.
Articles You May Like :
What is On/off valve ?
JT Valve Principle
Control Valve Facts
Globe Valve Seat
Valve Characteristics
Valve Position Indication
DIN Valve Connectors – Definition, Types
Difference between RTJ and T&G Flange Facings
SIS Emergency Block Valves (EBV)
Advantages and Disadvantages of Valve Actuators
Magnetic Level Gauge Working Principle Animation
Digital Control Valve Working Principle
Control Valve Sequence Methods
Turbine Flow Meters Animation
Working Principle of Flow Switch with Animation
Solenoid Valves Practical Problems
Rotary Stem Valves
Classification of Solenoid Valves
Relay Principle & its Types
Safety Relief Valve Material Selection
3-way solenoid valves control instrument air pressure
Solenoid Valve’s Energized or De-energized State ?
Displacer Level Sensor Working Animation
Network Switch
Solenoid Valve Troubleshooting
Solenoid Valve Troubleshooting Tips
Solenoid Valve Problems and Solutions
What is a Rotary Actuator
Difference Between Linear Actuator and Rotary Actuator
Capacitance Type Level Transmitter Working Principle
Capacitance Level Transmitter Animation
Select Right Type of Controller
How to Select the Right Type of Controller
What is an Oil Separator in HVAC?
Instrumentation Design Details
Locked Open (LO) and Locked Close (LC) Valves
Locked Open (LO) and Locked Closed (LC) Valves
Surface Grinding Process using PLC Program
PLC Program for Valves
PLC Pump Permissive Interlocks
