Reading: Basic Electronics Questions and Answers
Inst Tools > Blog > Electronics MCQ > Basic Electronics Questions and Answers
Check your technical skills with our objective questions and answers on basic electronics subjects with an online practice examination.
Last updated: August 8, 2021 10:30 am
Electronics MCQ
6 Min Read
You can check your technical skills with our objective questions and answers on basic electronics subjects with an online practice examination.
The sample 25 questions are listed below.
Question 1:
Which of the following statement is correct
A) FET and junction transistor both are unipolar
B) The FET is bipolar, while junction transistors are unipolar
C) FET and junction transistor both are bipolar
D) The FET is unipolar, while junction transistors are bipolar
Question 2:
Thermal runaway of a transistor occurs when
A) Transistor joints melt due to high temperature
B) There is excessive leakage current due to temperature rise
C) Heat dissipation from transistor is excessive
D) None of these answers
Question 3:
Which coupling produces the minimum interference with the frequency response
A) Transformer coupling
B) Impedance coupling
C) RC coupling
D) Direct coupling
Question 4:
In an NPN transistor, if the emitter junction is reverse biased and the collector junction is also reversed biased, the transistor will operate in
A) Cut-off region
B) Inverted region
C) Saturation region
D) Active region
Question 5:
In a transistor leakage current mainly depends on
A) Doping of base
B) Temperature
C) Rating of transistor
D) size of the emitter
Question 6:
When a transistor is connected in common emitter mode, it will have
A) Medium input resistance and high output resistance
B) Low input resistance as well as output resistance
C) Negligible input resistance and high output resistance
D) High input resistance and low output resistance
Question 7:
In amplifiers, the parasitic oscillations result due to
A) Push-pull operator
B) Negative feedback
C) Transistor inter-junction capacitance
D) Poor inter-stage coupling
Question 8:
As compared to a CB amplifier, a CE amplifier has
A) Higher input resistance
B) Lower input resistance
C) Lower current amplification
D) Higher current amplification
Question 9:
Which of the following is necessary for transistor action
A) The base region must be very narrow
B) The base region must be made of some insulating material
C) The collector region must be heavily doped
D) The base region must be very wide
Question 10:
The common base configuration is little used because
A) It has very high gain
B) It does not heat up
C) It has high input impedance
D) It has low input impedance
Question 11:
Conventional biasing of a bipolar transistor has
A) EB reversed biased and CB forward biased
B) EB forward biased and CB forward biased
C) EB reversed biased and CB reverse biased
D) EB forward biased and CB reverse biased
Question 12:
A quiescent state of a transistor implies
A) Zero bias
B) No input signal
C) No distortion
D) No output
Question 13:
The circuit consisting of two transistors connected in series with dc supply voltage is called
A) Complementary symmetry
B) Differential pair
C) Stacked V+
D) Push-pull
Question 14:
The emitter region in the NPN transistor is more heavily doped than the base region so that
A) Flow across the base region will be mainly of holes
B) Base current is low
C) Flow across the base region will be mainly of electrons
D) Base current is high
Question 15:
Which class of amplifiers operates with the least distortion
A) Class C
B) Class A
C) Class D
D) Class B
Question 16:
The heat sink disposes off heat mainly by
A) Natural convection
B) Radiation
C) Conduction
D) Forced convection
Question 17:
A bipolar transistor is a _________ controlled device whereas a FET is a _________ controlled device
A) Current-current
B) Voltage-current
C) Voltage-voltage
D) Current-voltage
Question 18:
A Junction Field Effect Transistor can operate in
A) Enhancement mode only
B) Depletion mode only
C) Neither depletion nor enhancement mode
D) Depletion and enhancement modes
Question 19:
Which of the following is the fastest switching device
A) JFET
B) Triode
C) BJT
D) MOSFET
Question 20:
The advantage of the transistor over vacuum tube is
A) Small size and light in weight
B) All of these answers
C) No heat is required
D) Very low power consumption
Question 21:
The Darlington pair consists of the following two stages
A) CE and CC
B) Both CC
C) CE and CB
D) Both CE
Question 22:
When n-channel depletion type MOSFET is used in enhanced mode
A) The gate will be negative
B) The gate will be at ground level
C) None of these answers
D) The gate will be positive
Question 23:
The input and output signals for the CE amplifier are always
A) Complementary to each other
B) Inphase
C) Out of phase
D) Equal
Question 24:
In oscillators, class C operation is preferred because it
A) Gives larger output
B) Is most efficient
C) It produces nearly square waves
D) has frequent stability
Question 25:
A transistor may fail due to
A) Overheating due to circuit failures
B) Any of these answers
C) Open weld at the wire leads to the semiconductor
D) Short circuit caused by momentary overloads
Click on the below button to launch the Quiz. Each question carries 1 mark. You have to score 50% of the marks to pass the test.
All 100 questions and answers are available in the Quiz.
Instrumentation Quiz
Share your suggestions through the comments section.
Next Quiz:
  • Transistor Biasing
  • Methods of Transistor Biasing
  • Transistors Questions & Answers
  • Biasing Techniques of Transistors
  • Comparison of Transistor Configurations
Electronic Devices & Circuits Quiz – Set 12
Electronic Devices & Circuits Quiz – Set 4
Electronic Devices & Circuits Quiz – Set 16
Electrical & Electronics Measurements Objective Questions – Set 2
Electrical & Electronics Measurements Objective Questions – Set 6
Electronic Devices & Circuits Quiz – Set 9
Top 300 Electrical Circuits Objective Questions and Answers
Electronic Devices & Circuits Quiz – Set 14
Electronic Devices & Circuits Quiz – Set 7
Electronic Devices & Circuits Quiz – Set 2
Vacuum Tubes Multiple Choice Questions and Answers
MicroElectronics and Integrated Circuits Objective Questions and Answers
Types of Relays – Questions and Answers
Top 250 Electronic Circuits Objective Questions and Answers
Electrical & Electronics Measurements Objective Questions – Set 5
Electronic Devices & Circuits Quiz – Set 5
Electricity and Magnetism Questions & Answers
Top 300 Electricity and Magnetism Questions & Answers
Circuit Control Devices Multiple Choice Questions
Circuit Control Devices Multiple Choice Questions & Answers
Electrical & Electronics Measurements Objective Questions – Set 4
Circuit Protection Devices Questions
Circuit Protection Devices Objective Questions and Answers
Chemical Sensors Objective Questions
Instrumentation of Ion Spectroscopy
Battery Hazard
Battery Hazards
two chemical streams are mixed together
Practical Process Control System Questions & Answers – 12
Magnetostrictive Level Transmitter Calibration
Magnetostrictive Level Transmitter Calibration Procedure
Best PLC for Your Project
Finding the Best PLC for Your Project – Tips and Tricks
