Reading: Area Velocity Flow Meter Principle
Inst Tools > Blog > Animation > Area Velocity Flow Meter Principle
An Area Velocity Flow Meter continuously measures both Level and Velocity to calculate flow volume in an open channel or pipe.
Last updated: November 2, 2023 10:04 am
Animation Flow Measurement
2 Min Read
Learn how to measure open channel flow without a flume or weir.
Area Velocity Flow MeterSeparate Level and Velocity Sensors
An Area-Velocity Flow Meter continuously measures both Level and Velocity to calculate flow volume in an open channel or pipe.
Open Channel Flow Measurement
The ultrasonic sensor is installed at the bottom of a pipe or channel. To measure water level the sensor transmits ultrasonic pulses that travel through the water and reflect off the liquid surface.
The instrument precisely measures the time it takes for echoes to return to the sensor. Based on the speed of sound in water, the level is measured with an accuracy of ±0.25%.
Flow velocity is measured with an ultrasonic Doppler signal continuously injected into the water. This high-frequency sound (640 KHz) is reflected back to the sensor from particles or bubbles suspended in the liquid.
If the fluid is in motion, the echoes return at an altered frequency proportionate to flow velocity. With this technique, the instrument measures flow velocity with an accuracy of ±2%.
Area-Velocity Flow Meters work in partially full and surcharged pipes, rectangular, trapezoid, and egg-shaped channels.
A separate down-looking ultrasonic sensor can be used for highly aerated or turbulent flow applications (optional).
It measures level by transmitting ultrasonic pulses through the air to the liquid surface with an accuracy of ±0.25%.
Along with the level sensor, a submerged Doppler velocity sensor is used to measure the water velocity.
Level and Flow Measurement Animation
Source: Greyline Instruments
  • Oval Gear Flow Meter
  • Classification of Flow
  • Piston Flow Meters
  • Coriolis flowmeter
  • Optical flow meter
Difference between Different Types of Flow Meters
Radiometric level measurement Working Principle
Square-root characteristics of Differential Pressure Flow Meters
Turbine Flow Meter Installation Procedure
How a Transistor Switch Works
Flow Transmitter Rangeability
Phase Watcher Multiphase Flow Meter (MPFM) Procedure
Capacitance Level Transmitter Animation
Volumetric Flow Calculations
Interview Questions on Flow Measurement
Proximity switches Circuit Diagram Operation
Dall Tube Flow Meter – Principle, Advantages, Disadvantages
Electrical-Switches-Working-Animation
Electrical Switches Working Animation
Orifice Flange Rating
Why Orifice Flow Meter Flange is Not Recommended 150# Rating?
magnetic flow meter parts
What is a Magnetic Flow Meter?
Difference between Orifice & Restriction Orifice
What is a Ultrasonic flow meter
What is a Ultrasonic Flow Meter?
DP type Flow Transmitter Preventive Maintenance
Troubleshooting DP type Transmitter Common Problems
Turbine Flow meter coefficient
Turbine Flow Meter Coefficient and Scaling Factor
ball Valve Animation
Basics of Ball Valves
Coriolis Mass Flow Meter Working Animation
Coriolis Meter Explained with Animation
strain gauge changes as it stretches and shrinks
Why Strain Gauge Resistance Changes as it Stretches and Shrinks?
Pneumatic Relay
Pneumatic Relay Questions
schottky diode working principle
Schottky Diode Working Principle
ROTARY ABUTMENT FLOW METERS WORKING ANIMATION
Rotary Abutment Flow Meters Working Principle and Animation
DC Machines Excitation Quiz
Hydraulic Actuator Principle
What is a Hydraulic Actuator ?
Foundation Fieldbus Signal Conversion Formula
