Reading: Analytical Control System of Heat Exchanger Questions
Inst Tools > Blog > Practical Questions > Analytical Control System of Heat Exchanger Questions
Describe in detail the effect this heat exchanger problem will have on the performance of the analytical control system.
Last updated: March 10, 2021 11:45 am
Practical Questions
3 Min Read
In this process, maple syrup is heated as it passes through a steam heat exchanger, then enters an evaporator where the water boils off.
The purpose of this is to raise the sugar concentration of the syrup, making it suitable for use as a food topping.
A level control system (LT, LIC, and LV) maintains constant syrup level inside the evaporator, while an analytical control system (AT, AIR, AC, and AV) monitors the sugar concentration of the syrup and adjusts steam flow to the heat exchanger accordingly.
Suppose the steam tubes inside the heat exchanger become coated with residue from the raw maple syrup, making it more difficult for heat to transfer from the steam to the syrup. This makes the heat exchanger less efficient, which will undoubtedly affect the process.
More Questions :
  1. Suppose the operations personnel of this maple syrup processing facility wished to have an automatic method for detecting heat exchanger fouling. What variable(s) could be measured in this process to indicate a fouled heat exchanger?
  2. What economic effect will this fouling have on the process? In other words, does the process become more or less profitable as a result of the heat exchanger fouling?
Answer:
The analytical control system should still be able to maintain sugar concentration at setpoint, unless the heat exchanger fouling is so extreme that even a wide-open steam valve does not heat the incoming syrup enough to sufficiently concentrate it.
Follow-up question: suppose the heat exchanger fouling really is this bad, but we cannot fix the heat exchanger with the tools we have available. What would you recommend the operator do to make this system produce on-spec syrup?
Share Your Answers via Comments
  • Questions on Piping and Instrumentation Diagrams
  • Inspecting the Trends of PV and SP
  • Analytical Measurement Multiple Choice Questions
  • Analytical Standards
Credits: Tony R. Kuphaldt
PLC Practice Questions
Programmable Logic Controller (PLC) Questions and Answers – 8
Solenoid Valves Questions & Answers – 1
Pitot Tube Flowmeter Calculations
A Question on Steam Drum Water Level Measurement
Programmable Logic Controller (PLC) Questions and Answers – 11
  • saleem ahmad says:
    March 11, 2021 at 12:56 pm
    By reducing flow rate of Maple syrup, required heat exchange can be achieved alternatively by reprocessing the concentrated syrup quality can be maintained. In either way the capacity of the plant will be reduced which will reduce the plant profatibility.
Programmable Logic Controller (PLC) Questions and Answers – 12
Calculate the Magnitude of Hydrostatic Pressure
Example PLC Program
Calculate Temperature of RTD
How much Pressure will Remote Seal Pressure Transmitter Indicate?
Calculate Total Hydrostatic Pressure at Bottom of Vessel
Determine LRV and URV settings for the Level Transmitter
How to Connect Proximity Switch (Sink Type) to Make LED ON ?
PLC Programming Questions
PLC Programming Question & Answer
Practical Control Systems Questions & Answers - 2
Practical Process Control System Questions & Answers – 2
surface-mounted water pump
Surface-mounted Water Pump
Steam Eductor Question
A Series of False Pressure Alarms
pressure transmitter calibration setup
Why Pressure Vessel Connected to Tubing System?
Two pressure switches
Identify Two Pressure Switches Logic
LRV and URV of PT for Extreme Limits of Empty and Full
Calculation of Hydrostatic Pressure
Remote User Authentication
Security of Industrial Automation Systems
Advantages of Pneumatic Systems in the Automotive Industry
Annubar Flow Meter Principle
Annubar Flow Meter – Principle, Advantages, Disadvantages
Troubleshooting a Biased Transistor
Standard Maintenance Procedure
Standard Maintenance Procedure (SMP)
Measurements & Instrumentation Quiz – Set 8
