Reading: Abbreviations of Pressure, Temperature & Flow
Inst Tools > Blog > Guest Articles > Abbreviations of Pressure, Temperature & Flow
Last updated: September 8, 2017 10:02 am
Guest Articles
2 Min Read
PRESSURE:
P : PRESSURE
PI : PRESSURE INDICATOR
PG : PRESSURE GAUGE
PCV : PRESSURE CONTROL VALVE
PT : PRESSURE TRANSMITTER
PIT : PRESSURE INDICATING TRANSMITTER
PIC : PRESSURE INDICATING CONTROLLER
PDT : PRESSURE DIFFERENTIAL TRANSMITTER
PRV : PRESSURE REDUCING VALVE
PSV : PRESSURE SAFETY VALVE
PS : PRESSURE SWITCH
PSH : PRESSURE SWITCH HIGH
PSL : PRESSURE SWITCH LOW
PSHH : PRESSURE SWITCH HIGH HIGH
PSLL : PRESSURE SWITCH LOW LOW
PDS : PRESSURE DIFFERENTIAL SWITCH
PDSH : PRESSURE DIFFERENTIAL SWITCH HIGH
PDSL : PRESSURE DIFFERENTIAL SWITCH LOW
PA : PRESSURE ALARM
TEMPERATURE:
T : TEMPERATURE
TI : TEMPERATURE INDICATOR
TW : THERMOWELL
TM : THERMOMETER
TE : TEMPERATURE ELEMENT
RTD : RESISTANCE TEMPERATURE DETECTOR
T/C : THERMOCOUPLE
TT : TEMPERATURE TRANSMITTER
TIC : TEMPERATURE INDICATING CONTROLLER
TRC : TEMPERATURE RECORDER CONTROLLER
TCV : TEMPERATURE CONTROL VALVE
TS : TEMPERATURE SWITCH
TSH : TEMPERATURE SWITCH HIGH
TSL : TEMPERATURE SWITCH LOW
TA : TEMPERATURE ALARM FLOW
FLOW
F : FLOW
FI : FLOW INDICATOR
FG : FLOW GLASS / FLOW GAUGE
FE : FLOW ELEMENT
FIT : FLOW INDICATING TRANSMITTER
FCV : FLOW CONTROL VALVE
FIC : FLOW INDICATING CONTROLLER
FS : FLOW SWITCH
FY : FLOW CONVERTER
FA : FLOW ALARM
FR : FLOW RECORDER
FRC : FLOW RECORDING CONTROLLER
LEVEL:
L : LEVEL
LI : LEVEL INDICATOR
LG : LEVEL GAUGE
LIT : LEVEL INDICATING TRANSMITTER
LCV : LEVEL CONTROL VALVE
LDT : LEVEL DISPLACER TRANSMITTER
LIC : LEVEL INDICATING CONTROLLER
LRC : LEVEL RECORDING CONTROLLER
LS : LEVEL SWITCH
LSH : LEVEL SWITCH HIGH
LSL : LEVEL SWITCH LOW
LA : LEVEL ALARM
RLT : RADAR LEVEL TRANSMITTER.
Article Shared by:
Mr.Basavaraj Ambarage
Why You Need FDA Process Validation and How to Do It Right ?
Digital Control Valve (DCV) Calibration Procedure
Redundant Power Supply for Critical Field Panels
Displacer Level Transmitter Dry Calibration with Weights
Capacitance Level Switch Calibration
Reversing Control Valve Actuator Fail Safe Mode
Using of MCT instead of Cable Glands on the Cabinets
Conductivity Transmitter Calibration Procedure
Control Valve Cavitation and Flashing
Circular Chart Recorder Calibration Procedure
Oracle Database 12c Administrator Certified Associate Certification
Internal Powered Modems
PLC Documents
PLC System Documentation
PLC Program for an Alternate output circuit
Automatic Lamp Control in Storage Facility
PLC Program for Car Parking
PLC Program for Entry and Exit Control of Car Parking
PLC Program for Alarm Indication in Process
Nuclear Level Measurement
Nuclear Level Detectors Cascade or Master/Slave concept
PLC Program for Conditional Control Logic
Analyzer Sampling System
Gas Analyzer Sampling System
Coriolis Mass Flow meter as a Multi Variable Transmitter - 1
Coriolis Mass Flow Meter as a Multi-Variable Transmitter
Identify Instruments in Piping and instrumentation Diagram
Control Valves Pre-Commissioning Checklist
Control Valve Cv Formula
Control Valve Cv calculation
Programmable Logic Controllers Multiple Choice Questions
Pressure and Temperature Compensation for Flow Transmitter
Steam Tracing
Steam Tracing
Characteristics of Level Measurement Technologies
Identify Characteristics of Level Measurement Technologies
