Reading: X-Ray Absorption Meter Questions and Answers
Inst Tools > Blog > Multiple Choice Questions > X-Ray Absorption Meter Questions and Answers
1. Absorption meter is __________ and ____________ of the chemical state of the element concerned.
a) Non-destructive, independent
b) Destructive, independent
c) Non-destructive, dependent
d) Destructive, dependent
Answer: a
Explanation: Absorption meters give information about the absorbing material. It is non-destructive and independent of the chemical state of the element concerned.
2. X-ray absorption meters have which of the following major disadvantages?
a) Low accuracy
b) Low range
c) Low sensitivity
d) It is destructive
Answer: c
Explanation: Absorption meters give information about the absorbing material. X-ray absorption meters have low sensitivity.
3. The applications of X-ray absorption meters are limited when compared with X-ray emission procedures.
a) True
b) False
Answer: a
Explanation: The applications of X-ray absorption meters are limited when compared with X-ray emission procedures. They are also limited when compared with fluorescence procedures.
4. In absorption meter, which of the following is placed between the cell and the X-ray tube?
a) Collimator
b) Filter
c) Chopper
d) Attenuator
Answer: c
Explanation: In Absorption meter, chopper is placed between the cell and the X-ray tube. It interrupts the half of the X-ray beam.
5. In absorption meter, which of the following is placed between the chopper and the reference cell?
a) Collimator
b) Filter
c) Photomultiplier tube
d) Attenuator
Answer: d
Explanation: In absorption meter, attenuator is placed between the chopper and the reference cell. A variable thickness aluminium attenuator is used.
6. In absorption meter, the two halves of the X-ray beam are allowed to fall on which of the following components?
a) Collimator
b) Filter
d) Attenuator
Answer: c
Explanation: In absorption meter, the two halves of the X-ray beam are allowed to fall on the photomultiplier tube. One beam passes through the sample and the other beam passes through the reference.
7. The photomultiplier tube used is absorption meter is coated with which of the following materials?
a) Sodium
b) Potassium
c) Phosphorous
d) Chlorine
Answer: c
Explanation: The photomultiplier tube used is absorption meter is coated with phosphorous. Only one photomultiplier tube is commonly present for both the beams.
8. In absorption meter, which of the following is adjusted until the absorption of two X-ray beams are brought into balance?
a) Collimator
b) Filter
d) Attenuator
Answer: d
Explanation: In absorption meter, the attenuator is adjusted until the absorption of two X-ray beams are brought into balance. A variable thickness aluminium attenuator is used.
9. In absorption meter, the change in thickness of aluminium required for different samples is a function of the difference in which of the following parameters?
a) Amount
b) Concentration
c) Colour
d) Composition
Answer: d
Explanation: In absorption meter, the change in thickness of aluminium required for different samples is a function of the difference in composition. A variable thickness attenuator used allows this function.
10. Absorption meters cannot be used to detect broken bones.
a) True
b) False
Answer: b
Explanation: Absorption meters can be used to detect broken bones. It can also be used to locate trace elements.
Level and Density Measurement Objective Questions
Preliminary Considerations of Classical Design
Pole Placement by State Feedback
Stability of Nonlinear System
Feedback and Non-feedback Systems Objective Questions
Root Locus in Control Systems
Atomic Absorption Spectroscopy Questions & Answers
Combination Electrode Questions & Answers
The Infinite Time Regulator Problem
Top 100 Power Plant Engineering Objective Questions & Answers
Nuclear Power Plant Multiple Choice Questions
Neural Networks
Experimentation of Transfer Function
Stability in Frequency Domain
Realization of Basic Compensators
Solution of State Equations
Construction of Root Loci
Liapunov’s Stability Analysis
Liapunov’s Stability Criterion – Part II
pH Meters Questions & Answers
Signal Flow Graphs Objective Questions
Digital Control Systems
Spectrum Analysis of Sampling Process
Instrumentation for Electron Spectroscopy
Free Electronics Projects & Ideas
300+ Free Electronics Projects & Ideas
Paddle Wheel Flow Meter
Paddle Wheel Flow Meters – Principle, Advantages, Limitations
Modbus ASCII and RTU Message Frame
Background of Modbus – ASCII and RTU Data Frames
Ladder Logic Programming Examples
Needle Valve Schematic
How Needle Valve Works ?
Closed-Tank-DP-Type-Level-Measurement-with-wet-leg-and-transmitter-installed-below-tapping-point
Level Measurement with Wet leg and Installed Below Tapping Point
Distributed Control System Architecture for Foundation Fieldbus Field Instruments
What is Foundation Fieldbus (FF) ?
Electric Solenoid Actuators Principle
What is a Electric Solenoid Actuator ?
