Reading: What is ON/OFF Valve ?
Inst Tools > Blog > Animation > What is ON/OFF Valve ?
Last updated: March 21, 2019 4:35 pm
Animation Control Valves eBooks
2 Comments
2 Min Read
An ON/OFF Valve is the fluid equivalent of an electrical switch, a device that either allows unimpeded flow or acts to prevent flow altogether.
What is ON/OFF Valve ?Animation :
These valves are often used for routing process fluid to different locations, starting and stopping batch processes, and engaging automated safety (shutdown) functions.
Valve styles commonly used for on/off service include ball, plug, butterfly (or disk), gate, and globe.
Large on/off valves are generally of such a design that the full-open position provides a nearly unimpeded path for fluid to travel through. Ball, plug, and gate valves provide just this characteristic:
Ball Valve and Butterfly Valve
A plug valve is very much like a ball valve, the difference being the shape of the rotating element. Rather than a spherical ball, the plug valve uses a truncated cone as the rotary element, a slot cut through the cone serving as the passageway for fluid.
The conical shape of a plug valve’s rotating element allows it to wedge tightly into the “closed” (shut) position for exceptional sealing.
A series of photographs showing a cut-away ball valve (hand-actuated) in three different positions reveals the inner workings common to all ball valve mechanisms:
The left-hand image shows the valve in the shut position, with the bore axis facing the viewer (preventing fluid flow).
The right-hand image shows the valve in the open position, with the bore axis perpendicular to view and allowing flow. The middle image shows the valve in a partially-open condition.
Animation :
ON/OFF Valve Animation
Articles You May Like :
Hydraulic Actuators
Valve flow coefficient
Emergency shutdown valve
Control Valves Interview
Valve Technician Questions
What is Complementary Split Range Control (CSRC)?
What is Parallel Thread Pipe Fittings ?
Magnetic Float Level Switch Working Animation
Basic Requirements of Control Valves Sizing
Types of Check Valves
Thermostatic Valves Working Principle
2 Comments
  • radu says:
    November 7, 2019 at 9:23 am
    How we can see the position of valve without the positionner?
  • Tiago Gustavo Marques says:
    January 4, 2023 at 11:59 am
    It is either fully open or fully closed. The open and closed positioned are checked by limit switch, one for the open and one for the closed.
    If during the operation, the valve stuck in between, none of the limit switch will be activated, and control system will interpret as discrepancy( not open and close after a predetermined time)
Working Principle of Pneumatic Actuators
Deluge System for Transformer Protection Animation
Basics of Butterfly Valves
How Diaphragm Valves Work ?
Types of Control Valves Noise
What is an Air Valve? Purpose, Types, Advantages, Disadvantages
Air Cylinder Consumption Calculation for Control Valves
PID Controller Action : Directing Acting & Reverse Acting
Cable Tray Routing
Cable Routing
Capacitance Type Level Transmitter Working Principle
Capacitance Level Transmitter Animation
Tilting Disk Check Valve Principle
What is Tilting Disk Check Valve ?
Ball Valve Pictures
How Ball Valves Work ?
What is an Actuator - Different Types of Actuators
What is an Actuator? – Different Types of Actuators
Malfunctioning Inlet Check Valves
Summary of Valve Types Characteristics
Control Valve Parts
Basic Parts of Control Valves
Solenoid Valve Terminology
How a Solenoid valve works
Liapunov’s Stability Analysis
Liapunov’s Stability Criterion – Part II
Bubbler level measurement
what is a Bubbler System?
Advantages and Applications of zigzag transformer
Alternative Vessel Level Indication
What is the Simple Alternative Vessel Level Indication?
Paddle Type Level Switch
What is a Level Switch? Types of Level Switches
Differential Pressure Gauge Principle
Password Protect Apps and Files
