Reading: What is Fuzzy Logic? Advantages, Disadvantages, Applications
Inst Tools > Blog > Common > What is Fuzzy Logic? Advantages, Disadvantages, Applications
Fuzzy logic is a typical type of logic through which for any variable there are multiple possible truth values that can be processed.
Last updated: February 8, 2023 12:02 pm
Common
Fuzzy logic is a typical type of logic through which for any variable there are multiple possible truth values that can be processed. Many logical systems work by processing inputs and outputs in terms of true and false. But in the case of fuzzy logic, the degree of the truthiness of the variable is taken into consideration. The word Fuzzy itself means unclear.
The Architecture of Fuzzy LogicAdvantages of Fuzzy LogicDisadvantages of Fuzzy LogicApplications of Fuzzy Logic
Boolean logic which is mainly used in computers uses 0 as a false condition and 1 as a true condition. But in the case of Fuzzy Logic, many intermediate values between 0 and 1 are possible. The values used for fuzzy logic between 0 and 1 determine the amount of trueness of a given variable. Hence, in Fuzzy Logic, values such as 0.1, 0.5, and 0.9 are possible.
Fuzzy Logic has 4 main components. They are Rule Base, Fuzzification, Interference Engine, and Defuzzifier.
What is Fuzzy Logic
Let us have a look into all these 4 components.
  • Rule Base
Rule base as the name suggests contains the rules. The basics of this rule base are IF-THEN.
The conditions are taken into consideration and the rule of IF is applied. If the condition meets the requirements of the given logical statement, then the rule is applied.
  • Fuzzification
In fuzzification, the inputs from various input devices like sensors are converted into fuzzy sets. The inputs from the input devices are also termed crisp inputs.
  • Interference Engine
The interference engine is the main brain of fuzzy logic. The interference engine decides what to do or what output to produce for a given fuzzy set/crisp input.
Here, Rule Base is used by the system to determine the output. The output of the interference engine is also in terms of fuzzy sets/crisp.
  • Defuzzification
The fuzzy sets given by the interference engine as output is an inputs for the defuzzifier.
The defuzzifier produces the output of the Fuzzy Logic System. Here also, the rule base is used as a reference to produce the outputs.
  1. Fuzzy logic relies on logical sets and reasoning which can be easily understood by any user.
  2. Fuzzy logic is easy to understand and hence fuzzy logic is user-friendly.
  3. Many complex problems cannot be solved by other systems which are easily solved by fuzzy logic.
  4. Fuzzy logic can give accurate outputs with imprecise data or inaccurate.
  5. Fuzzy logic is widely used for commercial and practical purposes.
  1. Sometimes fuzzy logic implementation becomes difficult because no systematic approach to solving through fuzzy logic is possible.
  2. Setting up fuzzy logic itself is sometimes very difficult
  1. In washing machines, fuzzy logic is widely used for automation.
  2. Fuzzy logic is used in computer-aided diagnostic systems.
  3. Fuzzy logic is used in gear selection in automobiles based on some factors like road conditions, engine load, and the style of driving.
  4. Fuzzy logic is used in aerospace to manage the altitude of satellites and spacecraft.
  5. In process industries, fuzzy logic is mostly used for the control of pH and conductivity.
  6. The neural network uses fuzzy logic to make decisions faster.
  • Motor Feedback PLC Logic
  • Steps in PLC System Design
  • SCADA System Vulnerabilities
  • Boiler Feed Water Treatment
  • Feedback Control System
Difference Between Adhesion and Cohesion
What is a Load Cell ?
Difference between Standards, Codes, Specifications, Regulations
Next-Generation Security Surveillance Systems – AI Technology
Metric Prefixes and Unit Conversions
What is an Automotive Radiator?
Difference Between Skin Effect and Proximity Effect
Difference between LVDT and RVDT?
Use of Isolator in Microwaves
Types of Sensors used in the Dairy Industry
What is Chemical Vapor Deposition? – The Ultimate Guide
Urea Bagging Plant – Process Flow
Capping Machine – 5 Aspects of Control Systems and Automation
Best Engineering Mobile Apps
Best Engineering Mobile Apps on Google Play & App Store
Mechanical Torsion Meter Principle
Sensors Used in Automotive Vehicles
Different Types of Sensors used in Automotive Vehicles
Ceramic Bearings
Everything You Need to Know About Ceramic Bearings
Good and Bad Wiring Practices
Advantages and Disadvantages of Pneumatic Instruments
Swiss Screw Machining
Things You Should Know About Swiss Screw Machining
Oil Burners
What are Oil Burners? Types, Advantages, Applications
Digital Image Processing Projects - DIP Project Ideas
600+ Digital Image Processing Projects – DIP Project Ideas
Basics of Butterfly Valves
Range Finders
Range Finders – Ultrasonic, Light, & Global Positioning Systems
basic-electronics-questions-answers
Basic Electronics Questions & Answers
Electron Spin Resonance Questions & Answers
Instrumentation of ESR Spectrometer
Automatic Transfer Switch
Automatic Transfer Switch (ATS) Using Classic Control Circuit
Major issues for Sensors Selection
