Reading: What is Directional Control Valve (DCV)?
Inst Tools > Blog > Control Valves > What is Directional Control Valve (DCV)?
As the name indicates, the directional control valve (DCV) is used to control the direction of fluids. Fluids are liquids or gases.
Last updated: September 28, 2022 2:34 pm
R Jagan Mohan Rao
Control Valves
As the name indicates, the directional control valve is used to control the direction of fluids. Fluids are liquids or gases.
Classification of Directional Control ValvesBased on the Type of ConstructionBased on Number of PortsBased on a number of switching positions:Based on Actuating MechanismVarious Types of Directional Control Valves DCV and Fluid Pressure Control ValvesPressure Relief valveSequence ValveCounterbalance valve
Directional control valves are extensively used in industries for the passage of fluid in the system. It is difficult to adjust manually every control valve at the right time.
It controls the fluid flow in a hydraulic or pneumatic system by changing the position of its internal components. It permits or restricts fluid flow to the actuator by opening and closing its ports.
There is a difference between the directional control valve used for liquids and gases. The liquids exert high pressure, so the directional control valve is heavier and strong in construction, while DCV used for gases is generally aluminum.
The below are the types of directional control valves as follows.
  1. Based on the type of construction.
  2. Based on the number of ports.
  3. Based on the number of switching positions.
  4. Based on actuating mechanism.
The most basic configuration of the directional control valve is a spool inside a cylinder where the movement of the spool allows and stops the flow of the fluids through it.
Other types include a ball, spool (sliding spool or rotating spool), or poppet.
Directional Control Valve Construction
Two-way, three-way, four-way valves. Denoted in capital letters P (pump port), T (Tank port), A, B (supply ports), or numerals 1, 2, 3, 4 are shown on the boxes that indicate connections.
The square box represents position. The symbol of the directional control valve is made of a number of square boxes which are adjacent to each other depending on the number of positions. One, two, or three positions.
The directional control valves are actuated by a variety of methods includes manual, mechanical, electrical, pneumatic, and hydraulic and as shown in the table below.
When the actuator has pressed the spool inside the directional control valve changes its position and controls the fluid flow.
Types of Valve Actuation
2/2 way valves are for ON/OFF function for fluid supply. It can be normally open or closed.
3/2 way valves are generally used to control single-acting actuators. It can be normally open or closed.
4/2, 4/3, 5/2, 5/3 way valves are normally used for double-acting actuators.
Example:
 Find below a hydraulic circuit that describes how a directional control valve works. In a 4/2 directional control valve, 4 ports, 2 positions.
When the lever is pressed, the directional control valve changes its position and controls the fluid flow.
Directional Control Valve Basics
Directional control valves provide a flow path to the cylinder actuation and also a return path to the tank.
Fluid pressure is controlled to perform different functions like pressure relief, sequence valve, and counterbalance valve as discussed below.
Pressure relief valve is used to limit the pressure in the whole system called pressure relief valve, also Safety valve. It prevents system pressure from building up and causing damage to equipment or serious hazards.
Pressure relief valves are two types, direct operated and pilot operated. Pressure relief valves are normally closed-type valves.
The pressure relief valve is located between the pump and the direction control valve.
Sequence Valve
A sequence valve is used to ensure that a certain pressure level is attained in one branch line with the first consumer of the circuit.
Later supplied to the second consumer in a sequence manner.
Counterbalance valve is used to avoid the uncontrolled speedy movement of the cylinder. It resists rapid changeover.
A counterbalance valve is used in earth-moving equipment. It holds the load for some time like lifting the trolley of the tractor or the trucks.
Reference: Hydraulic and Pneumatics A technician’s and Engineer’s guide by Andrew Parr.
  • How to Install a Control Valve?
  • How to Select Directional Valves
  • Solenoid Valve Manual Reset
  • 5 Port 2 Position Valve Working Principle
  • Flow Control Valves Interview Questions
Valves MCQ
Butterfly Valves – Concentric, Double-offset, and Triple-offset
How Gate Valves Work ?
Valve Technician Interview Questions
Direct Acting Control Valves & Reverse Acting Control Valves
Safety Relief Valve Material Selection
  • Gustavo Delgado says:
    May 21, 2021 at 6:59 pm
    I’ve never seen one position valve, Do you have any example?
How to Reduce the Control Valve Noise?
Solenoid Valves Terminology
Emergency Shutdown Valve : Advantages
Solenoid Valve Troubleshooting Tips
Difference between PCV and PRV
What is Control Valve Flashing ?
Control Valve Cv calculation
Difference Between the Control Valve and Shut-off Valve
valve actuator yoke
Advantages and Disadvantages of Valve Actuators
Latest Control Valves Interview Questions
Control Valve Interview Questions and Answers
4 way Solenoid Valve Principle
What is a 4-way Solenoid Valve?
Direct operated (direct acting) solenoid valves
Solenoid Valves Types & Functions
Dome Valve Principle
Dome Valve Working Principle
Thermostatic valves Principle
Thermostatic Valves Working Principle
pneumatic piston actuator
Working Principle of Pneumatic Actuators
Diaphragm
Diaphragms
ultrasonic-level-measurement
Ultrasonic Level Transmitter Working Principle
Peak Inverse Voltage of Center Tap Rectifier
Advantages & Disadvantages of Different Vibration Sensors
Arduino Zero
What is Arduino? Different Models of Arduino Controllers
4-20mA to Process Variable conversion
Formula to Calculate Process Variable from 4-20mA
limit-switch-works
How Limit Switch Works ?
