Reading: What is a GSD File and Why it is required?
Inst Tools > Blog > PLC Tutorials > What is a GSD File and Why it is required?
The abbreviation of GSD file is General Station Description. These are like data sheets for particular field device written in ASCII format.
Last updated: May 7, 2021 1:23 pm
2 Comments
3 Min Read
In automation industry, there are various communication protocols are used to connect field devices to controller.
GSD File ExtensionsHow to Import GSD files into TIA portal?Naming Structure of GSD files
Some of communication protocols are Ethernet, Profibus, Profihub, Modbus, DevicesNet.
Also Read: Industrial Automation Protocols
While connecting device through profibus / Profinet GSD/GSDML files comes into picture. Each device has its unique GSD file.
To setup a device in controller, it is important to know properties of a device.
When you integrate GSD files in controller, controller gets the device parameters and characteristics. It enables you to configure devices as per requirement.
GSD  is abbreviation of German term “Gerätestammdaten.”  It is also known as General Station Description.
GSD files are kind of data sheets for particular device. They are written in ASCII text format. It contains internal data structure of device such as
1. Vendor Name GSDML number.
2. Model Name
3. Version Number
3. Baud Rate
4. DP features
5. IO related information
6. Diagnostics Data
GSD File Extensions
GSD files are generally published by manufacture on their Official website. You can find them on internet or in form of CD’s along with your field device.
When you search on internet for specific GSD file you may come across various extensions of file. (gs*). The GSD files have language specific instructions.
The last letter specifies the language in which file is written.
GSD – Default format
GSE -English
GSS – Spanish
GSP – Portuguese
GSF – French
GSI – Italian
When device is connected on ProfiNet, GSDML files are used.
GSDML files are nothing but GSD files written in XML format (.XML extension).
1.  Open TIA portal
2. Go to Options
3. Go to Manage general service description files (GSD)
4. Click on Installed GSDs
5. Give the Source Path of GSD file
6. Select file
7. Click on Install
Image Courtesy: Siemens
Consider a GSD file with name “abcd1010.gsd”
Here, abcd is Vendor Name
1010 is Unique hexadecimal number (Always 4 digits)
This number is provided by PI (PROFIBUS & PROFINET International) on registering device.
.gsd is language version. (D by default)
Remember to select latest version of GSD files for your device!!
Author: Priyanka R. Lunge
  • ProfiBus Questions and Answers
  • Types of System Architecture
  • FF Device Configuration
  • Field Transmitter Communication
  • Mitsubishi PLC Online Training
Allen Bradley PLC Interview Questions and Answers
PLC Techniques for I/O Mapping
Advanced PLC Programming for Defective Parts Sorting
Create a Function (FC) for a Valve Logic in Siemens PLC
Top 100 PLC Objective Questions and Answers
2 Comments
  • Shrutika Giradkar says:
    May 7, 2021 at 10:49 am
    Loved the article. Easily explained and interesting. Looking forward for more such articles.
  • Anant says:
    May 7, 2021 at 10:59 am
    You’re an fantastic author ma’am.
Comparison of Control Loops – Open, Closed, Cascade, Feedforward, Ratio
PLC Ladder Logic Example
PLC Programming Example for Motor Forward and Reverse Control
Electrical Earthing Calculations
How to Retrieve PLC Project From Memory Card?
#20 PLC Best Practices – Identify Critical Alerts
What is the DDE Protocol?
Omron PLC washing machine automation
Omron PLC Logic for Washing Machine Automation
PLC Control for Baking Machines Logic
PLC Programming for Baking with Auto and Manual Modes
PLC Timer Program
PLC Timer Instructions
PLC program for bread oven
Bread Oven Control in Auto and Manual Modes PLC Program
Learn PLC in Hindi
Learn PLC in Hindi
PLC Sequential Operation Example Program
Forward reverse motor control diagram with timer
Timer during Motor Direction Change PLC Program
Siemens OB Blocks
Siemens PLC Organization Blocks (OB)
Most Frequently Asked Instrumentation Questions
General Instrumentation Questions
Innovative Segment Orifice
Pitot-tube Replaced with Innovative Segment Orifice Plate
Dahlander Motor Control Circuit
Dahlander Motor Control Circuit and Power Circuit
Advantages of Bundled Conductors in Transmission Lines
thermal imaging instrument
Thermal Imaging Temperature Measurement
Top 100 Robotic Projects for Engineering Students
How to Test a Pressure Switch ?
Temperature Balance System Objective Questions
