Reading: What is Gate Valve ?
Inst Tools > Blog > Control Valves > What is Gate Valve ?
Last updated: March 21, 2019 3:52 pm
Control Valves
2 Min Read
A gate valve is a linear motion valve used to start or stop fluid flow; however, it does not regulate or throttle flow.
The name gate is derived from the appearance of the disk in the flow stream.
The disk of a gate valve is completely removed from the flow stream when the valve is fully open. This characteristic offers virtually no resistance to flow when the valve is open. Hence, there is little pressure drop across an open gate valve.
When the valve is fully closed, a disk-to-seal ring contact surface exists for 360°, and good sealing is provided. With the proper mating of a disk to the seal ring, very little or no leakage occurs across the disk when the gate valve is closed.
What is Gate Valve ? | Gate Valve Parts
Figure : Gate Valve
On opening the gate valve, the flow path is enlarged in a highly non-linear manner with respect to percent of opening. This means that flow rate does not change evenly with stem travel.
Also, a partially open gate disk tends to vibrate from the fluid flow. Most of the flow change occurs near shutoff with a relatively high fluid velocity causing disk and seat wear and eventual leakage if used to regulate flow.
For these reasons, gate valves are not used to regulate or throttle flow.
A gate valve can be used for a wide variety of fluids and provides a tight seal when closed.
Disadvantages of Gate Valve
The major disadvantages to the use of a gate valve are:
  • It is not suitable for throttling applications.
  • It is prone to vibration in the partially open state.
  • It is more subject to seat and disk wear than a globe valve.
  • Repairs, such as lapping and grinding, are generally more difficult to accomplish.
Articles You May Like :
Metal Seated Valves
Electric Motor Actuator
Valve Erosion Problems
Gas Valve Sizing
Disk Valves
Emergency Shutdown Valve : Advantages
Globe Valve Body Design
Shaft and Coupling Bore Tapers Repair Caused Frequent Shutdowns
Control Valves Pre-Commissioning Checklist
Control Valve Preventive Maintenance
Control Valve Performance with Constant Pressure
Globe Valve Seat and Disk
Control Valve Sequence Methods
What is an Air Valve? Purpose, Types, Advantages, Disadvantages
Types of Check Valves
What is Shutdown Valve?
Face to Face Dimension of Control Valve
Trip Valve Principle
Selecting the Proper Failure Mode
How to Select Control Valve Failure Mode
actuated-valve-schematic
Components of Shutdown Valve
Control Valve Testing for Noise Measurement
Direct & reverse actions control valve
Direct Acting Control Valves & Reverse Acting Control Valves
Triple-offset Butterfly Valves
Butterfly Valves – Concentric, Double-offset, and Triple-offset
Control Valve with Positioner
 Control Valve Accessories – Principle, Purpose, Advantages
Control valve characteristics
Valve Characteristics – Quick Opening, Linear & Equal Percentage
Classification of valves
Introduction to Types of Valves
Power Electronics Projects
Top 100 Power Electronics Projects for Engineering Students
Simple PLC example Hardware configurations
Schneider PLC Programming Example
Schneider PLC Programming Example for Beginners
Hydrostatic Level Measurement
Car Lifts
Car Lifts – Choosing the Right One for Your Mechanic Shop
What are Switchgear Interlocks?
Electrical Switch Questions and Answers
Top 50 Electrical Switch Questions and Answers
Generated EMF Quiz
