Reading: What is a Filter Circuit ?
Inst Tools > Blog > Electronic Devices & Circuits > What is a Filter Circuit ?
Last updated: September 27, 2016 3:56 pm
2 Min Read
Generally, a rectifier is required to produce pure d.c. supply for using at various places in the electronic circuits. However, the output of a rectifier has pulsating character i.e. it contains a.c. and d.c. components. The a.c. component is undesirable and must be kept away from the load.  To do so, a filter circuit is used which removes (or filters out) the a.c. component and allows only the d.c. component to reach the load.
A filter circuit is a device which removes the a.c. component of rectifier output but allows the d.c. component to reach the load.
Obviously, a filter circuit should be installed between the rectifier and the load as shown in Fig. A filter circuit is generally a combination of inductors (L) and capacitors (C). The filtering action of L and C depends upon the basic electrical principles.  A capacitor passes a.c. readily but does not pass d.c. at all.
On the other hand, an inductor opposes a.c. but allows d.c. to pass through it.  It then becomes clear that suitable network of L and C can effectively remove the a.c. component, allowing the d.c. component to reach the load.
Types of Filter Circuits
The most commonly used filter circuits are
  1. capacitor filter,
  2. choke input filter and
  3. capacitor input filter or π-filter.
CRT Fluorescent Screen
Transistor Biasing
Summary Of Transistor Bias Circuits
Optoisolator Working Principle
Time Base Generator
pi filter Operation
Different Types of Diodes
Bipolar Junction Transistor Construction
Zener Diode Voltage Regulator Operation
Current Divider Rule
Phototransistor Working Principle
Photodiode as Variable Resistance Device
Operation of Zener Diode Voltage Regulator
Power MOSFET Safe Operating Area
p-type-semiconductor
N Type and P Type Semiconductors
Testing a defective transistor
Testing a Transistor with a Digital Multimeter
Combining Independent Current Sources in Parallel
example-of-KCL
What is Kirchhoff’s Current Law
Voltage Divider Rule
Reverse Voltage Characteristics of Photo diode
Diode-testing-with-multimeter
How to Test a Diode using Multimeter
Zener Diode
Zener Diode Breakdown Characteristics
Fieldbus and Profibus
Difference between Fieldbus and Profibus
Valve Basics
Basics of Control Valves
Surface Detector Level Measurement System
Surface Detector Level Gauges (Plumb-bob)
Mechanical Engineering Design and Fabrication Projects
300+ Mechanical Engineering Design and Fabrication Projects
Master-Slave Flip-Flops Objective Questions
Baffle Nozzle Assembly Sensitive Mechanism
FOUNDATION Fieldbus junction boxes
Fieldbus Cables
Two Transistor Model of Thyristor
Thyristors – Switching, Two Transistor Model, Advantage, Applications
