  • Videos
  • Q & A
      • Practical Questions
    • MCQ
      • Instrumentation MCQ
      • Electrical MCQ
      • Electronics MCQ
      • Control Systems MCQ
      • Power Electronics MCQ
      • Multiple Choice Questions
  • EE
      • Electronics Q & A
      • Electronic Basics
      • Electronics Animation
      • Electrical Q & A
      • Electrical Machines
      • Electrical Animation
      • Power Systems
      • Switchgear & Protection
      • Transmission & Distribution
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Process Fundamentals
    • Videos
Reading: What Effect on Hydrostatic Level Transmitter if Liquid Density Changes?
  • PLC Tutorials
  • Control Systems
  • Videos
  • Q & A
    • MCQ
  • EE
  • Measure
    • Control Valves
    • Analyzers
    • Switches
    • Solenoid Valve
  • Control
    • PLC Tutorials
    • Control Systems
  • More
    • Formulas
    • TextBooks
    • Common
    • Excel Tools
    • Videos
Inst Tools > Blog > Practical Questions > What Effect on Hydrostatic Level Transmitter if Liquid Density Changes?
Suppose the density of the liquid within the vessel decreases. What effect will be on hydrostatic level transmitter (LT)?
Last updated: February 10, 2021 11:28 am
Practical Questions
4 Comments
1 Min Read
The lever transmitter (LT) in this level control system is hydrostatic; i.e. it senses liquid level in the vessel based on the hydrostatic pressure exerted by the liquid’s height in the vessel:
Suppose the density of the liquid within the vessel decreases. What effect will this have on the controlled liquid level?
In other words, what will the liquid level inside the vessel do over time in response to this change in density?
Be sure to explain why the level will be affected (or not affected), not just what will happen to the level.
Share your answers & explanation with us through the below comments section.
  • Liquid Level Sensors Symbols
  • Level Gauge Interface Problem
  • Tank Design and Accuracy
  • Sump Tank Level Transmitter
  • Guided Wave Radar Level Sensor
Credits: Tony R. Kuphaldt
Recommended Articles
Which Instrument is Faulty? Transmitter, Recorder, or Controller
Questions on Pneumatic Transmitter and Repeater
Baffle Nozzle Question
pH Monitoring System Triggers an Alarm
Programmable Logic Controller (PLC) Questions and Answers – 2
4 Comments
  • Flávio Stefani says:
    February 10, 2021 at 4:54 pm
    If the density of the fluid changes, so the Level Transmitter will identify the level different that the real measurement of the Vessel. Density has a direct impact on volume by the formula is d = m/V.
  • Gary Donaldson says:
    February 10, 2021 at 8:30 pm
    The transmitter is deriving level form a pressure measurement.
    In this case Pressure = ρgh (density x gravity constant x height)
    A change in density will increase or decrease the pressure measured.
    In effect there is more or less weight on the diaphragm of the transmitter depending on how dense the liquid in the tank is.
  • Alberto Fernández says:
    February 11, 2021 at 3:36 am
    Hola,
    Si la densidad disminuye, el transmisor LT lo interpretará como una disminución del nivel debido a que la presión medida se ve afectada por la densidad según la siguiente ecuación: P=h*g*d = m*m/s^2*kg/m3 = N/m2; debido a está variación en la medida el lazo de control LIC tratara de reducir la salida de la válvula para mantener el SP anterior a la reducción de la presión.
    February 11, 2021 at 3:38 am
    Hi,
    If the density decreases, the LT transmitter will interpret it as a decrease in the level because the measured pressure is affected by the density according to the following equation: P = h * g * d = m * m / s ^ 2 * kg / m3 = N / m2; Due to this variation in the measure, the LIC control loop will try to reduce the valve output to maintain the SP prior to the pressure reduction.
    Regards
208kSubscribersSubscribe
Recent Comments
Related Articles
Span of Pressure Gauge
How to Decrease Span of Pressure Gauge?
Heat Exchanger Differential Pressure Transmitter
Limit Switches Wiring
Draw Limit Switch Symbol ?
PSV lift pressure
Calculate PSV Lift Pressure
Allen-Bradley MicroLogix PLC Wiring
Programmable Logic Controller (PLC) Questions and Answers – 8
Allen-Bradley PLC Program
DP transmitter Elevated 10 Feet above the Vessel
Bourdon Tube Gauge Spiral Spring
What is the Purpose of Bourdon Tube Gauge Spiral Spring?
More Articles
Foundation Fieldbus Tutorials
Electron Spin Resonance Questions & Answers
Basic ESR Spectrometer
Malfunctioning Inlet Check Valves
Hook-up Diagram for Pressure Gauge
What is Instrument Hook Up Diagram ?
Basics of Ground Loops
Turbine Speed Control system using Woodward Governor
PLC program to control a water pump
PLC Program to Control a Water Pump
Closed-tank-DP-Level-Transmitter-with-wet-leg-Zero-elevation-Calibration
Closed tank DP Level Transmitter with wet leg Zero elevation Calibration
