Reading: Waste-Burning System OMRON PLC Program Example
Inst Tools > Blog > PLC Tutorials > Waste-Burning System OMRON PLC Program Example
Learn how to create a waste-burning system with a weighing function example with the CX-Programmer OMRON PLC program.
Last updated: September 24, 2024 5:12 am
6 Min Read
Learn how to create a waste-burning system with a weighing function example with the CX-Programmer OMRON PLC program using the Counter, Timer, and KEEP instructions.
Waste-Burning SystemProgram IO DetailsOMRON PLC Program Example
This PLC program has 4 buttons, the START_SYSTEM (0.00) button is used to turn ON the system, the STOP_SYSTEM (0.01) button is used to turn OFF the system, the FINISH_BUTTON (0.02) button is used to turn OFF the Finish Alarm, the RESET _COUNTER (0.03) button is used to Reset data in memory word COUNTER_SYSTEM(D0).
In this PLC program, when the START_SYSTEM (0.00) button is pressed, the system will be in a Standby state.
When the Weighing Indicator detects that the collected waste has exceeded the “Set value/25kg” limit, the burning process will be carried out and the Output BURNING_SYSTEM (100.00) will be ON.
The burning process will be carried out for 15 seconds and continued with the cooling process.
The cooling process will be carried out for 10 seconds and the EXHAUST_FAN (100.01) Output will be ON.
When the cooling process is complete, the ALARM_FINISH (100.02) output becomes ON. This alarm indicates that the waste burning and cooling process has been completed.
The ALARM_FINISH (100.02) Output will be OFF if the FINISH_BUTTON (0.02) button is Pressed.
The memory word COUNTER_SYSTEM (D10) will count the processes that have been carried out.
The memory word COUNTER_SYSTEM (D10) will be Reset to zero “0” if the RESET _COUNTER (0.03) button is Pressed.
When the STOP_SYSTEM (0.01) button is pressed, the system will be OFF.
Program IO Details
CommentInput (I)Output (Q)Memory BitsMemory WordsTimers
START_SYSTEM0.00
STOP_SYSTEM0.01
FINISH_BUTTON0.02
RESET_COUNTER0.03
BURNING_SYSTEM 100.00
EXHAUST_FAN 100.01
ALARM_FINISH 100.02
BURNING_TIMER    T0000
COOLING_TIMER    T0001
SYSTEM_ON  W0.00
WEIGHING_INDICATOR   D0
COUNTER_SYSTEM   D10
RUNG 0 (SYSTEM_ON)
In this Rung, when the START_SYSTEM (0.00) button is pressed, the memory bit SYSTEM_ON( W0.00) will be in the HIGH state. Because it uses the KEEP (011) instruction, the memory bit SYSTEM_ON(W0.00) remains in the HIGH state even though START_SYSTEM (0.00) button has been Released.
The memory bit SYSTEM_ON (W0.00) will change to LOW state if the STOP_SYSTEM (0.01) button is Pressed.
OMRON PLC program for waste-burning automation
RUNG 1 (BURNING AREA)
In this Rung, when the NO contact of memory bit SYSTEM_ON (W0.00) in HIGH state and the memory word WEIGHING_INDICATOR (D0) has a value Greater Than Or Equal to “25”, then the BURNING_SYSTEM (100.00) Output will be ON and the timer BURNING_TIMER (T0000) Start counting up to 15 seconds.
The BURNING_SYSTEM (100.00) Output will be OFF when the BURNING_TIMER (T0000) timer has finished counting. When the memory word WEIGHING_INDICATOR (D0) is Less Than Or Not Equal to “25”, then the BURNING_TIMER (T0000) timer will be Reset.
RUNG 2 (COOLING AREA)
In this Rung, when the NO contact of memory bit SYSTEM_ON (W0.00) in HIGH state and the NO contact of BURNING_SYSTEM (100.00) Output is ON, the EXHAUST_FAN (100.01) Output will be ON and the timer COOLING_TIMER (T0001) Starts counting up to 10 seconds.
Because it uses Latching, the EXHAUST_FAN (100.01) Output remains ON even though the BURNING_SYSTEM (100.00) Output is OFF. The EXHAUST_FAN (100.01) Output will be OFF when the timer COOLING_TIMER (T0001) has finished counting.
Waste-burning system PLC example
RUNG 3 (FINISH AREA)
In this Rung, when the NO contact of memory bit SYSTEM_ON (W0.00) is in a HIGH state and the NO contact of  EXHAUST_FAN (100.01) Output is ON, then the ALARM_FINISH (100.02) Output will be ON.
Because it uses Latching, the ALARM_FINISH (100.02) Output remains ON even though the EXHAUST_FAN (100.01) Output is OFF. The ALARM_FINISH (100.02) Output will be OFF if the FINISH_BUTTON (0.02) button is Pressed.
PLC waste incineration program example
RUNG 4 (COUNTER)
When the NO contact of memory bit SYSTEM_ON (W0.00) in HIGH state and the NO contact of EXHAUST_FAN (100.01) Output is ON, then the value in memory word COUNTER_SYSTEM (D10) will increase (+1).
RUNG 5 (RESET COUNTER)
In this rung, if the RESET_COUNTER (0.03) button is pressed, the data in memory word COUNTER_SYSTEM (D10) will be Reset to zero “0”.
  • PLC Product Sticker Machine with Weighing
  • Automatic Exhaust Fan XG5000 PLC Program
  • Perfume Mixing and Filling System PLC Logic
  • Product Painting with Omron PLC Program
  • Attendance System Program in Omron PLC
PLC Analog Signals Wiring Techniques
PLC Programming for Train Detection and Gate Operation
Auto and Manual Liquid Tank System: PLC Program Example
How to Work With Simulator in S7-1200 and S7-1500 PLC?
Relay Operation, Types, Symbols & Characteristics
PLC Program for 2 Push buttons to Control 1 Output
PLC 1 Push Button to Turn ON or OFF 1 Output
Safety Door Interlock PLC Program
Single-Acting Cylinder Control using Proximity Sensor
PID in Studio 5000
Motor ON OFF Logic in PLC
Conveyor Sorting System with Color Detection PLC Logic
#6 PLC Best Practices – Validate Timers and Counters
Profibus DP Master
DP Master System Configuration in PLC
PLC Programming Course Online Free
Yokogawa DCS CPU
System Cabinet Health Checks – PLC and DCS Industrial Automation
Modbus in Industrial Networks
PLC program for Latching and unlatched circuit
PLC Sizes and Applications
SCADA and HMI Systems - Differences, Similarities, Purpose
SCADA and HMI Systems – Differences, Similarities, Purpose
High and Low Ports on Pneumatic DP Transmitter
Identify High and Low Ports on Pneumatic DP Transmitter
Manometer with two different liquids
Calculate the Height of Glycerine
InTouch SCADA Training Course
Free InTouch SCADA Tutorial Course for Beginners
CODESYS HMI Interface
pressure switch ladder-logic diagram
Draw the appropriate Pressure Switch Symbol ?
Pressure Gauge Datasheet Preparation
How to Prepare Pressure Gauge Datasheet ?
Power Factor Meter Principle
What is an Automated Guided Vehicle
What is an Automated Guided Vehicle?
