Reading: Types of Pressure Measuring Scales
Inst Tools > Blog > Pressure Measurement > Types of Pressure Measuring Scales
Types of pressure measuring scales are Atmospheric, Gauge, Vacuum, Absolute, and Differential Pressure Scale.
Last updated: May 10, 2024 3:55 pm
2 Comments
When you are working in an industrial environment, you will mostly find a general parameter that influences the performance of a system. It is pressure. Pressure is a very fundamental concept and a base for all engineering studies, which helps in designing the system.
What is Pressure Measurement?TypesAtmospheric Pressure ScaleGauge Pressure ScaleVacuum Pressure ScaleAbsolute Pressure ScaleDifferential Pressure Scale
Pressure is measured in general by a scale reading and is still the most used one, which is the base for all measurements. So, it is necessary to study different types of pressure measuring scales.
First of all, let us understand what pressure is. A pressure is nothing but a force applied on a media over an area. Both the force and area matter for pressure calculation. So, for calculating pressure, it is first of all necessary to determine what the nearby surroundings is and how the area is. Because all these factors play an important part in determining pressure.
For this reason, pressure measurement scales use four main methods which we will discuss later in the post. These methods form the base for any other advanced pressure measurement methods. The general units of pressure are pascals (Pa), pounds per square inch (psi), or atmospheres (atm).
Types
The main types of pressure scales are as follows.
  1. Atmospheric Pressure Scale
  2. Gauge Pressure Scale
  3. Vacuum Pressure Scale
  4. Absolute Pressure Scale
  5. Differential Pressure Scale
The atmospheric pressure scale measures the pressure of the media with respect to the sea level. This is the baseline for starting pressure measurement. After this level, measurements then vary depending on above or below it.
The gauge pressure scale measures the pressure of the media with respect to the pressure in the ambient atmosphere. A simple example is a car mechanic checking the pressure of tires. Because a tire is in the atmosphere, the scale will calculate the force applied with respect to atmospheric pressure. A main disadvantage is that as the scale is exposed to the atmosphere, it is disturbed by some changes in it, mainly humidity and moisture in the air.
The vacuum pressure scale measures the pressure of the media with respect to the pressure below the ambient atmosphere. It is also called sealed pressure. It is mostly used for checking media pressure in an enclosed and tight surrounding, which is not exposed to the atmosphere. The value is mostly between 0-1 bars.
The Absolute Pressure Scale measures the pressure of the media with respect to the pressure at zero reference or an atmosphere where there is no air. Absolute Pressure Scale is mostly used in vacuum vessels by completely removing the air and making it zero. With this reference, the media pressure is then measured with respect to it. It is the most accurate method of all.
The Differential Pressure Scale is where the difference between two pressure media is measured. A general example of the Differential Pressure Scale will be a filter switch used in AHU (before and after HEPA filters). There, you get to know whether the filter is choked or not, by measuring the difference between inlet pressure and outlet pressure of air.
  • DataSheet for Pressure Calibration
  • Magnehelic Gauge Calibration
  • Selection of Master Instrument
  • Calibration of Temperature Chamber
  • Double Block and Bleed Valves Sequence
U-tube Manometer with equal & unequal limb types
Top 30 Interview Questions on Pressure Measuring Devices
Pressure Switch Calibration Procedure
Pressure Gauge Pulsation Damping
2 Comments
  • Your rishi Name says:
    August 2, 2024 at 8:58 pm
    instrument technician
    August 2, 2024 at 8:59 pm
    this app very good and very useful app thank you youra team all members
Why are Impulse Lines often Installed in a Sloping Manner?
Pneumatic Pressure Transmitters Principle
Differential Pressure Transmitter Calibration Procedure
5 Valve Manifold Operation
Scaling Sensor Output to Engineering Units
What is a Submersible Pressure Transmitter? Principle, Advantages
What is LVDT ?
Identify the Pressure Gauge Error
Differential Pressure Transmitters Static Pressure
What is Static Pressure Limit in DP Transmitter ?
C-Bourdon Tube
C-Bourdon Tube Pressure Gauge Theory
Differential Pressure Flow Transmitter Interview Questions
pressure-gauge-animation
Bourdon Tube Pressure Gauge Working Principle Animation
Fieldbus Pressure Transmitter Configuration
Foundation Fieldbus Pressure Transmitter Configuration
Gauge Cock
Pressure Gauge Cocks
7 Marketing Strategies for Engineering Companies
Problem on Tachogenerator
Instrumentation Thread
Thread Sealant Types and Selection for Instrumentation Applications
Backwashing Precoat Filters
Exhaust Fan Control
Exhaust Fan Control: Example of PLC Timer Programming
optical fiber cable junction box
Underwater Fibre Optic Cable
current-limiting-reactors-and-short-circuit-currents
Current Limiting Reactors and Short Circuit Currents
Chromatograph Principle
Basics of Chromatograph Operation
