Reading: Types of Allen Bradley PLC
Inst Tools > Blog > PLC Tutorials > Types of Allen Bradley PLC
In this article, I will discuss the types of Allen Bradley PLC, which are PLC 5, SLC 500, CompactLogix, ControlLogix, and MicroLogix.
Last updated: August 11, 2023 10:50 am
3 Comments
In this article, I will discuss the types of Allen Bradley PLC used from smaller applications to higher ones.
Types of Allen Bradley PLCMicroLogixCompactLogixControlLogixCompactLogix Versus ControlLogix
While designing a control system it is important to know about the PLC type you require.
The larger the project is, the higher end PLC requires to fulfill needs.
There are three types of PLC you can use,
  1. MicroLogix
  2. CompactLogix
  3. ControlLogix
These three types of PLC have the capability of handling the process. They are greatly differentiated by their software, expansion module limitation, memory space, and communication protocol.
MicroLogix
This type of PLC is used for the small control system.
Allen Bradley MicroLogix PLC
We can use where less I/O’s is required.
Cost-effective solution for small-scale applications.
Use rslogix500 software for the programming.
It comes with fixed I/Os (onboard I/O).
No physical rack is required. The input and output cards are connected using a ribbon cable.
The supported communication port is RS-232/485, an Ethernet port.
The controller supports 32 discrete I/O points and 6 analogs I/Os.
It comes with an LCD display.
CompactLogix
This type of PLC is used for the medium control system.
CompactLogix PLC
This type of PLC is used in machine control and packing system.
It comes with an inbuilt I/O system (onboard I/O).
We can use an expansion module to add additional I/Os, but there is a limitation of an expansion.
Rslogix 5000 software is required for the programming.
The supported communication protocol is Ethernet, ControlNet, DH-485, RS 232, Modbus.
The controller supports 30 I/o modules and 16 motion axes.
No LCD display.
Learn PLC Programming in 7 Hours - Allen Bradley PLC Training Course
ControlLogix
This type of PLC is used for a large control system.
ControlLogix PLC
This is also known as modular PLC as it uses separate I/O modules.
These types of PLC are used in processing, batching, and in a motion control system.
Rslogix 5000 software is required for programming.
It uses rack-based I/O modules.
Supported communication protocol are EtherNet/IP, ControlNet, DeviceNet, DH+.
The controller supports 32 points per module for digital I/O. For analog I/o it supports RTD and Thermocouple modules. Cn support 16 channel module.
No LCD display.
Apart from all the above mention things, there are some similarities between compact and Control Logix.
Both use a symbolic name, can create user-defined data types in both types of the PLC.
Both use Ethernet/IP, DeviceNet, ControlNet, DH communication protocol to transfer data.
Both require rslogix5000 software.
Still, anything misses out here? Then share your thought in the comment section.
Author: Suhel Patel
  • Modbus, Fieldbus, Profibus
  • Factory Acceptance Test
  • Run Motors in Sequential
  • OFF Delay Timer using PLC
  • Allen Bradley SLC 500 PLC
Factory Acceptance Test (FAT) of a PLC Panel
What is Seal-in Circuit ?
How to import GSD files into the TIA Portal? – Siemens PLC
PLC Based Industrial Conveyor Ladder Logic
Communication between Wincc and Tia Portal
3 Comments
  • Ghulam murtaza shah says:
    July 24, 2023 at 9:46 pm
    6
  • Sunday Ayeomoni says:
    September 17, 2023 at 10:39 pm
    Good evening, sir,
    I write to make enquiry of the prices of PLC PRODUCTS.
    I am an Electrical Engineering student from Nigeria. I need a small size PLC for programming. What are the prices of small size PLC products or what advice can you give me on getting a small size PLC Products for building projects?
    I await your apt reply graciously.
    Thank you.
    Sunday Ayeomoni
    • Abdi says:
      October 26, 2023 at 4:28 pm
      You have a very small project, you can use the Siemens LOGO!8 PLC.
      Part No. – 6ED1052-1CC08-0BA1
      Its got 12 Inputs and 4 Outputs.
      You can additionally buy expansion modules.
      Thanks
      Abdi
How a 4-20mA Transmitter Works?
RSLogix 5000 PLC Programming Procedure
PLC Programming for Traffic Barrier Control
Vijeo Designer software – Import and Export
Design a PLC program for Operational Sequence of Packaging Process
Programmable Logic Controller Boiler Logic
PLC Ladder Logic for Start-up Control of Boilers
PC-Based Motion Controller
Various Types of Delta PLC used in Industrial Automation
Most Asked Questions on SCADA
Most Asked Questions on SCADA with Answers
Redundant Power Supply
How Does Redundant Power Supply Work?
Introduction to SCADA
Claw Machine PLC Programming
Doll Claw Machine using Omron PLC Programming
FactoryTalk View Studio Site Edition Pop-Up Confirm Action
How to Automatically Close Pop-up in FactoryTalk View Studio?
Frequency Response MCQ
Bode Plots MCQ
Electrical & Electronics Measurements Objective Questions – Set 3
Diode-vi-characteristic-curve-for-forward-bias
VI Characteristic of a Diode
how-a-4-20ma-transmitter-works
Control Systems Questions & Answers
Control Systems Objective Questions & Answers – Set 4
Ziegler-Nichols closed-loop Formula
Tuning a Temperature Process Control Loop
Magnetic Tape Recorder Principle
What is Magnetic Tape Recorder ?
What is Linear Electric Motor
What is Linear Electric Motor?
