Reading: Tuning of PID Controllers
Inst Tools > Blog > Multiple Choice Questions > Tuning of PID Controllers
1. The input of a controller is
a) Sensed signal
b) Error signal
c) Desired variable value
d) Signal of fixed amplitude not dependent on desired variable value
Answer: b
Explanation: Controller is the block in the control system that control the input and provides the output and this is the first block of the system having the input as the error signal.
2. Phase lag controller:
a) Improvement in transient response
b) Reduction in steady state error
c) Reduction is settling time
d) Increase in damping constant
Answer: b
Explanation: Phase lag controller is the integral controller that creates the phase lag and does not affect the value of the damping factor and that tries to reduce the steady state error.
3. Addition of zero at origin:
Answer: a
Explanation: Stability of the system can be determined by various factors and for a good control system the stability of the system must be more and this can be increased by adding zero to the system and improves the transient response.
4. Derivative output compensation:
Answer: c
Explanation: Derivative controller is the controller that is also like high pass filter and is also phase lead controller and it is used to increase the speed of response of the system by increasing the damping coefficient.
5. Derivative error compensation:
Answer: d
Explanation: Damping constant reduces the gain, as it is inversely proportional to the gain and as increasing the damping gain reduces and hence the speed of response and bandwidth are both increased.
6. Lag compensation leads to:
a) Increases bandwidth
b) Attenuation
c) Increases damping factor
d) Second order
Answer: b
Explanation: Phase compensation can be lead, lag or lead lag compensation and integral compensation is also known as lag compensation and leads to attenuation which has least effect on the speed but the accuracy is increased.
7. Lead compensation leads to:
b) Attenuation
d) Second order
Answer: a
Explanation: High pass filter is similar to the phase lead compensation and leads to increase in bandwidth and also increase in speed of response.
8. Lag-lead compensation is a:
b) Attenuation
d) Second order
Answer: d
Explanation: Lag-Lead compensation is a second order control system which has lead and lag compensation both and thus has combined effect of both lead and lag compensation this is obtained by the differential equation.
9. Rate compensation :
b) Attenuation
d) Second order
Answer: c
Explanation: Damping factor is increased for reducing the oscillations and increasing the stability and speed of response which are the essential requirements of the control system and damping factor is increased by the rate compensation.
10. Negative exponential term in the equation of the transfer function causes the transportation lag.
a) True
b) False
Answer: a
Explanation: Transportation lag is the lag that is generally neglected in systems but for the accurate measurements the delay caused to transport the input from one end to the other is called the transportation lag in the system causes instability to the system.
Root Locus in Control Systems
Split-Range, Auto-Selector, Ratio & Cascade Systems
Concept of Stability in Control Systems
Flame Emission Photometers Questions & Answers
Ion Analyzer Questions & Answers
Operation of Chromatography Questions & Answers
Types of NMR Spectrometers Questions & Answers
Gas Solid Chromatography Questions & Answers
Measurement and Instrumentation Objective Questions – Part 3
Temperature Measurement Multiple Choice Questions
Block diagram Algebra Objective Questions
Construction of Root Loci
Measurement and Instrumentation Objective Questions – Part 2
Time Response Analysis
Time Response of Second Order Systems – IV
Fundamentals of Radiochemical Methods Questions
Digital Control Systems
Signal Reconstruction
Optimal Control Systems
Parameter Optimization
Performance Indices
Transistor Collector Characteristic Curves
Servo Operated Electro Magnetic Flowmeter Objective Questions
Convert Linear mA to Square root mA
PLC Memory Organization - Data Files and Program Files
PLC Memory Organization – Data Files and Program Files
gauge’s bourdon tube
Pressure Gauges : Remote and Chemical Seals
HVDC transmission compared to HVAC transmission
Comparison of HVDC transmission and HVAC transmission
What is Photoionization Detector (PID)
What is Photoionization Detector (PID)?
