Reading: What is Transformer Bushing? Working Principle
Inst Tools > Blog > Electrical Basics > What is Transformer Bushing? Working Principle
A transformer bushing is an electrical insulator that allows the safe passage of electrical conductor current.
Last updated: November 29, 2022 3:32 pm
Electrical Basics
In this post, we will see the concept of transformer bushing.
What is Transformer Bushing?Working Principle of Transformer Bushing
A transformer is a device that is used to step up or step down a voltage, depending upon the requirements. The transformer is required in the power transmission and generation stage, due to the high voltages involved.
Because the transformer deals in very high voltages, it is also necessary to take care that it functions properly without any leakage or damage.
Now, it is to be noted that a transformer has a very important component to help it function properly; which is its bushing. Without a bushing, it is not possible to operate a transformer in any high-voltage condition (typically in KV).
A bushing is an electrical insulator that allows the safe passage of electrical conductor current. It is similar to any insulator which surrounds a conductor, to help it prevent from making any untoward incident.
A transformer has two windings – primary and secondary (HV and LV). It makes the connection with external wires to conduct electricity. Though there is also LV involved in the transformer, it is not that too low which is negligible.
When a current passes through a conductor, it creates an electromagnetic field around it. So, the higher the current and voltage involved, the higher is the field generated.
Coming to the transformer, the current around the windings (means outside transformer case) is so strong, that it can ionize the insulator outside (air, gas, or vacuum) and make it conductive.
If the insulator’s dielectric strength is broken, then it will start conducting and once an insulator becomes conductive, it can either pass leakage current or even create a short circuit below the ground.
This will be very harmful to the transformer due to its proximity to it, which can even damage the transformer. To protect the transformer body from it, the bushing is used before and after the windings immediately.
A bushing has many components, but we will not see all of them. We will have a general look at the main working theory. It majorly consists of an insulated body, which has the conductor going inside through it.
The insulation is normally made of porcelain or capacitance-graded material (because it increases dielectric strength). Between the insulation body and conductor is a void space. This space is filled with electrical-grade mineral oil, which has excellent insulation properties. This prevents direct contact between the insulator and the conductor.
Porcelain is used because it handles a lot of electrical stress. The same theory goes with capacitance-graded material. Because high voltage stress can break low-grade insulation very easily, it is important to use this type of material. Also, they have great mechanical strength, which increases the lifetime of the bushing.
The oil is filled properly in proportion to the transformer tank level and insulated body level. When the current starts to flow from the conductor, due to the presence of such insulation around it, it is confined inside the conductor’s body only. Voltage flows to and fro directly between windings inside and the external wires carrying the current. This avoids any contact with the outside environment, and thus prevents the transformer body from any untoward incident.
The bushing controls the shape and intensity of the electric field and hence reduces the electrical forces on the insulating material. The bushings can thus be easily used for higher voltages (starting from 11KV and can go above 33KV too).
In this way, we saw the general concept of transformer bushing.
  • Basics of Electrical Transformer
  • Routine Tests of Transformer
  • Importance of Neutral Wire
  • Power and Instrument Cables
  • What Happens Pump Runs Dry?
Understanding Protection Relays – 50, 50N, 51, 51N
Types of Electrical Loads
What is a Bus Coupler in Electrical Panel?
What is an Air Circuit Breaker? Working Principle & Applications
How Do Electrical Shorts and Ground Faults Trip Circuit Breakers?
What is an Electrical Drive? Types, Advantages, Disadvantages
What is a Substation? Purpose of an Electrical Substation
Electrical Engineering Documents – Engineers Questions
What is a VFD? – Theory, Advantages, Disadvantages
Basics of Electricity Rates
Variable Motor Speed Control
Advantages of Star and Delta Systems
What is Electrical Interlocking?
Electrical Contactor Interlocking Circuit Explained
Constant Torque Load of Electrical Motor
Types of Motor Loads – Constant & Variable Torque, Horsepower
Working of Stepper Motor
Types of Stepper Motors
Difference Between HV and LV Cables
Dahlander Motor Control Circuit
Dahlander Motor Control Circuit and Power Circuit
Three-Phase Power Supply
Single Phase versus Three Phase Power
Lightning Arrester Basics and Terminology
Electrical Conduit Seal
Industrial Automation Acronyms
111 Industrial Automation Acronyms Questions and Answers
Addressable Fire Alarm System
Which One is Best – Conventional or Addressable Fire Alarm System?
Identify Instruments in Piping and instrumentation Diagram
Determine the Problems with the Level Transmitter and Gauge
Determine the Problems with Level Transmitter and Gauge
MCQ on Measurement and Instrumentation
Armoured cable
What is an Armoured Cable? Classification of Cables
PLC Program to Drain Same Products from Two Tanks
Interview Questions on Control Valves
