Reading: What is Trace Function in Tia Portal?
Inst Tools > Blog > PLC Tutorials > What is Trace Function in Tia Portal?
Last updated: March 4, 2021 12:03 pm
This article is about how to use trace function in TIA PORTAL.
You can find trace function in CPU-1200 and CPU-1500 models of Siemens PLC.
With this trace feature, you can configure specific data that you want to trace and record when the CPU meets a trigger condition that you define. The CPU stores the recorded data, and STEP 7 provides tools for retrieving and analyzing the recorded data.
So the traces function is used to track or record the Input or Output at the required condition. You can simply have to add Input or Output to the list and you can record the value and check the functionality of your processes within TIA PORTAL.
Trace Function
Follow the below steps to learn how to add Inputs or outputs to record the value.
Step 1:
Open TIA PORTAL. Create a new project and select CPU-1200 or CPU-1500.
Step 2:
In our example, I will write a simple program to check the functionality of the trace function.
I have written a simple program to turn ON the output for the specified time.
Here, I want to monitor the timer. So, I have to use trace function to do that.
IEC Timer in Tia Portal
Step 3:
To Add timer go to “trace” as shown in the below window.
Expand “trace” and click on add new trace. Now click on a newly added trace.
Tracing within a Siemens PLC
Step 4:
Double-clicking on the trace will open window as you can see below.
In “configuration” add a tag that you want to monitor. Here I have added timer.
Trace tool
Step 5:
In “sampling” define your cycle to record data. Here, I choose 100 means that it will record data until 100 cycles.
Trace Function
Step 6:
Here, in “trigger” choose when you want to start to record value.
Here I have chosen trigger when I will press the START button.
Trigger on Tag
Step 7:
Now after configuration, click on the icon as shown in the red square to transfer trace configuration to the device.
trace configuration
Step 8:
Clicking on the button will open up the record window.
Now click on an icon in the red circle to start recording.
trace functions for all CPU tags
Step 9:
To monitor the tag, make sure to stay online in the simulation environment.
As you can see with turning ON switch, recording of the selected timer has started which is in our case timing of the 5 seconds.
Traces in TIA Portal
Step 10:
To stop the recording press the icon as shown in the below window.
You can add as many variables as you want to monitor their status.
Siemens Trace
Author: Suhel Patel
  • Upload Siemens PLC Program
  • Digital Logic Functions
  • Wonderware Intouch Project
  • Memory Structure of Siemens
  • Open Platform Communication
UPS Working Principle and Types – Offline and Online UPS Systems
Feedback Monitoring in Safety PLC
Standard Colors in PLC Automation Systems
Download Allen Bradley RSLogix PLC Software
Concept of Interlocking in PLC
Allen Bradley Powerflex VFD
PLC Program using START and STOP Buttons
Difference between Motion Controller and PLC
PLC Compressor Control Ladder Logic
InTouch SCADA Login Password Security
Types of Interlocks
How to Control VFD with PLC using Ladder Logic
V1000 Family Programming Simulator Tool
Siemens PLC Force LED
Forcing and Modifying PLC Logic
Why 24 Volts DC Power Supply
Why 24 Volts DC Power Supply is used? – Industrial Automation Systems
PLC Program for Trash Compactor
HMI configuration for Delta VFD
Modbus Communication between Delta PLC with VFD
SCADA System
What is SCADA System?
Types of Script in Intouch Scada
Electrical Motor Jogging Operation
Wellhead Control Panel
Basics of Wellhead Control Panel (WHCP)
LIC and FIC Controllers
What LIC and FIC Controllers will do?
Top Embedded Systems Projects for Engineers and Students
200 Top Embedded Systems Projects for Engineers and Students
Ladder Logic for Stair-Case wiring using Toggle Switches
Auger Electron Spectroscopy
Latched and Momentary Operation of Motor PLC Program
Creating Logic in Intouch Using Scripting
Create Logic with InTouch Scada using Scripting
