Reading: Total Organic Carbon Analyzer Principle
Inst Tools > Blog > Analyzers > Total Organic Carbon Analyzer Principle
Last updated: March 5, 2018 3:47 am
Analyzers Guest Articles
3 Min Read
 TOC analyzer
Introduction of organic matter into water system occur only from living organisms and from decaying matter in source water, but also from purification and distribution system’s materials. In pharmaceuticals water distribution system, the organic matter are introduced in the form of endotoxins, microbes and development of biofilms on pipeline walls and biofilm growth so it is necessary to maintain low TOC levels. USP, EP and JP recognize TOC as a required test for purified water and Water for Injection. To make sure there is no cross contamination between products of different drugs, various cleaning procedures are performed.
TOC Analyzer measures TOC in pure and ultrapure water based on differential conductivity. This difference in conductivity is used to determine the amount of organic carbon present.
Principle
TOC Analyzer Principle
The sample water enters the analyzer and passes through a pressure regulator, which controls sample pressure to downstream components. Then, the sample is splits into two flow paths, where a portion of the flow is directed to the by-pass streamline, where resistivity/ conductivity and temperature are measured via a sensor (a). The other portion flows through another conductivity sensor before passing through the oxidation chamber. The sample is subjected to high intensity UV radiation at 185 nm, effectively oxidizing the sample to CO2.
Then, the oxidized sample passes into another conductivity sensor (b) where the conductivity and temperature are measured again. The difference between the values measured from the (a) and (b) sensors are determined, which is directly proportional to the concentration of organic impurity in the incoming water stream. The water from the (b) sensor is then passed through a flow meter which has a fine flow adjustment and then exits from the outlet which can be rejected or recycled.
The values of TOC, resistivity and temperature are displayed on the LCD screen of the instrument. These values can be printed or sent to a computer via RS 232 serial interface ports and other output can be obtained in the form of 4-20 mA analog output which is further connected to a DCS/PLC system.
Also Read : Basics of Total Organic Carbon Analyzers
Article by :
Muthukrishnan. R
pH Analyzer Do’s and Don’ts
3 Phase Motor Control using PLC Ladder Logic
Inhouse Moisture separator for Pneumatic Systems
Absorption Type Optical Analyzer
Capacitance Level Switch Calibration
Silica Analyzer Problems and Troubleshooting Tips
Chlorine dioxide Analyzer Principle
Top 100 Analytical Instrumentation Engineering Projects
H & B Gas Analyzer Principle and Calibration Procedure
pH Transmitter Problem
Accelerometer Vibration Probe Principle
NDIR Analyzer Filter Cells
pH measurement
Specific-Conductance-Calibration-Procedure
Specific Conductance Calibration Procedure
Total Organic Carbon Analyzer Working Principle
TOC Analyzer Working Principle
pH Analyzer Calibration and Troubleshooting
Troubleshooting pH Analyzer Common Problems
Chromatograph Principle
Basics of Chromatograph Operation
Displacer Level Transmitter weight calibration
Displacer Level Transmitter Dry Calibration with Weights
process gas chromatographs
Multi Column Gas Chromatograph
Circular Chart Recorder Calibration Procedure
Determine the statuses of all lamps and relay coils in the circuit
Determine the Status of Lamps and Relays in the Circuit ?
Instrumentation Design Details
Omron PLC painting program
Product Painting PLC Program using Omron CX-Programmer
Gas Detectors Calibration
Calibration of Gas Detectors
Pressure and Temperature Gauges
Control Valve Cv Formula
Control Valve Cv calculation
corroded tank
Cathodic Protection – Sacrificial Anodic and Impressed Current
Single-Phase Full Wave AC-DC Converter Objective Questions
