Δ-Y and Y-Δ Conversions
In many circuit applications, we encounter components connected together in one of two ways to form a three-terminal network: the “Delta,” or ∆ (also known as the “Pi,” or π) configuration, and the “Y” (also known as the “T”) configuration.
Delta and Wye Network
It is possible to calculate the proper values of resistors necessary to form one kind of network (∆ or Y) that behaves identically to the other kind, as analyzed from the terminal connections alone.
That is if we had two separate resistor networks, one ∆ and one Y, each with its resistors hidden from view, with nothing but the three terminals (A, B, and C) exposed for testing, the resistors could be sized for the two networks so that there would be no way to electrically determine one network apart from the other. In other words, equivalent ∆ and Y networks behave identically.
Δ and Y Conversion Equations
There are several equations used to convert one network to the other:
Delta to Wye Network Conversion Formula
∆ and Y networks are seen frequently in 3-phase AC power systems, but even then they’re usually balanced networks (all resistors equal in value) and conversion from one to the other need not involve such complex calculations. When would the average technician ever need to use these equations?
Application of ∆-Y Conversion
A prime application for ∆-Y conversion is in the solution of unbalanced bridge circuits, such as the one below:
A solution of this circuit with Branch Current or Mesh Current analysis is fairly involved, and neither the Millman nor Superposition Theorems are of any help since there’s only one source of power. We could use Thevenin’s or Norton’s Theorem, treating R3 as our load, but what fun would that be?
If we were to treat resistors R1, R2, and R3 as being connected in a ∆ configuration (Rab, Rac, and Rbc, respectively) and generate an equivalent Y network to replace them, we could turn this bridge circuit into a (simpler) series/parallel combination circuit:
Selecting Delta network to convert
After the ∆-Y conversion . . .
Delta converted to a Wye Circuit
If we perform our calculations correctly, the voltages between points A, B, and C will be the same in the converted circuit as in the original circuit, and we can transfer those values back to the original bridge configuration.
Calculations for Bridge Circuit
Resistors R4 and R5, of course, remain the same at 18 Ω and 12 Ω, respectively. Analyzing the circuit now as a series/parallel combination, we arrive at the following figures:
Delta to Wye and Wye to Delta Conversions
We must use the voltage drops figures from the table above to determine the voltages between points A, B, and C, seeing how they add up (or subtract, as is the case with the voltage between points B and C):
voltage drops in unbalanced bridge circuits
EA-B = 4.706 V
EA-C = 5.294 V
EB-C = 588.24 mV
Now that we know these voltages, we can transfer them to the same points A, B, and C in the original bridge circuit:
voltage drops in bridge circuits
Voltage drops across R4 and R5, of course, are exactly the same as they were in the converted circuit.
At this point, we could take these voltages and determine resistor currents through the repeated use of Ohm’s Law (I=E/R):
Determine resistor currents
Simulation using SPICE
A quick simulation with SPICE will serve to verify our work:
v1 1 0
r1 1 2 12
r2 1 3 18
r3 2 3 6
r4 2 0 18
r5 3 0 12
.dc v1 10 10 1
.print dc v(1,2) v(1,3) v(2,3) v(2,0) v(3,0)
.end
v1           v(1,2)       v(1,3)       v(2,3)       v(2)         v(3)
1.000E+01    4.706E+00    5.294E+00    5.882E-01    5.294E+00    4.706E+00
The voltage figures, as read from left to right, represent voltage drops across the five respective resistors, R1 through R5.
I could have shown currents as well, but since that would have required insertion of “dummy” voltage sources in the SPICE netlist, and since we’re primarily interested in validating the ∆-Y conversion equations and not Ohm’s Law, this will suffice.
Review
  • “Delta” (∆) networks are also known as “Pi” (π) networks.
  • “Y” networks are also known as “T” networks.
  • ∆ and Y networks can be converted to their equivalent counterparts with the proper resistance equations. By “equivalent,” I mean that the two networks will be electrically identical as measured from the three terminals (A, B, and C).
  • A bridge circuit can be simplified to a series/parallel circuit by converting half of it from a ∆ to a Y network. After voltage drops between the original three connection points (A, B, and C) have been solved for, those voltages can be transferred back to the original bridge circuit, across those same equivalent points.
Previous: Maximum Power Transfer Theorem
Share via
Send this to a friend
