Reading: Top PLC Manufacturers
Inst Tools > Blog > PLC Tutorials > Top PLC Manufacturers
The Top PLC Manufacturers are Siemens, Allen Bradley, ABB, Omron, Delta, Schneider Electric, and Mitsubishi.
Last updated: March 4, 2021 10:28 am
4 Comments
1 Min Read
The below list shows the top PLC manufacturers in the world.
PLC
  • Siemens
  • Allen Bradley
  • ABB
  • Omron
  • Delta
  • Honeywell
  • GeFanuc
  • Schneider Electric (Previously Modicon)
  • Mitsubishi
  • Delta
  • Yokogawa
  • Toshiba
  • Hitachi
  • Fuji
  • Panasonic
  • Fatek
  • Kinco
  • Inovance
  • Unitronics
  • Eaton
  • Bosch
  • Beckhoff
  • Wago
Did we miss any PLC manufactuer? Share with us through below comments section.
Tia Portal – OB30 Cyclic Interrupt Organization Block
PID Controller Output Types – PID_PWM and PID_Output
How to Troubleshoot a PLC System?
Rockwell PLCs for Large Scale Applications
Retentive ON Delay Timer using PLC
4 Comments
  • Gustavo Delgado says:
    January 21, 2021 at 7:15 pm
    LG, Festo, Telemechanic (now Schneider), Nice,
  • Alhadi Abusalah says:
    July 17, 2021 at 12:35 pm
    Rockwell automation
  • Desta says:
    May 9, 2023 at 3:33 am
    Great products.
    Your products are of high quality.
  • Dom says:
    October 9, 2023 at 12:39 pm
    Jetter PLCs, very solid, robust and reliable
How a 4-20mA Transmitter Works?
PLC Raw Count Calculation for Pressure Transmitter
Structured Text vs. Instruction List for PLC Programming
Siemens S7-300 CPU Suffix Explanation
Various Communication Protocols in PLC
Define the Order of Execution in Functional Block Diagram of Studio 5000
What is Process Control ?
What is Process Control?
Allen-Bradley PLC
PLC Programming for Sequential Batch Mixing System
Free Omron PLC Programming Course in HINDI
What is the consumed tag in Studio 5000 software?
Produced Tags and Consumed Tags in Studio 5000
Field Instruments
#11 PLC Best Practices – Instrument for Plausibility Checks
PLC Data Logging and Transmission
Moving Data between PLCs – Siemens Basics – TSEND TRCV
schottky diode working principle
Schottky Diode Working Principle
Difference between Current Transformer and Potential Transformer
Stripping tower unit
Inter Discipline Check (IDC)
What is Inter Discipline Check (IDC)?
Elevator PLC Ladder Logic
Demister Pads Problem
Problems with Demister Pads – Root Cause Analysis (RCA)
DP Diaphragm Capillary Seal Level instrument
DP Diaphragm Capillary Seal Level instrument Calibration Procedure
Detection System of Liquid Chromatography Questions & Answers
