Reading: Interview Questions for Instrumentation Engineer Freshers
Inst Tools > Blog > Instrumentation Interview Questions > Interview Questions for Instrumentation Engineer Freshers
Last updated: October 28, 2019 7:17 pm
51 Min Read
We prepared an article on Interview Questions Instrumentation Engineer Freshers. We wish all the best for young instrumentation engineers to get placed in the core job.
Interview Questions Instrumentation EngineerTemperature measurement using ThermocoupleDefine thermocouple?How the output voltage is measured the thermocouple?What is the nature of EMF induced in thermocouple?Define Skin effect?What are advantages of themocouple?What are the materials used for thermocouple?Who invented thermocouple?Explain temperature measurement using thermocouple?What are errors in this instrument?Define temperature?Temperature measurement using Resistance Temperature DetectorDefine RTD?What are major material used for RTD?Why gold & silver are not used for RTD?What is resistance temperature coefficient ?The material with high or low resistivity should be used for RTD ?Explain method of measurement of temperature?What are features of RTD?What are effect of temperature on RTD?Why RTD are popular?List advantages & disadvantages of RTD?Temperature measurement using ThermistorDefine thermistor.What are the materials used for construction of Thermisters?The temperature coefficient of material should be high or low?On what factors is depends?The characteristics of thermistor in linear or non-linear?What are the feature of thermistor?What is the temperature range for thermistor?What are two types of thermistor?Define self heating property of thermistor?List the applications of themistor?Displacement measurement using LVDTWhat is LVDT?What is the frequency range of ac applied to the primary winding?What is the null condition in the LVDT?Quest 4:- What are the advantages of LVDT?What are the uses of LVDT?Explain working of LVDT?List basic component of LVDT?What are the disadvantages of LVDT ?What is the value of excitation voltage?What is the value of operating frequency?Weight measurement using Strain Gauge Bridge Can you define strain gauge?What is types of strain gauges ?What are the materials used for strain guage?What is piezo resistive effect?What is hookes law?Explain the principle of operation?Explain the effect of temperature on strain Gauge ?What are the errors in strain guage?Define guage factor for strain guage ?Define hysteresis of strain gauge ?Speed measurement of motor using Magnetic Proximity SwitchWhat is the instrument used for measurement of speed.Name the instrument user to measure angular velocity?List the advantages of DC tachometer generator?List the disadvantage of AC tachometer generator?What is the function of resistance in dc tachometer generator?Specify the temperature range for operation of AC tachometer generator?Define tachometer?What are features of tachometer?Define toothed rotor?What features are considered for a tachometer?Speed measurement of motor using Photo Electric TransducerWhat are the two digital methods? What are materials used for piezoelectric transducer?Can you explain the advantages of digital method for measurement of speed?List the advantage of tachometer?Define gating period?What are factor used to control error?Define tachometer?List application of digital tachometer?On what factor frequency of motor depends?List disadvantages of digital tachometer?Explain working of tachometer?Piezo Electric Transducer QuestionsWhat is Piezo-electric transducer?What are two group of these transducer?Name the material used for this effect?Is these transducer direction resistive?Is the voltage sensitivity high or low?Which material is used as active element in piezoelectric transducer?How Piezo-electric works?Define transverse effect?Define electrical peoperties of piezoelectric transducer?What are application of piezoelectric transducer?Displacement measurement with Light Dependent Resistor (LDR)What is LDR?If resistance is low than light is dim or bright?What are material used for the LDR?What are the types of LDR?What are types of photoresistor?What are application of LDR?What is the function of LDR?What are benefits of LDR?What are two types of light dependent resistor?List dopants used in LDR?Displacement measurement using Inductive Pickup TransducerWhat quantity is measured with inductive pick-up transducer?What is the principal of operation of these transducer?On which factor inductance depends?What is differential output?What are coil used in transducer?What is smaller in size air or iron core ?What are two types of inductive pick up transducer?Which parameter are varied to change the displacement?What is the principal of inductive type transducer?What are advantages of differential output?Pressure measurement using Load CellLoad cell is what kind of transducer?What is load cell?What are the different type of load cell ?Sensitivity of the guage cell is low or high?Define pressure ?List application of load cell?How conversion in load cell is carried out?How load cell works?What is the use of load cell?Which strain guage is used to measure weight?Liquid level measurement using Capacitive type transducerAs the level increases what happens of capacitance?Capacitive type transducer is used for measurement of solids or liquids or both?What parameter are changed to change capacitor?What are the anodes used in it ?Define capacitance?How capacitive transducer works?How measurement of torque is carried out?How acceleration is measured in this transducer?List advantages of capacitive transducer?Which parameter are varied in capacitive type transducer?Study of Proportional mode of controllerDefine proportional control?Define Proportional bandwidth?Define offset?What is need of integral control?What is the role of integrator?What is role of derivative control?List example of on off control?List the features of on off controller?Define controller? List advantages?List various types of controller?What are types of analog controller?Performance of Data Acquisition System (DAS)What is data acquisitions?What the categories of DAS?Important factors for configuration of DAS what is multiplexing? Name the multiplexing techniques?What is transducer ?List components of DAS?Define sensor?Define signals ?Explain DAS hardware?Explain DAS software?
The thermocouple is a junction of two material used to convert heat into electrical energy.When a pair of wires made up ofdifferent metals is joined at one end and a temperature difference produce a voltage proportional to the voltage.
PMMC instrument.
DC in nature & in few MV.
Define Skin effect?
The skin effect is refers to the condition where at high frequency the current is forced to pass through outer surface of conductors as inductance & reactance of inner part is larger than that of outer part.
  1. it has rugged construction,
  2. temperature range is -270C to -2700C
  3. it is cheaper.
  4. good reproducibility.
The elements used are:Constantan, alloy of Nickel (Ni) – Copper (Cu) Chromel, alloy of Nickel (Ni) alloy of Nickel (Ni) and Aluminum (Al) Magnesium (Mg), base element Platinum (Pt), base element .
The basis of thermocouples was established by Thomas Johann Seebeck in 1821.
The basis of thermocouples was established by Thomas Johann Seebeck in 1821 when he discovered that a conductor generates a voltage when it is subjected to a temperature gradient.
Measuring this voltage requires the use of a second conductor material that generates a different voltage under the same temperature gradient. If the same material is used for the measurement, the voltage generated by the measuring conductor simply cancels that of the first conductor.
The voltage difference generated by the two dissimilar materials can be measured and related to the corresponding temperature gradient.
Based on Seebeck’s principle, it is clear that thermocouples can only measure temperature differences and they need a known reference temperature to yield the absolute readings.
The Seebeck effect describes the voltage or electromotive force (EMF) induced by the temperature gradient along the wire.
The change in material EMF with respect to a change in temperature is called the Seebeck coefficient or thermoelectric sensitivity. This coefficient is usually a nonlinear function of temperature.
CJC errors represent the difference between the actual temperature at the point where the thermocouple is connected to the measurement device (the cold-junction temperature), and the measured temperature by the device.
The CJC error is roughly a 1 to 1 contributor to the accuracy of the temperature measurement of the thermocouple, and is often one of the largest single contributors to the overall accuracy.
The overall CJC error includes the error from the CJC temperature sensor (often a thermistor) used to sense the cold-junction temperature, the error from the device measuring the CJC sensor, and the temperature gradient between the cold-junction and the CJC sensor.
Of these three errors, the temperature gradient between the cold-junction and the CJC sensor is generally the largest, and typically has the largest variation. The error from the CJC sensor can be a large contributor in many devices; however, high-accuracy thermistors or resistance temperature detectors (RTDs) with small errors are common in many high-end thermocouple measurement devices.
Define temperature?
Technically, temperature is a measure of the average kinetic energy of the particles in a sample of matter, expressed in units of degrees on a standardized scale.
Define RTD?
A resistance-temperature detector (RTD) is a temperature sensing device whose resistance increases with temperature.
Compared to other temperature devices, the output of an RTD is relatively linear with respect to temperature.
Platinum.
Because of low sensitivity.
0.39/c. for Pt & copper
High value of resistivity.
The method for calculating the resistance of an RTD is to place the device in a Wheatstone bridge that is excited by a known voltage.
A Wheatstone bridge consists of four individual resistors. If the RTD is the only unknown resistance in the bridge, the voltage measured from the bridge, the excitation voltage, and the values of the three other resistors is used to determine the resistance of the RTD.
This Wheatstone bridge configuration is known as a quarter-bridge configuration because the RTD is the only variable resistance and the resistances of the other three resistors is constant.
A7 RTDs are popular because of their excellent stability, and exhibit the most linear signal with respect to temperature of any electronic temperature sensor.
They are generally more expensive than alternatives, however, because of the careful construction and use of platinum.
RTDs are also characterized by a slow response time and low sensitivity; and because they require current excitation, they can be prone to self-heating.
Also Read : Practical Process Control System Questions & Answers
RTDs are commonly categorized by their nominal resistance at 0 °C. Typical nominal resistance values for platinum thin-film RTDs include 100 Ω and 1000 Ω.
The relationship between resistance and temperature is very nearly linear and follows the equation
For <0 °C ,
RT = R0 [ 1 + aT + bT2 +cT3 (T – 100) ]
For >0 °C,
RT = R0 [ 1 + aT + bT2 ]
Advantages
    1. Linearity over wide temperature range.
    2. high temperature operation
  1. better stability.
Define thermistor.
An electrical resistor whose resistance is greatly reduced by heating, used for measurement and control.
Sintered mixture of metallic oxide such as mangnese, nickel, cobalt, iron & uranium.
The negative temperature should be large.
Types of materials used and temperature.
Non-linear.
Thermistors (thermally sensitive resistors) are similar to RTDs in that they are electrical resistors whose resistance changes with temperature.
Thermistors are manufactured from metal oxide semiconductor material which is encapsulated in a glass or epoxy bead.
Thermistors have a very high sensitivity, making them extremely responsive to changes in temperature.
For example, a 2252 Ω thermistor has a sensitivity of -100 Ω/°C at room temperature. In comparison, a 100 Ω RTD has a sensitivity of 0.4 Ω/°C. Thermistors also have a low thermal mass that results in fast
response times,but are limited by a small temperature range. Thermistors have either a negative temperature coefficient (NTC) or a positive temperature coefficient (PTC).
The first has a resistance which decreases with increasing temperature and the latter exhibits increased resistance with increasing temperature.
The temperature range is -90C to 130C.
Thermistors can be classified into two types, depending on the sign of k.
If k is positive, the resistance increases with increasing temperature, and the device is called a positive temperature coefficient (PTC) thermistor, or posistor.
If k is negative, the resistance decreases with increasing temperature, and the device is called a negative temperature coefficient (NTC) thermistor.
When a current flows through a thermistor, it will generate heat which will raise the temperature of the thermistor above that of its environment.
If the thermistor is being used to measure the temperature of the environment, this electrical heating may introduce a significant error if a correction is not made.
Alternatively, this effect itself can be exploited. It can, for example, make a sensitive air-flow device employed in a sailplane rate-of-climb instrument, the electronic variometer, or serve as a timer for a relay as was formerly done in telephone exchanges.
The electrical power input to the thermistor is just: where I is current and V is the voltage drop across the thermistor. This power is converted to heat, and this heat energy is transferred to the surrounding environment.
1. PTC thermistors can be used as current-limiting devices for circuit protection, as replacements for fuses. Current through the device causes a small amount of resistive heating. If the current is large enough to generate more heat than the device can lose to its surroundings, the device heats up, causing its resistance to increase, and therefore causing even more heating. This creates a self-reinforcing effect that drives the resistance upwards, reducing the current and voltage available to the device.
2.PTC thermistors are used as timers in the degaussing coil circuit of CRT displays and televisions. When the unit is initially switched on, current flows through the thermistor and degauss coil. The coil and thermistor are intentionally sized so that the current flow will heat the thermistor to the point that the degauss coil shuts off in under a second.
3. NTC thermistors are used as resistance thermometers in low-temperature measurements of the order of 10 K.
4. NTC thermistors can be used as inrush-current limiting devices in power supply circuits. They present a higher resistance initially which prevents large currents from flowing at turn-on, and then heat up and become much lower resistance to allow higher current flow during normal operation. These thermistors are usually much larger than measuring type thermistors, and are purposely designed for this application.
What is LVDT?
LVDT is abbreviation of linear variable differential transformer. it is a transducer which converts voltage into displacement.
The frequency of ac applied to primary window may be between 50hz to 20khz.
When the core id at its normal(null) position, the flux linking the both secondary Windings are equal & hence equal emfs are induced in them.
Thus at null position Es1=Es2. the output voltage E0 is zero at null position.
The advantage of LVDT :-
  1. high range
  2. friction & electrical isolation
  3. immunity from external
  4. high input & sensitivity
  5. low power consumption
  1. LVDT can be used in all application where displacement ranging from a Fraction of mm to few cm to be measured.
  2. it can be used as a device to measure force, weight, & pressure etc.
When an AC excitation signal is applied to the Primary Coil (P), voltages are induced in the two Secondary Coils (S).
The Magnetic Core inside the Coil Winding Assembly provides the magnetic flux path linking the Primary and secondary Coils. Since the two voltages are of opposite polarity, the Secondary Coils are connected series opposing in the center, or Null Position.
The output voltages are equal and opposite in polarity and, therefore, the output voltage is zero. The Null Position of an LVDT is extremely stable and repeatable.
When the Magnetic Core is displaced from the Null Position, an electromagnetic imbalance occurs. This imbalance generates a differential AC output voltage across the Secondary Coils which is linearly proportional to the direction and magnitude of the displacement.
When the Magnetic Core is moved from the Null Position, the induced voltage in the Secondary Coil, toward which the Core is moved, increases while the induced voltage in the opposite Secondary Coil decreases.
LVDTs possess the inherent ruggedness and durability of a transformer and truly provide infinite resolution in all types of environments. As a result of the superior reliability and accuracy of LVDTs, they are the ideal choice for motion control.
The components are consisting of a Primary Coil and two Secondary Coils symmetrically spaced on a tubular center.A Cylindrical Case which encloses and protects the Coil Winding Assembly.
A rod shaped Magnetic Core which is free to move axially within the Coil Winding Assembly.A separate shield is used for Electromagnetic Shielding.
  • Very high displacement is required for generating voltage.
  • Shielding is required for magnetic fields.
  • It is affected by the vibrations.
  • It is affected by temperature changes.
The value of excitation voltage is 5v to 12v.
Note : Vary from model to model.
The frequency is about 50 Hz to 400Hz.
It a metal conductor is stretched or compressed, its resistance change on Account of the fact that both length & diameter of conductor change.
The Strain gauges are used for measurement of strain lay change in resistance.
The different types are grid type,rosette type,torque type and helical type.
Nickel, maganin, nichrome,cabon.
the change in value of resistance due to dimensional changes is called piezo resistive effect.
What is hookes law?
It give a relationship between stress & strain for linear strain curve. E=S/E
strain gauge takes advantage of the physical property of electrical conductance and its dependence on not merely the electrical conductivity of a conductor, which is a property of its material, but also the conductor’s geometry.
When an electrical conductor is stretched within the limits of its elasticity such that it does not break or permanently deform, it will become narrower and longer, changes that increase its electrical resistance end-to-end.
Conversely, when a conductor is compressed such that it does not buckle, it will broaden and shorten, changes that decrease its electrical resistance end-to-end.
From the measured electrical resistance of the strain gauge, the amount of applied stress may be inferred. A typical strain gauge arranges a long, thin conductive strip in a zig-zag pattern of parallel lines such that a small amount of stress in the direction of the orientation of the parallel lines results in a multiplicatively larger strain over the effective length of the conductor—and hence a multiplicatively larger change in resistance than would be observed with a single straight-line conductive wire.
Variations in temperature will cause a multitude of effects. The object will change in size by thermal expansion, which will be detected as a strain by the gauge. Resistance of the gauge will change, and resistance of the connecting wires will change.
Most strain gauges are made from a constantan alloy Various constantan alloys and Karma alloys have been designed so that the temperature effects on the resistance of the strain gauge itself cancel out the resistance change of the gauge due to the thermal expansion of the object under test.
Because different materials have different amounts of thermal expansion, self-temperature compensation (STC) requires selecting a particular alloy matched to the material of the object under test.
Zero Offset – If the impedance of the four gauge arms are not exactly the same after bonding the gage to the force collector, there will be a zero offset which can be compensated by introducing a parallel resistor to one or more of the gage arms.
Temperature coefficient of Gage Factor (TCGF) – This is the change of sensitivity of the device to strain with change in temperature. This is generally compensated for by the introduction of a fixed resistance in the input leg, whereby the effective supplied voltage will increase with temperature, compensating for the decrease in sensitivity with temperature.
Zero Shift with temperature – If the TCGF of each gage is not the same, there will be a zero shift with temperature. This is also caused by anomalies in the force collector. This is usually compensated for with one or more resistors strategically placed in the compensation network.
Linearity – This is an error whereby the sensitivity changes across the pressure range. This is commonly a function of the force collection thickness selection for the intended pressure and/or the quality of the bonding.
Hysteresis – This is an error of return to zero after pressure excursion.
Repeatability – This error is sometimes tied-in with hysteresis but is across the pressure range.
The ratio of change in value of resistance to change in value of length with respect to their original resistance and length is called guage factor.
If resistance of strain guage is measured with no strain applied and guage is then stressed to its maximum usable resistance value, the measured resistance after stress is removed differes from original value.
The inability to guage element to resume exact physical form it had before being elongated.This effect is called hysteresis.
Electromagnetic transducer.
Electrical tachometers:
  1. dc tachometer
  2. ac tachometer
  1. The direction of rotation is directly indicated by polarity of output voltage
  2. The output voltage is typically 10m v/rpm & can be measured with conventional type dc voltmeter.
  1. The difficulty with is this s/m is low speed the frequency of o/p voltage is low, & There are ripples in o/p voltage waves hopes.
  2. With high speed frequency increase, impedance of coils of tacho generator increases.
It is used for purpose of limiting the current from generator.
Tachometer Generators are designed for continuous operation in ambient temperatures ranging from -55°C to +100°C(-67°F to +212°F). Voltage output at 25°C will not deviate by more than 0.01% per degree of change within the range of -20°C to +75°C.
Define tachometer?
Tachometers are used to measure the velocity of a rotating object. They operate on the principle that a driven motor (i.e., a motor operated as a generator) produces a voltage that is proportional to the angular velocity of the motor.
The features are:
  1. Compact and Light Weight and can substitute a range of imported / indigenous tachos.
  2. High Linearity
  3. Low Ripple
  4. High Stability and Extreme Reliability in Hostile Industrial Environments.
The toothed rotor consists of a metallic toothed rotor mounted on shaft whose speed is to measured
A magnetic pick up is placed near toothed rotor.It is used for measurement of angular speed.
 The various feature are:
  1. operating range
  2. sensitivity.
  3. environmental compatibility.
  4. accuracy.
  1. Photoelectric type
  2. Inductive.
The material used are Quartz,Rochelle salt and barium titanate.
There is no physical contact is required with shaft whose speed is to be measured.It is simple and rugged in construction .
It is maintenance free. It is easy to calibrate. The information can be easily transmitted.
  1. It is simple & rugged in construction.
  2. It is maintenance free.
  3. It is easy to calibrate.
The digital meter measure freq by counting no of pulses which occur in short period of time called gating period.
The factors to control error
  1. Getting period.
  2. No of pulses gen per revolution.
Define tachometer?
A tachogenerator for detecting the rotation speed of a rotating machine part comprising: at least one magnetically acting encoder which can rotate with the machine part, said encoder comprising magnetically acting areas subdivided into angle parts spaced a distance apart from each other, said distance between said angle parts defining an angular pitch; wherein the magnetically acting areas are composed of ferromagnetic material or a magnetic pole ring; and wherein during rotation said encoder produces a measurement signal.
This is used for counting of revolution of motor,rotor etc.
The frequency of motor depends on no of holes in disc and speed of rotation.
  1. Light source must be replaced from time to time i.e. time period is 50,000 hours.
  2. accuracy depends on error represented by one pulse.
The disc has a no of equidistant holes on its periphery. At one side of disc a light source is fixed and at other end of disc and on line with light source,light sensor,the latter is unilluminated and produce no output.
When a hole appears between the two the light falling upon sensor produce an output pulse.
The material in which the electric potential appears as dimension of crystal are changed ley application of mechanical force.
Nature and Synthetic.
Rochelle salt, ammonium die hydrogen phosphate.
Yes.
Low.
The active element of most acoustic transducers used today is a piezoelectric ceramic, which can be cut in various ways to produce different wave modes.
The large piezoelectric ceramic element are quartz (SiO2) or barium titanate (BaTiO3).
The conversion of electrical pulses to mechanical vibrations and the conversion of returned mechanical vibrations back into electrical energy is the basis for ultrasonic testing. The active element is the heart of the transducer as it converts the electrical energy to acoustic energy, and vice versa.
The active element is basically a piece of polarized material (i.e. some parts of the molecule are positively charged, while other parts of the molecule are negatively charged) with electrodes attached to two of its opposite faces.
A force is applied along a neutral axis (y) and the charges are generated along the (x) direction, perpendicular to the line of force. The amount of charge depends on the geometrical dimensions of the respective piezoelectric element. When dimensions a,b,c apply,
Cx = dxyFyb / a,
where a is the dimension in line with the neutral axis, b is in line with the charge generating axis and d is the corresponding piezoelectric coefficient.
A piezoelectric transducer has very high DC output impedance and can be modeled as a proportional voltage source and filter network.
The voltage V at the source is directly proportional to the applied force, pressure, or strain. The output signal is then related to this mechanical force as if it had passed through the equivalent circuit.
Piezoelectric sensors have proven to be versatile tools for the measurement of various processes. They are used for quality assurance, process control and for research and development in many different industries.
Although the piezoelectric effect was discovered by Curie in 1880, it was only in the 1950s that the piezoelectric effect started to be used for industrial sensing applications.
Since then, this measuring principle has been increasingly used and can be regarded as a mature technology with an outstanding inherent reliability.
It has been successfully used in various applications, such as in medical, aerospace, nuclear instrumentation, and as a pressure sensor in the touch pads of mobile phones. In the automotive industry, piezoelectric elements are used to monitor combustion when developing internal combustion engines.
What is LDR?
A photoresistor, light dependent resistor (LDR) or cadmium sulfide (CdS) cell is a resistor whose resistance decreases with increasing incident light intensity. It can also be referred to as a photoconductor.
Bright.
Lead sulphide, Indium Antimonide.
photoelectric device can be either intrinsic or extrinsic. An intrinsic semiconductor has its own charge carriers and is not an efficient semiconductor, e.g. silicon. In intrinsic devices the only available electrons are in the valence band, and hence the photon must have enough energy to excite the electron across the entire bandgap.
Extrinsic devices have impurities, also called dopants, added whose ground state energy is closer to the conduction band; since the electrons do not have as far to jump, lower energy photons (i.e., longer wavelengths and lower frequencies) are sufficient to trigger the device.
If a sample of silicon has some of its atoms replaced by phosphorus atoms (impurities), there will be extra electrons available for conduction. This is an example of an extrinsic semiconductor.
Photoresistors come in many different types. Inexpensive cadmium sulfide cells can be found in many consumer items such as camera light meters, street lights, clock radios, alarms, and outdoor clocks.They are also used in some dynamic compressors together with a small incandescent lamp or light emitting diode to control gain reduction.
A6 One of the most common uses for light dependent resistors is in traffic lights. The light dependent resistor controls a built in heater inside the traffic light, and causes it to recharge over night so that the light never dies.
Other common places to find light dependent resistors are in: infrared detectors, clocks and security alarms.
The main purpose of a light dependent resistor is to change the brightness of a light in different weather conditions. This can easily be explained with the use of a watch. Some watches start to glow in the dark so that it is possible to see the time without having to press any buttons.
It is the light dependent resistor that allows the watch to know when it has gotten dark, and change the emissions level of the light at that time. Traffic lights use this principle as well but their lights have to be brighter in the day time.
There are many great benefits to light dependent resistors. They allow less power to be used in many different kinds of lights. They help lights last much longer. They can be trigged by several different kinds of triggers, which is very useful for motion lights and security systems.
They are also very useful in watches and cars so that the lights can turn on automatically when it becomes dark. There are a lot of things that light dependent resistors can do.
There are two basic circuits using light dependent resistors – the first is activated by darkness, the second is activated by light. The two circuits are very similar and just require an LDR, some standard resistors, a variable resistor ( potentiometer), and any small signal transistor.
The LDR uses dopants are
  • phosphorus,
  • indium,
  • gallium,
  • arsenic.
Measurement of displacement.
Self inductance of AC exited coil is varied by changed in magnetic circuit.
No. of turns, geometrical configuration changes in permeability.
The change is measured as the differential of two resulting output is differential output/
Air core & iron core.
Air core.
The two types are variable of self inductance and variation of mutual inductance.
the parameter varied are no of turns, geometrical configuration and permeability of coil.
This self generating type transducer utilizes the basic electrical principle that is motion between conductor and magnetic field induce a voltage in a conductor.
This relative motion between field and conductor is supplied by changes in the measurand.
The advantages are:
  1. sensitivity and accuracy is increased.
  2. output is less affected by external magnetic field.
  3. effect due to change in supply voltage and frequency are reduced.
Primary.
What is load cell?
A load cell is a transducer that is used to convert a force into electrical signal. This conversion is indirect and happens in two stages. Through a mechanical arrangement, the force being sensed deforms a strain gauge
Tensile cell and compressive cell.
High .
Define pressure ?
Pressure is represented as force per unit area.It is measured in pascal,
The applications are:
  1. Force measurement
  2. Portable weigh scales
  3. Platform scales
  4. Electronic weighbridge or truck weighing
  5. Electronic crane scales
  6. Hopper/Tank/Silo weighing
  7. Finding Center of gravity
  8. Onoard weighing
  9. Railcar weighing
This conversion is indirect and happens in two stages. Through a mechanical arrangement, the force being sensed deforms a strain gauge. The strain gauge converts the deformation (strain) to electrical signals.
A load cell usually consists of four strain gauges in a Wheatstone bridge configuration. Load cells of one strain gauge (quarter bridge) or two strain gauges (half bridge) are also available.
The electrical signal output is typically in the order of a few millivolts and requires amplification by an instrumentation amplifier before it can be used.
The output of the transducer is plugged into an algorithm to calculate the force applied to the transducer.
Also read : Top 100 Instrumentation Basics Questions
First, a force is applied to the mechanical system, which transfers the force to the strain gauge, which is basically an elastic foil connected to a wheatstone bridge configuration.
This wheatstone bridge configuration is the electronic device that the strain gauge uses to convert a certain amount of strain into electrical output. Essentially, the mechanical system and strain gauge are used to convert a force into an electrical output.
This electrical output is generally very small, so it is amplified using a form of electric amplification, for which an integrated circuit or transistor may possibly be used.
The electrical output is measured and the plugged into a computer algorithm. The algorithm uses the amount of electricity to tell a user how much force was applied to the load .
The load cell are used to measure large as well as small loads.
Load cell
Read Also: Biomedical Questions & Answers
Increases.
Both.
height, thickness and dielectric.
Auxilixiary and reference anode.
Define capacitance?
The ability to store charge in a electrically charged body is called capacitance.
Thus the capacitance of the variable capacitance transducer can change with the change of the dielectric material, change in the area of the plates and the distance between the plates.
Depending on the parameter that changes for the capacitive transducers, they are of three types as mentioned below.
In these capacitive transducer the dielectric material between the two plates changes, due to which the capacitance of the transducer also changes. When the input quantity to be measured changes the value of the dielectric constant also changes so the capacitance of the instrument changes.
This capacitance, calibrated against the input quantity, directly gives the value of the quantity to be measured. This principle is used for measurement of level in the hydrogen container, where the change in level of hydrogen between the two plates results in change of the dielectric constant of the capacitance transducer.
Apart from level, this principle can also be used for measurement of humidity and moisture content of the air.
The capacitance of the variable capacitance transducer also changes with the area of the two plates. This principle is used in the torquemeter, used for measurement of the torque on the shaft.
This comprises of the sleeve that has teeth cut axially and the matching shaft that has similar teeth at its periphery.
In he plates is variable, while the area of the plates and the dielectric constant remain constant. This is the most commonly used type of variable capacitance transducer.
For measurement of the displacement of the object, one plate of the capacitance transducer is kept fixed, while the other is connected to the object. When the object moves, the plate of the capacitance transducer also moves, this results in change in distance between the two plates and the change in the capacitance.
The changed capacitance is measured easily and it calibrated against the input quantity, which is displacement. This principle can also be used to measure pressure, velocity, acceleration etc.
  1. Simple to construct and inexpensive to produce.
  2. It is insensitive to temperature and pressure variations.
the parameter varied are dielectric and width of the capacitive transducer.
A most widely used form of continuos control mode is the proportional control action, in which a smooth,linear relation exists between the controller output and error.
It is defined as error required to cause a 100% change in controller output and error. And it is usually expressed as percentage of chart width.
Define offset?
The residual error in the operating point of controlled variable when a change in load occurs is called offset.
The integral control reduces the steady state variation.
The action of integrator then causes the controller output voltage begin to change to rise to steady state.
The derivative control provides a stabilizing influence on the system and is desirable in a system in which the value of controlled variable changes rapidly.
The example of on off control are domestic heating system,refrigeration, water tanks etc.
The features of on off controller are :
  1. The reaction time should be slow.
  2. There should be very little dead time.
  3. There should be little transfer lag.
An instrument used to achieve reference value or setpoint is called controller.
  • It is compactness.
  • It is faster.
  • It is easy to install.
  • It is reliable.
This are classified on basis of signal transmission required hydraulic, pneumatic, electrical and electronic.The analog controller are proportional,integral and proportional and integral control.
It relates to process of collecting output data in digital from as rapidly and accurately.
  1. these suitable for favorable environment.
  2. hostile environment.
  1. accuracy and
  2. no. of channels.
  3. sampling rate .
  4. signal
It is a process of sharing single channel with the more than one input. TDM and FDM.
They convert a physical quantity into electrical quantity .
The components of data acquisition systems include:
  • Sensors that convert physical parameters to electrical signals.
  • signal conditioning circuitry to convert sensor signals into a form that can be converted to digital values.
  • analog-digital converters, which convert conditioned sensor signals to digital values.
Define sensor?
Data acquisition begins with the physical phenomenon or physical property to be measured. Examples of this include temperature, light intensity, gas pressure, fluid flow, and force.
Regardless of the type of physical property to be measured, the physical state that is to be measured must first be transformed into a unified form that can be sampled by a data acquisition system. The task of performing such transformations falls on devices called sensors.
Define signals ?
Signals may be digital (also called logic signals sometimes) or analog depending on the transducer used.
Signal conditioning may be necessary if the signal from the transducer is not suitable for the DAQ hardware being used. The signal may need to be amplified, filtered or demodulated.
Various other examples of signal conditioning might be bridge completion, providing current or voltage excitation to the sensor, isolation, linearization.
For transmission purposes, single ended analog signals, which are more susceptible to noise can be converted to differential signals. Once digitized, the signal can be encoded to reduce and correct transmission errors.
DAQ hardware is what usually interfaces between the signal and a PC. It could be in the form of modules that can be connected to the computer’s ports (parallel, serial, USB, etc.) or cards connected to slots (S-100 bus, AppleBus, ISA, MCA, PCI, PCI-E, etc.) in the mother board. Usually the space on the back of a PCI card is too small for all the connections needed, so an external breakout box is required. The cable between this box and the PC can be expensive due to the many wires, and the required shielding.
DAQ cards often contain multiple components (multiplexer, ADC, DAC, TTL-IO, high speed timers, RAM). These are accessible via a bus by a microcontroller, which can run small programs. A controller is more flexible than a hard wired logic, yet cheaper than a CPU so that it is alright to block it with simple polling loops.
For example: Waiting for a trigger, starting the ADC, looking up the time, waiting for the ADC to finish, move value to RAM, switch multiplexer, get TTL input, let DAC proceed with voltage ramp. Many times reconfigurable logic is used to achieve high speed for specific tasks and Digital signal processors are used after the data has been acquired to obtain some results. The fixed connection with the PC allows for comfortable compilation and debugging. Using an external housing a modular design with slots in a bus can grow with the needs of the user.
Not all DAQ hardware has to run permanently connected to a PC, for example intelligent stand-alone loggers and oscilloscopes, which can be operated from a PC, yet they can operate completely independent of the PC.
A10 software is needed in order for the DAQ hardware to work with a PC. The device driver performs low-level register writes and reads on the hardware, while exposing a standard API for developing user applications. A standard API such as COMEDI allows the same user applications to run on different operating systems, e.g. a user application that runs on Windows will also run on Linux and BSD.
Also Read : Top 100 Sensors & Transducers Questions and Answers for Freshers
Gas Analyzers Interview Questions and Answers
Pneumatic Valves Questions & Answers
Ultrasonic Level Measurement Questions and Answers
Instrument Mechanic Interview Questions
Safety Relief Valve Questions & Answers
Modbus Communication Interview Questions and Answers
Safety Questions and Answers
Biomedical Instrumentation Questions and Answers
Interview Questions on Vibration Measurement
Instrumentation Engineers Interview Questions & Answers
How to Apply on Online JOB Portal Website?
Foundation Fieldbus Interview Questions and Answers
Instrumentation Cables Questions Answers
Instrumentation Cables Questions & Answers
Latest Control Valves Interview Questions
Control Valve Interview Questions and Answers
Most Frequently Asked Instrumentation Questions
General Instrumentation Questions
Smoke Detection System Questions
Interview Questions on Smoke Detection System
Precision Instruments Interview Questions
EPC Questions and Answers
Interview Questions on Industrial Wireless
Interview Questions and Answers on Load Cell
Loop Splitter Theory of Operation
4-20 mA Loop Splitter
Pole Placement by State Feedback
Three-Phase Rectifier Quiz
Gas Detection Excel Converters
Paddle Wheel Level Switch Principle
Relay Wiring
Basics-of-Gas-Chromatograph-Working-Principle
Working Principle of Gas chromatograph
Area Velocity Flow Meter Principle
