Reading: Time Response of Second Order Systems – II
Inst Tools > Blog > Multiple Choice Questions > Time Response of Second Order Systems – II
Last updated: November 27, 2021 5:41 pm
1. What will be the nature of time response if the roots of the characteristic equation are located on the s-plane imaginary axis?
a) Oscillations
b) Damped oscillations
c) No oscillations
d) Under damped oscillations
Answer: c
Explanation: complex conjugate (non-multiple): oscillatory (sustained oscillations)
Complex conjugate (multiple): unstable (growing oscillations).
2. Consider a system with transfer function G(s) = s+6/Ks2+s+6. Its damping ratio will be 0.5 when the values of k is:
a) 2/6
b) 3
c) 1/6
d) 6
Answer: c
Explanation: s+6/K[s2+s/K+6/K] Comparing with s2+2Gw+w2
w= √6/K
2Gw=1/K
2*0.5*√6/K =1/K
K=1/6.
3. The output in response to a unit step input for a particular continuous control system is c(t)= 1-e-t. What is the delay time Td?
a) 0.36
b) 0.18
c) 0.693
d) 0.289
Answer: c
Explanation: The output is given as a function of time. The final value of the output is limn->∞c(t)=1; . Hence Td (at 50% of the final value) is the solution of 0.5=1-e-Td, and is equal to ln 2 or 0.693 sec.
4. Which one of the following is the most likely reason for large overshoot in a control system?
a) High gain in a system
b) Presence of dead time delay in a system
c) High positive correcting torque
d) High retarding torque
Answer: c
Explanation: Large overshoot refers to the maximum peak in the response of the closed loop system and this is mainly due to the high positive correcting torque.
5. For the system 2/s+1, the approximate time taken for a step response to reach 98% of its final value is:
a) 1s
b) 2s
c) 4s
d) 8s
Answer: c
Explanation: C(s)/R(s) = 2/s+1
R(s) = 1/s (step input)
C(s) = 2/s(s+1)
c(t) = 2[1-e-t] 1.96 = 2[1-e-T] T= 4sec.
6. The unit step response of a second order system is = 1-e-5t-5te-5t . Consider the following statements:
1. The under damped natural frequency is 5 rad/s.
2. The damping ratio is 1.
3. The impulse response is 25te-5t.
Which of the statements given above are correct?
a) Only 1 and 2
b) Only 2 and 3
c) Only 1 and 3
d) 1,2 and 3
Answer: d
Explanation: C(s) = 1/s-1/s+5-5/(s+5)^2
C(s) = 25/s(s2+10s+25)
R(s) = 1/s
G(s) = 25/(s2+10s+25 )
w= √25
w = 5 rad/sec
G = 1.
7. The loop transfer function of controller Gc(s) is :
a) 1+0.1s/s
b) -1+0.1s/s
c) –s/s+1
d) s/s+1
Answer: a
Explanation: The transfer function of the controller is 0.1s+1/s
Gc(s) = 0.1s+1/s.
8. The peak percentage overshoot of the closed loop system is :
a) 5.0%
b) 10.0%
c) 16.3%
d) 1.63%
Answer: c
Explanation: C(s)/R(s) = 1/s2+s+1
C(s)/R(s) = w/ws2+2Gws+w2
Compare both the equations,
w = 1 rad/sec
2Gw = 1
Mp = 16.3 %
9. Consider a second order all-pole transfer function model, if the desired settling time(5%) is 0.60 sec and the desired damping ratio 0.707, where should the poles be located in s-plane?
a) -5+j4√2
b) -5+j5
c) -4+j5√2
d) -4+j7
Answer: b
Explanation: G = 1/√2
Gw = 5
s = -5+j5.
10. Which of the following quantities give a measure of the transient characteristics of a control system, when subjected to unit step excitation.
1. Maximum overshoot
2. Maximum undershoot
3. Overall gain
4. Delay time
5. Rise time
6. Fall time
a) 1,3 and 5
b) 2, 4 and 5
c) 2,4 and 6
d) 1,4 and 5
Answer: d
Explanation: Maximum overshoot, rise time and delay time are the major factor of the transient behaviour of the system and determines the transient characteristics.
Time of Flight Mass Spectrometer
Top 10 Industrial safety Objective Questions
Total Reflection Spectrometer Questions & Answers
Programmable Logic Controllers Multiple Choice Questions
Controller Components – Part 1 Objective Questions
Pneumatic Systems Objective Questions
Analyzers Based on Gas Density Questions & Answers
Stability Analysis by Describing Functions
Electron Probe Microanalyser Questions & Answers
DC Circuits Multiple Choice Questions
Realization of Basic Compensators
Measurement and Instrumentation Objective Questions – Part 2
Digital Control Systems Multiple Choice Questions
Liquid Chromatograph- Mass Spectrometer
Digital Circuits Questions & Answers
Logic Families Questions and Answers
Optimal Control Systems
Parameter Optimization : Servomechanims
Frequency Response MCQ
Output Regulator & the Tracking Problem
Hydrogen and Glass Electrodes Questions & Answers
Top 100 Control Systems Objective Questions & Answers
Stability in Frequency Domain
Cascade Compensation in Frequency Domain
Parallel RLC Circuit
Resonance, Resonant Frequency, Series and Parallel Resonance
compressor emergency shutdown system
Solenoid Valves Questions & Answers – 2
Basics of Vibration Measurement
Smart Transmitter Calibration Tutorial Part 2
Fieldbus Flow Transmitter Calibration
Top Beginner Soldering Mistakes
Top Beginner Soldering Mistakes and How to Avoid Them?
Gas and Liquid Measurement
Gas and Liquid Measurement: Processes and Solutions for the Industrial Sector
Lube Oil Console
Immersion Heaters in Lube Oil Consoles
