Reading: Strain Gauge Animation
Inst Tools > Blog > Animation > Strain Gauge Animation
Last updated: March 23, 2020 7:08 pm
Animation
3 Comments
1 Min Read
A strain gauge is a long length of conductor arranged in a zigzag pattern on a membrane.
When it is stretched, its resistance increases and Vice Versa.
Strain gauges are mounted in the same direction as the strain and often in fours to form a full ‘Wheatstone Bridge’.
The animation represents what might happen if a strip of metal were fitted with four gauges.
An downward bend stretches the gauges on the top and compresses those on the bottom.
A load cell may contain several similar strain gauges elements.
Credits : rdpe.com
Venturi Flow Meter – Working Principle, Advantages, Animation
Optical Pyrometer Working Principle Animation
Argonite/CO2 Flooding System Master & Slave Cylinder Operation
Eddy Current Working Principle Animation
Fundamentals of DC Motor Animation
Basics of Ball Valves
3 Comments
  • JoshWa2el says:
    June 8, 2020 at 10:54 am
    Thank you
  • Tayeeba says:
    June 3, 2021 at 2:27 pm
    Hey, I really need this GIF for my report. Please kindly if you can send me I will be very very grateful to you, please.
    Email: [email protected]
    • Hans Athmaram says:
      September 14, 2023 at 10:09 am
      Right click on the image and perform a “save image as”. Then you save as a gif.
Fire Water Sprinklers Working Principle
Stepper Motor Working Principle
Gas chromatograph Working Animation
Two Wire Sensor Working Principle and Animation
Transit Time Flow Meter Principle
Pushbutton switches and Types of Switches
Circuit Breaker Working Principle Animation
Deluge Valve Operation
Deluge Valve Working Principle
Radiometric level Principle
Radiometric level measurement Working Principle
bourdon-tube-pressure-gauge-working-animation
Working Principle of Pressure Gauge
Oscillating Piston Flow Meters Animation
Oscillating Piston Flow Meters Working Principle
load cell in deflection
Load Cell Working Principle
Electrical-Switches-Working-Animation
Electrical Switches Working Animation
Coriolis Mass Flow Meter Working Animation
Coriolis Meter Explained with Animation
Guided-wave Radar Level Measurement Animation
Advantages of Hydrogen cooling in Synchronous Generators
Online Testing of Solenoid Valve
Design and Accessories Required for Online Testing of Solenoid Valve
Percentage-to-Process-Variable-Conversion
Formula for Percentage to Process Variable Conversion
D Flip Flop Objective Questions
VFD Torque Boosting
What is Torque Boosting in Variable Frequency Drive (VFD)?
Introduction of Arithmetic Operation
Dall Tube Flow Meter Working Principle
Dall Tube Flow Meter – Principle, Advantages, Disadvantages
Motor Control On-Delay Timers Circuit
Motor Control Timer Circuit – Automatic Motor START and STOP
