In this article, we shared the top 300 Solid State Devices objective questions and answers for instrumentation, electrical, and electronics engineering students.
Solid State Devices Questions
The below list provides all the multiple-choice questions (MCQ) related to solid state devices.
1. A special type of semiconductor diode that varies its internal capacitance as the voltage applied to its terminal varies.
A) | Point contact diode |
B) | Zener diode |
C) | Silicon controlled rectifier |
D) | Varactor diode |
2. A positive charge outside the nucleus which is present only in semiconductor due to unfilled covalent bonds.
A) | Electron |
B) | Neutron |
C) | Hole |
D) | Proton |
3. Diffusion or storage capacitance is the term used to refer to
A) | The reverse bias capacitance of a diode |
B) | The breakdown capacitance of a zener diode |
C) | The effective capacitance of the rectifier |
D) | The forward bias capacitance of a diode |
4. When transistor applications call for a temperature operating condition which exceeds 185ºF, which element is most suitable?
A) | Silicon |
B) | Antimony |
C) | Impossible to operate transistor above 185ºF |
D) | Gallium |
5. What occurs in PN diodes when the minority carriers that cross the depletion region under the influence of the electric field gain sufficient kinetic energy to be able to break covalent bonds in atoms with which they collide?
A) | Drift |
B) | Diffusion |
C) | Avalanche breakdown |
D) | Saturation |
6. A measure of the ability of an LED to produce the desired number of lumens generated per applied watt of electrical energy.
A) | Luminous ability |
B) | Luminous intensity |
C) | Luminous efficiency |
D) | Luminous efficacy |
7. Which of the choices below does not describe a clipper circuit?
A) | Limiter |
B) | Baseline stabilizer |
C) | Amplitude selector |
D) | Slicer |
8. What is the typical bulk resistance of rectifier diodes?
A) | Greater than​​ 1 ohm |
B) | Less than​​ 1 ohm |
C) | Equal to​​ 1 ohm |
D) | It depends on the doping level |
9. The averaged dc voltage of a half-wave rectifier circuit is _____ of the value of the peak input voltage.
A) | 4.8% |
B) | 31.8% |
C) | 63.6% |
D) | 6.2% |
10. What is the most commonly used color of an LED?
A) | Green |
B) | Orange |
C) | Red |
D) | Blue |
11. A datasheet gives these JFET values; IDSS = 20 mA and pinch-off voltage is 5 volts. What is the gate-source cut-off voltage?
A) | 15 volts |
B) | -5 volts |
C) | 5 volts |
D) | 10 volts |
12. The frequency of a half-wave signal is
A) | Equal to the line frequency |
B) | One-half of the line frequency |
C) | One-fourth the line frequency |
D) | Twice the line frequency |
13. What occurs in PN diodes when the electric field in the depletion layer increases to the point where it can break covalent bonds and generate electron-hole pairs?
A) | Covalent breakdown |
B) | Avalanche effect |
C) | Diffusion |
D) | Zener breakdown |
14. The break up of nuclei into nuclear fragments that are themselves nuclei is called
A) | Neutrino |
B) | Isotope |
C) | Atom |
D) | Fission |
15. In a push-pull power amplifier, an input transformer can be used as a ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ providing equal amplitude input signals opposite in polarity
A) | Limiter |
B) | Phase reversal |
C) | Discriminator |
D) | Phase-splitter |
16. Another name for saturation current in a diode, which arises from the fact that it is directly proportional to the cross-sectional are of the diode.
A) | Thermal current |
B) | Constant current |
C) | Scale current |
D) | Steady-state current |
17. The maximum reverse voltage that can be applied before current surges is called
A) | Reverse recovery time |
B) | Reverse breakdown voltage |
C) | Maximum junction voltage |
D) | Forward voltage |
18. A ____​ is a light-sensitive device whose number of free electrons generated is proportional to the intensity of the incident light.
A) | Varicap |
B) | LED |
C) | Photodiode |
D) | Schottky diode |
19. What is approximately the sum of the number of protons and neutrons of an atom?
A) | Valence shell |
B) | Atomic mass |
C) | Atomic number |
D) | Atom subscript |
20. The way in which the gain of an amplifier varies with the frequency is called
A) | Logarithmic response |
B) | Frequency response |
C) | Voltage response |
D) | Phase response |
21. Which of the items below is not true with​ α ​of a transistor?
A) | It is the current gain of a common-base configuration |
B) | It is usually having a value of unity in some approximations |
C) | It is the ratio of the change in collector current to the change in base current. |
D) | It is the ratio of the change in collector current to the change in emitter current |
22. Which of the items below is not taking place inside a silicon crystal?
A) | Some free electrons disappears in the lattice due to vaporization |
B) | Other free electrons and holes are recombining |
C) | Some free electrons and holes are being created by thermal energy |
D) | Some free electrons and holes exist in an in-between state |
23. The highest energy band of an atom which can be filled with electrons.
A) | Valence band |
B) | Energy level |
C) | Conduction band |
D) | Insulation band |
24. What is the other name of Esaki diode?
A) | Tunnel diode |
B) | Hot-carrier diode |
C) | Shockley diode |
D) | Diac |
25. The current gain of an emitter follower circuit is
A) | High |
B) | Very low |
C) | Moderate |
D) | Low |
26. An acceptor atom is also called
A) | Trivalent atom |
B) | Minority carrier |
C) | Majority carrier |
D) | Pentavalent atom |
27. The maximum operating frequency of a transistor should be _____ percent of the frequency cut-off of the transistor to ensure best performance.
A) | 100 |
B) | 80 |
C) | 20 |
D) | 50 |
28. It is the current gain for the common-emitter configuration
A) | ​α​ |
B) | ​β​ |
C) | ​γ​ |
D) | ​δ​ |
29. The reduction of power handling capability of the diode due to the increase of ambient temperature from room temperature.
A) | Amplification factor |
B) | Power factor |
C) | Linear power derating factor |
D) | Maximum junction temperature |
30. Reducing the number of free electrons in a doped semiconductor forms a/an ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ semiconductor.
A) | NPN type |
B) | PNPN type |
C) | P type |
D) | N type |
31. What is another name for a PN crystal
A) | Junction diode |
B) | PN junction |
C) | Diode |
D) | Lattice |
32. What type of material usually has one valence electron?
A) | Transistor |
B) | Conductor |
C) | Insulator |
D) | Semiconductor |
33. It is a stable positive charge in the nucleus that is not free to move
A) | Hole |
B) | Electron |
C) | Proton |
D) | Neutron |
34. The electrons in the largest orbit travel _____ than the electrons in the smaller orbits.
A) | Faster |
B) | In the same velocity |
C) | More slowly |
D) | A little bit slower |
35. The creation voltage in a conductor or semiconductor by illumination of one surface
A) | Destriau effect |
B) | Night effect |
C) | Skin effect |
D) | Dember effect |
36. An acceptor atom contains how many valence electrons?
A) | 3 |
B) | 1 |
C) | 2 |
D) | 4 |
37. Boltzmann’s constant is equivalent to
A) | 1.3 x​ 108 V/m​ |
B) | 8032 x​​ 10-5 eV/ok |
C) | 1.62 x​​ 10-18 C |
D) | 0.7 V |
38. What is the most important factor of a power transistor?
A) | Output parameter |
B) | Heat dissipation |
C) | Output resistance |
D) | Input voltage |
39. What line is drawn between the open-circuit current on a JFET characteristic curve?
A) | Tangent line |
B) | Quiescent point |
C) | Load line |
D) | Operating point |
40. What is the net charge if a certain semiconductor losses 4 valence electrons?
A) | +4 |
B) | +8 |
C) | -4 |
D) | -8 |
41. Equivalent of the transistor at saturation in JFETs is ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ?
A) | Ohmic |
B) | Pinch-off |
C) | Constant-current |
D) | Breakdown |
42. The ______ transistor configuration has the highest value of input resistance.
A) | Emitter-stabilized |
B) | Common emitter |
C) | Common collector |
D) | Common base |
43. Junction diodes are commonly rated by its
A) | Capacitance and maximum reverse current |
B) | Inductance and PIV |
C) | Circuits resistance and maximum forward current |
D) | Maximum current and PIV |
44. The temperature coefficient of resistance of a semiconductor is
A) | Infinity |
B) | Negative |
C) | Zero |
D) | Positive |
45. The use of ______ coupling is particularly desirable in low level, low noise audio amplifier stages to minimize hum pick up from stray magnetic fields.
A) | LC |
B) | RC |
C) | Transformer |
D) | Direct |
46. What is the charge of the hole?
A) | Equal to zero |
B) | Equal to that of an electron |
C) | Equal to that of a proton |
D) | Equal to that ​ of a neutron |
47. A FET without a channel and no current occurs with zero gate voltage is
A) | Enhancement-mode FET |
B) | Depletion-mode FET |
C) | Metal-oxide transistor |
D) | CMOS |
48. What type of material usually has four valence electrons?
A) | Semiconductor |
B) | Conductor |
C) | Insulator |
D) | IGFET |
49. Approximate mass at rest of a proton is ​______​ to that of a neutron.
A) | Greater than |
B) | Less than |
C) | Comparable |
D) | Equal |
50. A semiconductor in its purest form is called
A) | Extrinsic semiconductor |
B) | Doped semiconductor |
C) | Pure semiconductor |
D) | Intrinsic semiconductor |
51. Approximately, the atomic weight of germanium is
A) | 32 |
B) | 28.09 |
C) | 16 |
D) | 72.7 |
52. A diode is a nonlinear device because
A) | It produces a nonlinear graph |
B) | Its current is not directly proportional to its voltage |
C) | It can rectify alternating current |
D) | It has a built-in barrier potential |
53. As a general rule, _____ are found only in semiconductors.
A) | Electrons |
B) | Bulk resistances |
C) | Depletion layers |
D) | Holes |
54. Which of the following is considered a unipolar device?
A) | FET |
B) | Inductor |
C) | BJT |
D) | Capacitor |
55. What is also called as the conventional amplifier?
A) | Common emitter circuit |
B) | Emitter follower circuit |
C) | Common base circuit |
D) | Common-collector circuit |
56. Which of the following is considered as the best conductor?
A) | Mica |
B) | Germanium |
C) | Gold |
D) | Silicon |
57. Two PN silicon diodes are connected in series opposing. A 5 V voltage is impressed upon them. Find the voltage across each junction at room temperature when nVT= 0.052 V.
A) | D. 3.21 V, 1.79 V |
B) | 0.236 V, 3.2 V |
C) | 4.764 V, 0.236 V |
D) | 0.036 V, 4.964 V |
58. Typical leakage current in a PN junction is in the order of
A) | nA |
B) | mA |
C) | µA |
D) | pA |
59. Diode that operates in the reverse breakdown voltage and is used as a voltage regulator.
A) | Zener diode |
B) | PIN diode |
C) | Tunnel diode |
60. When PN junction is connected to a battery in such a way that P-side is connected to positive terminal of the battery and negative terminal to N-side, this connections is known as
A) | Forward bias |
B) | Reverse bias |
C) | Knee bias |
D) | Back bias |
61. An extrinsic semiconductor produces ​_____​ when a pentavalent atom is added to the molten silicon
A) | N-type |
B) | Hybrid type |
C) | P-type |
D) | Intrinsic |
62. The principal characteristics of a tunnel diode.
A) | A negative resistance region |
B) | An internal capacitance that varies with the applied voltage |
C) | A constant current under conditions of varying voltage |
D) | A very high PIV device |
63. When both emitter and collector junction are forward biased, the transistor is said to be at ______​ region.
A) | Active |
B) | Saturation |
C) | Cut-off |
D) | Breakdown |
64. When charges are forced to move by the electric field of a potential difference, ​ ​ ​ ​ ​ ​ ​ ​ ​ current is said to flow.
A) | Reverse |
B) | Drift |
C) | Leakage |
D) | Threshold |
65. Charge of an electron is approximately equal to
A) | No charge |
B) | 1.6022 x​ 10-19 ​C |
C) | -1.6022 x​ 10-19 ​C |
D) | -1.6726 x​ 10-27 ​C |
66. What is the reason why FET has high input impedance?
A) | Because its input is reverse biased |
B) | Because of the impurity atoms |
C) | Because its input is a forward biased |
D) | Because it is made of semiconductor material. |
67. An LED and phototransistor is equivalent to a/an
A) | FET |
B) | Regulator |
C) | Optocoupler |
D) | Thermocouple |
68. A cold-cathode glow-discharge diode having a copper anode and a large cathode of sodium or other material.
A) | Tunnel diode |
B) | Anotron |
C) | BARITT diode |
D) | READ diode |
69. Which of the following is the equivalent circuit for a diode for third approximation?
A) | A switch in series with a battery in series with a resistance |
B) | A switch in series with battery |
C) | A switch in series with a resistance |
D) | A switch only |
70. Reverse recovery time of the diode is computed as the ​______​ of the storage time and transition interval from the forward to reverse bias.
A) | Product |
B) | Sum |
C) | Quotient |
D) | Difference |
71. What happens to the photoconductive material when light strikes on it?
A) | The conductivity of the material decreases |
B) | The conductivity of the material increases |
C) | Nothing important happens |
D) | The conductivity of the material stays the same |
72. What temperature is inside the diode, right at the junction of the p and n-type materials?
A) | Internal temperature |
B) | Absolute temperature |
C) | Junction temperature |
D) | Ambient temperature |
73. Clamper is also known as
A) | Charger |
B) | Clipper |
C) | Rectifier |
D) | DC restorer |
74. Which is a donor atom?
B) | Pentavalent atom |
C) | Aluminum |
D) | Boron |
75. What is the input control parameter of a FET?
A) | Source voltage |
B) | Gate voltage |
C) | Drain voltage |
D) | Gate current |
76. The value of coupling capacitor, Cc in RC coupling is about
A) | 10 µF |
B) | 0.01 µF |
C) | 100 µF |
D) | 0.1 µF |
77. It is the process by which atoms are constantly losing and regaining free electrons.
A) | Covalent bond |
B) | Parasitism |
C) | Ionization |
D) | Recombination |
78. If the line frequency is 60 Hz, the output frequency of a bridge rectifier is
A) | 240 Hz |
B) | 30 Hz |
C) | 120 Hz |
D) | 60 Hz |
79. What are often called square law devices?
A) | Diodes |
B) | Transistors |
C) | JFETs |
D) | SCRs |
80. Electron emitted by the mechanical impact of an ion striking a surface is called
A) | Moderately doped electrons |
B) | Secondary electrons |
C) | Primary electrons |
D) | Polarized charge |
81. When the transistors are used in video amplifiers, its main limitation is
A) | Poor filtering of signals |
B) | Poor frequency response |
C) | Low peak current |
D) | Low peak voltage |
82. What are the solid state gallium arsenide devices that emit beam of radiant flux when forward biased?
A) | Photoconductive cells |
B) | Photodiodes |
C) | LEDs |
D) | IR emitters |
83. The removal by electronic means of one extremity of an input waveform is called ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ .
A) | Clipping |
B) | Filtering |
C) | Amplifying |
D) | Clamping |
84. What is the approximate mass of a neutron at rest?
A) | 1.6022 x​ 10-19 ​kg |
B) | 9.1096 x ​ 10-31 ​kg |
C) | No mass |
D) | 1.6726 x​ 10-27 ​kg |
85. How much voltage would you measure across the base-emitter junction of a silicon transistor at class A?
A) | 3.6 V |
B) | 0 V |
C) | 0.7 V |
D) | 0.3 V |
86. FET has a pinch-off voltage of about
A) | 0.5 V |
B) | 20 V |
C) | 5 V |
D) | 10 V |
87. Photoconductive effect means
A) | The decreased conductivity of an illuminated semiconductor junction |
B) | The conversion of an electromagnetic energy to photonic energy |
C) | The conversion of photonic energy to electromagnetic energy |
D) | The increased conductivity of an illuminated semiconductor junction |
88. In power supplies, circuits that are employed in separating the ac and dc components and bypass the ac components around the load, or prevent their generation are called
A) | Diode circuits |
B) | Filters |
C) | Series capacitors |
D) | Limiters |
89. What are the two possible breakdown mechanisms in PN junction diodes?
A) | Reverse and breakdown effects |
B) | Threshold and knee effects |
C) | Avalanche and forward effects |
D) | Zener and avalanche effects |
90. Gallium arsenide, aluminum arsenide and gallium phosphide are classified as
A) | Insulators |
B) | Intrinsic material made by doping |
C) | Elementary semiconductor |
D) | Secondary semiconductor |
91. The most important application of schottky diodes is in
A) | Digital computers |
B) | Voltage regulators |
C) | Power supplies |
D) | Amplifier circuits |
92. When the electron transmit time through the base region is very short, this
A) | Creates a higher potential barrier |
B) | Provides a zener effect |
C) | Makes the transistor unable to amplify its signal |
D) | Provides higher cut-off frequency |
93. Electron mobility property of silicon at 300 K is approximately equal to ​m2/V-s
A) | 1.1 |
B) | 0.048 |
C) | 45 |
D) | 0.135 |
94. An energy band in which electrons can move freely
A) | Conduction band |
B) | Energy gap |
C) | Valence band |
D) | Insulation gap |
95. When a JFET is cut-off, the depletion layers are
A) | Very far apart |
B) | Close together |
C) | Touching |
D) | Separated |
96. Avalanche breakdown in a semiconductor takes place
A) | When forward current exceeds a certain value |
B) | When reverse bias exceeds a certain value |
C) | When forward bias exceeds a certain value |
D) | When potential barrier is reduced to zero |
97. Avalanche effects occurs at
A) | Lower forward voltages |
B) | Higher reverse voltages |
C) | Lower reverse voltages |
D) | Higher forward voltages |
98. A special type of diode which is often used in RF switches, attenuators and various types of phase shifting devices is called
A) | Tunnel diode |
B) | Zener diode |
C) | PIN diode |
99. another name for a light activated diode (LAD) is
A) | LCD |
B) | LED |
C) | IR emitter |
D) | Photodiode |
100. The varactor diode is also called as
A) | All of the answers |
B) | Varicap |
C) | Epicap |
D) | Voltage-variable capacitance |
101. Depletion–mode MOSFET acts mostly as
A) | Enhancement-mode MOSFET |
B) | A voltage source |
C) | A resistor |
D) | A JFET |
102. Structural category of a semiconductor diodes can be either
A) | Electrolytic and vacuum |
B) | Junction and point contact |
C) | Vacuum and gaseous |
D) | Electrolytic and point contact |
103. The ​ ​ ​ ​ as fundamental particle is considered as a bundle of radiant energy or light, the amount energy being related to the frequency.
A) | Photons |
B) | LED |
C) | Protons |
D) | Comet |
104. Suppose a JFET has IDSS = 7 mA and VGS(off) = -3 V. Calculate the drain current for a gate-source voltage of -1V.
A) | 31.2 mA |
B) | 4.45 mA |
C) | 3.1 mA |
D) | 0.455 A |
105. Unijunction transistor has three terminals, namely
A) | Gate, base 1 and base 2 |
B) | Base 1, base 2 and emitter |
C) | Grid, plate and cathode |
D) | Gate, cathode and anode |
106. The purpose of adding an impurity atom to an intrinsic crystal is
A) | To increase the resistivity of the semiconductor material |
B) | To alter its insulating property |
C) | To increase its electric conductivity |
D) | To stop conduction |
107. Silicon that has been doped with a pentavalent impurity is called a/an
A) | Intrinsic semiconductor |
B) | P-type semiconductor |
C) | Extrinsic semiconductor |
D) | N-type semiconductor |
108. The reason why electrons are not pulled into the nucleus of an atom.
A) | Because they are not being attracted by the positive nucleus. |
B) | Because of the centrifugal or outward force created by their orbital motion. |
C) | Because of the strong bonding between them that resists any force pulling them towards the nucleus. |
D) | Because of the force of attraction between them and the nucleus is weak. |
109. When temperature increases, barrier potential ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​
A) | Either increases or decreases depending on the semiconductor material used |
B) | Decreases |
C) | Increases |
D) | Remains the same |
110. There are two mechanisms by which holes and electrons move through a silicon crystal. They are
A) | Covalent bond and recombination |
B) | Free and charge particles |
C) | Diffusion and drift |
D) | Forward and reverse bias |
111. What type of diode is used for tuning receivers and is normally operated with reverse bias and derived its name from voltage variable capacitor?
A) | Zener diode |
B) | Tunnel diode |
C) | Hot-carrier diode |
112. When the number of free electrons is increased in doped semiconductor, it becomes a/an ____​ semiconductor.
A) | NP type |
B) | N type |
C) | P type |
D) | PN type |
113. Eg for silicon is 1.12 eV and germanium is 0.72 eV. It can be concluded that
A) | More number of electrons and hole pairs will be generated in silicon than in germanium at room temperature |
B) | High energy of charges is a property of silicon |
C) | The relationship of the two is not significant |
D) | Less number of electron hole pairs will be generated in silicon than in germanium at room temperature |
114. Which of the following doping elements have a valence of 5?
A) | Phosphorous |
B) | Boron |
C) | Gallium |
D) | Aluminum |
115. A graphical representation in transistor wherein the emitter current is plotted against the variable emitter base voltage​ VEB ​for constant value of collector-base voltage​ VGB​
A) | Input characteristic curve |
B) | Static curve |
C) | Semilog curve |
D) | Output characteristic curve |
116. Which of the items below describes an RF amplifier which will amplify a weak signal voltage in relatively the same proportion as it will amplify a stronger signal voltage?
A) | Inverting amplifier |
B) | Class A amplifier |
C) | Linear amplifier |
D) | Non-linear amplifier |
117. A class______amplifier stage operates with a small forward bias of the transistor so that some collector current flows at all times
A) | AB |
B) | A |
C) | C |
D) | B |
118. Varactor diode’s transition capacitance is directly proportional to the product of the permittivity of the semiconductor material and PN junction area but inversely proportional to its
A) | Resistance |
B) | Depletion width |
C) | Voltage |
D) | Threshold voltage |
119. The eight electrons which are tightly held by the atom are called
A) | Valence electrons |
B) | Outermost electrons |
C) | Covalent electrons |
D) | Bound electrons |
120. Termed as unwanted oscillation that may occur in most any type of circuits, oscillator, amplifier, power supply, receiver and transmitters
A) | Pulsating dc signal |
B) | Parasitic oscillations |
C) | White noise |
D) | Ripple |
121. Silicon that has been doped with a trivalent impurity is called a/an
A) | P-type semiconductor |
B) | Extrinsic semiconductor |
C) | Intrinsic semiconductor |
122. A volt-ampere characteristic curve that describes the relationship of the output voltage of a transistor to its output current is a set input current.
A) | Load line |
B) | Output characteristic |
C) | Saturation curve |
D) | Input characteristic |
123. Approximate energy gap in insulator is
A) | Eg = 0.67 eV |
B) | Eg = 1.1 eV |
C) | Eg = > 5 eV |
D) | Eg = 4 eV |
124. Optocoupler is otherwise known as
A) | Optoisolator |
B) | Photoconductive cell |
C) | Laser |
D) | Photodiodes |
125. It refers to any of the over 100 different substances which have never been separated into simpler substances by chemical means and which alone or in combination constitute all matter.
A) | Elements |
B) | Holes |
C) | Atom |
D) | Electrons |
126. When temperature of a pure semiconductor is increased, its resistance
A) | Increases |
B) | Remains the same |
C) | Decreases ​ ​ ​ ​ ​ ​ |
D) | None of the answers |
127. What refers to the temperature of the surrounding air?
A) | Freezing point |
B) | Cooling temperature |
C) | Atmospheric temperature |
128. Pure semiconductor atoms contain how many valence electrons?
A) | 1 |
B) | 2 |
C) | 4 |
D) | 8 |
129. A diode modeling circuit which considers the threshold voltage, average resistance and switch as the diode’s equivalent circuit.
A) | Ideal model |
B) | Piecewise linear model |
C) | Real model |
D) | Simplified model |
130. How many protons does the nucleus of a silicon atom contain?
A) | 29 |
B) | 4 |
C) | 14 |
D) | 32 |
131. What term is used to refer to the vacancy left by the free electron when it departs from its original shell?
A) | Hole |
B) | Proton |
C) | Neutron |
D) | Nucleus |
132. What is the ideal value stability factor?
A) | 0.5 |
B) | 1 |
C) | Infinite |
D) | 100 |
133. Another name for metal-oxide semiconductor field effect transistor is
A) | IGFET |
B) | GFET |
C) | Transistor |
D) | JFET |
134. A half-wave signal has a period of
A) | 8.3 µs |
B) | 16.7 µs |
C) | 8.3 ms |
D) | 16.7 ms |
135. ________ is a substance that contains atoms with several bands of electrons but with only one valence electron.
A) | Insulator |
B) | Semiconductor |
C) | Conductor |
D) | Resistor |
136. What diode has no depletion layer
A) | Schottky diode |
B) | Varistor |
C) | Varactor |
D) | Shockley diode |
137. The maximum permissible number of electrons in the third orbit is
A) | 32 |
B) | 18 |
C) | 2 |
D) | 8 |
138. What is the barrier potential of germanium at 25ËšC
A) | 0.4 V |
B) | 0.3 V |
C) | 0.5 V |
D) | 0.7 V |
139. The reason why electrons are not pulled in the positive charged nucleus is because of the _____ which usually became exactly equals the inward attraction of the nucleus.
A) | Frictional force |
B) | Centrifugal force |
C) | Kinetic energy |
D) | Energy at rest |
140. Which of the items below is not a good conductor?
A) | Ionized gases |
B) | Silicon |
C) | Electrolytes |
D) | Silver |
141. Which of the items below is a special precaution necessary in handling FET and CMOS devices?
A) | They have fragile leads that it might break off |
B) | They have microwelded semiconductor junctions that are susceptible to breakage |
C) | The are light sensitive |
D) | The are susceptible to damage and static charges |
142. What particles are of zero charge and zero mass?
A) | Fission |
B) | Isotopes |
C) | Neutrino |
D) | Fusion |
143. Each atom in the silicon crystal has how many electrons in its valence orbit?
A) | 8 |
B) | 4 |
C) | 2 |
D) | 32 |
144. Varistors are used for line filtering to eliminate spikes and dips and is also called
A) | Transient suppressor |
B) | Transient filter |
C) | Transient limiter |
D) | Transient regulator |
145. The energy gap for semiconductors made of silicon is
A) | Eg = 4 eV |
B) | Eg = 5 eV |
C) | Eg = 1.1 eV |
D) | Eg = 0.67 eV |
146. Which of the following is true about the emitter follower circuits?
A) | An emitter follower circuit is equivalent to a common emitter connection |
B) | The output signal is 180º out of phase with the input signal |
C) | The output signal is in phase with the input signal |
D) | The input signal is always equal to the output signal |
147. It is an arrangement of silicon atoms combine to form a solid such that there are now 8 electrons in the valence shell.
A) | Recombination |
B) | Crystal |
C) | Bonding |
D) | Solid silicon |
148. What is the principal characteristic of a zener diode?
A) | A constant current under conditions of varying voltage |
B) | A very high PIV |
C) | A constant voltage under conditions of carrying current |
D) | A high forward current rating |
149. A semiconductor is an element with a valence of
A) | Eight |
B) | Four |
C) | Two |
D) | One |
150. Which of the following has the highest input impedance
A) | MOSFET |
B) | BJT |
C) | Crystal diode |
D) | FET |
151. Atomic weight of silicon at 300 K is
A) | 5.32 |
B) | 72.7 |
C) | 28.09 |
D) | 16 |
152. If the temperature of a semiconductor material increases, the number of free electrons
A) | Decreases |
B) | Becomes zero |
C) | Increases |
153. What two elements widely used in semiconductor devices exhibit both metallic and nonmetallic characteristics?
A) | Silicon and germanium |
B) | Germanium and gold |
C) | Gold and silicon |
D) | Bismuth and galena |
154. For a full-wave rectifier, the output frequency
A) | Equals one-half the input frequency |
B) | Equals two times the input |
C) | Equals the line frequency |
D) | Is three times the line frequency |
155. When the collector current​ Ic ​is plotted against the collector base voltage at constant emitter​ Ie ​ the curve obtain is called
A) | Linear curve |
B) | Output characteristic curve |
D) | V-I curve |
156. Which of the choices below is another name for a photoconductive cell?
A) | Varicap |
B) | Photoresistive device |
C) | Photodiode |
D) | Varistor |
157. JFET’s input impedance is
A) | Is unpredictable |
B) | Approaches zero |
C) | Approaches unity |
D) | Approaches infinity |
158. A lightly doped semiconductor has
A) | Low resistance |
B) | No effect on a semiconductor |
C) | High resistance |
D) | More heat dissipated behaviors |
159. What orbit controls the electrical property of the atom?
A) | Valence orbit |
B) | First orbit |
C) | Fourth orbit |
D) | M shell |
160. The semiconductor device that radiate light or utilize light are called
A) | Passive devices |
B) | Active devices |
C) | Optoelectronic devices |
D) | Photoelectric devices |
161. The barrier potential for a silicon diode at 25ËšC is approximately
A) | 0.3 V |
B) | 0.4 V |
C) | 0.5 V |
D) | 0.7 V |
162. A photodiode which conducts current only when forward biased and is exposed to light.
A) | LED |
B) | Photoconductor |
C) | LAD |
D) | PIN |
163. What extrinsic semiconductor is produced when a trivalent atom is added to the molten silicon?
A) | N-type |
B) | Holes |
C) | P-type |
D) | Aluminum |
164. Which of the following is NOT one of the three distinct regions in the characteristic curve of a diode?
A) | Breakdown region |
B) | Reverse bias region |
C) | Saturation region |
D) | Forward bias region |
165. A coupled amplifier which has the major advantage of permitting power to be transported from the relatively high output impedance of the first stage to the relative low input impedance of the second stage.
A) | Direct coupling |
B) | RC coupling |
C) | Transformer coupling |
D) | Stabilized coupling |
166. A multiple-terminal solid-state device similar to a transistor that generates frequencies up to about 10000 MHz by injecting electrons or holes into a space-charge layer which rapidly forces these carriers to a collecting electrode.
A) | Klystron |
B) | Magnetron |
C) | Spacistor |
D) | IMPATT |
167. The sum of the resistance of the p-region and the n-region is called
A) | Extrinsic resistance |
B) | Junction resistance |
C) | Intrinsic resistance |
D) | Bulk resistance |
168. The amount of additional energy required to emit an electron from the surface of metal is called
A) | Knee voltage |
B) | Junction voltage |
C) | Potential barrier |
D) | Work function |
169. An amplifier has an output power of 3 watts. Determine the power output level with reference to 1 mW.
A) | -30 dBm |
B) | -40 dBm |
C) | 34.77 dBm |
D) | 40 dBm |
170. What silicon NPN tetrode serves as bistable negative-resistance device?
A) | BJT |
B) | Thermistor |
C) | FET |
D) | Binistor |
171. A large signal amplifier which is biased so that current is non-zero for less than one-half cycle.
A) | Class C |
B) | Class B |
C) | Class A |
D) | Class AB |
172. The voltage that turns on an enhancement-mode device is the
A) | Knee voltage |
B) | Threshold voltage |
C) | Gate-source cut-off voltage |
D) | Pinch off voltage |
173. The maximum temperature the diode can operate before burning.
A) | Maximum dissipation factor |
B) | Ambient temperature |
C) | Boiling temperature rating |
174. A diode that has a negative resistance region and widely used in the design of oscillators, switching networks and pulse generators.
A) | Hot-carrier diode |
B) | LED |
C) | Schottky diode |
D) | Tunnel diode |
175. The resistance of a forward biased PN junction is in the order of
A) | ​​mΩ |
B) | ​​kΩ |
C) | ​​µΩ |
D) | ​​Ω |
176. Which of the following materials has the smallest leakage current?
A) | Sulfur |
B) | Silicon |
C) | Germanium |
D) | Carbon |
177. Varactor diodes are commonly used
A) | As voltage controlled capacitance |
B) | As a constant voltage source |
C) | As voltage multiplier |
D) | As a constant current source |
178. What is also known as the photodiffusion effect?
B) | Skin effect |
C) | Dember effect |
D) | Night effect |
179. What term is used to describe the outermost shell of an atom?
A) | Free shell |
B) | Valence shell |
C) | Electron shell |
D) | Conductive cell |
180. The maximum rectification efficiency of a full-wave rectifier is
A) | 40.6 % |
B) | 81.2 % |
C) | 110 % |
D) | 92 % |
181. The peak inverse voltage of a half wave rectifier circuit is approximately equal to the ​ ​ ​ ​ _______ of the input signal.
A) | Peak amplitude |
B) | Current |
C) | Voltage sinusoidal |
D) | Frequency |
182. One of the important diode parameters which gives the magnitude of current the diode candle without burning.
A) | Forward breakdown current |
B) | Reverse current |
C) | Forward current |
D) | Reverse saturation current |
183. What is the resistivity of an extrinsic semiconductor?
A) | 3​ Ω-cm​ |
B) | 2​ Ω-cm​​ |
C) | 4​ Ω-cm​​ |
D) | 1​ Ω-cm​​ |
184. Which of the following doping elements have a valence of 3?
A) | Gallium |
B) | Aluminum |
C) | Boron |
D) | Phosphorous |
185. The amount of time between the creation and disappearance of a free electron.
A) | Recombination time |
B) | Lifetime |
C) | Propagation time |
D) | Bonding time |
186. The average dc voltage of a full wave rectifier circuit is ______ of the value of the peak input voltage.
A) | 31.8% |
B) | 63.6% |
C) | 48.1% |
D) | 1% |
187. An intrinsic semiconductor has some holes in it at room temperature. What causes these holes?
A) | Free electrons |
B) | Thermal energy |
C) | Doping |
D) | Valence electrons |
188. Percentage ripple can be calculated by getting the ​​______ and multiplying the result by 100%.
A) | Ratio of the input resistance and input voltage |
B) | Product of the ac current to dc current |
C) | Ratio of the ac voltage to dc voltage |
D) | Addition of the ac and dc component of the given signal |
189. The maximum rectification efficiency of a half wave rectifier is
A) | 40.6 % |
B) | 25 % |
C) | 20.6 % |
D) | 81.2 % |
190. What are the majority current carriers in the N-type silicon?
A) | Bounded electrons |
B) | Holes |
C) | Free electrons |
D) | Protons |
191. What semiconductor material is used in the construction of LED?
A) | Germanium |
B) | Gallium arsenide |
C) | Gallium |
D) | Silicon |
192. In enhancement-type MOSFETs, the _____​ regions are used for operation as a switch.
A) | Triode and saturation |
B) | Cut-off and triode |
C) | Saturation and active |
D) | Cut-off and saturation |
193. The time taken by the diode to operate in the reversed condition from forward conduction.​
A) | Time allocation |
B) | Lifetime |
C) | Reverse recovery time |
D) | Maximum power time |
194. What is the approximate voltage drop of LED?
A) | 3.8 V |
B) | 0.3 V |
C) | 0.7 V |
D) | 1.5 V |
195. What are the electrons at the outermost shell which are usually weakly attracted by the core such that an outside force can easily dislodge these electrons from the atom?
A) | Bound electrons |
B) | Loose electrons |
D) | Orbiting electrons |
196. When a diode is forward biased, the recombination of free electrons and holes may produce?
A) | Radiation |
B) | Light |
C) | All of the answers |
D) | Heat |
197. The reverse bias diode capacitance is termed as
A) | Reverse capacitance |
B) | Diffusion capacitance |
C) | Transition region capacitance |
D) | Storage capacitance |
198. Refers to a three-layer diode.
A) | Triac |
B) | Diac |
199. When doping increases, ______ of a semiconductor decreases.
A) | Bulk resistance |
B) | Impurity |
C) | Minority carrier |
D) | Conductivity |
200. What device uses a material catwhisker as its anode and is classified as a hot-carrier diode?
A) | Point-contact diode |
B) | Shockley diode |
C) | PIN |
D) | Crystal diode |
201. What factor is shown on a data sheet that tells how much you have to reduce the power of a ​ device?
A) | Reduction factor |
B) | Power factor |
C) | Reactive factor |
D) | Derating factor |
202. At absolute zero temperature, a semiconductor behaves as a/an
A) | Insulator |
B) | Good conductor |
C) | Variable resistor |
D) | Superconductor |
203. An electron in the conduction band
A) | Has higher energy than the electron in the valence band |
B) | Has lower energy that the electron in the valence band |
C) | Jumps to the tip of the crystal |
D) | Losses its charge easily |
204. In an n-type semiconductor, free electrons are called
A) | Majority carriers |
B) | Minority carriers |
C) | Charge carriers |
205. Which of the following items is not a type of material?
B) | Diode |
C) | Conductor |
D) | Insulator |
206. The sharing of valence electrons to produce a chemically stable atom
B) | Bound electrons |
C) | Recombination |
D) | Crystal |
207. When PN junction is connected to a battery in such a way that P-side is connected to negative terminal of the battery and positive terminal to N-side, this connections is known as
A) | Forward bias |
B) | Reverse bias |
C) | Positive bias |
D) | Depletion connection |
208. Zener effect only depends on the
A) | Intensity of the magnetic field |
B) | High-speed majority carriers |
C) | Intensity of the electric field |
D) | High-speed minority carriers |
209. A silicon diode has a maximum allowable junction temperature of 150ºC.​
Find the maximum allowable power dissipation at 25ºC temperature if the diodes thermal resistance is 0.4 ºC/mW.
A) | 117 mW |
B) | 313 mW |
C) | 600 mW |
D) | 238 mW |
210. Which of the following doping elements have a valence of 4?
A) | Aluminum |
B) | Gallium |
C) | Silicon |
D) | Arsenic |
211. The voltage gain of an emitter follower circuit is
A) | Low |
B) | Moderate |
C) | High |
D) | Very high |
212. Who invented the feedback amplifier in 1928?
A) | Harold Black |
B) | Bell Labs |
C) | Henry Brattain |
D) | Mark Twain |
213. Under standard conditions, pure germanium has a resistivity of
A) | 60​​ Ω-m |
B) | 60​​ Ω-mm |
C) | 60 x​​ 10-4 |
D) | 60​​ Ω-cm |
214. The energy gap for germanium made semiconductor is
A) | No energy gap |
B) | Eg = 1.1 eV |
C) | Eg = 0.67 eV |
D) | Eg = 5 eV |
215. What type of diode is used for tuning receivers; operate with reverse bias and derived its name from voltage-variable capacitor?
A) | Zener diode |
B) | Varactor diode |
D) | Tunnel diode |
216. What term is used to describe the released electrons dislodged from its original shell due to the increase in temperature which joins into a larger orbit?
B) | Merge electrons |
D) | Free electrons |
217. When the emitter junction is forward biased while the collector junction is reverse biased, the transistor is at ​_____ ​ region.
A) | Saturation |
B) | Breakdown |
C) | Cut-off |
D) | Active |
218. An extrinsic semiconductor is a
A) | Good conductor |
B) | Pure semiconductor |
C) | Good insulator |
D) | Doped semiconductor ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ |
219. In enhancement-type MOSFETs, the ​______ region is used if the FET is to operate as an amplifier.
A) | Triode region |
B) | Saturation region |
C) | Cut-off region |
D) | Diode region |
220. Which of the items below is not a pentavalent atom?
A) | Antimony |
B) | Arsenic |
C) | Aluminum |
D) | Phosphorus |
221. An ideal diode
A) | Should have infinitely large resistance in forward as well as reverse bias |
B) | Should have a zero resistance in the forward bias as well as in reverse bias |
C) | Should have zero resistance in forward bias and an infinitely large resistance in reverse bias |
D) | Should have an infinitely large resistance in the forward bias and zero resistance in reverse bias |
222. What in a semiconductor is defined as the incomplete part of an electron pair bond?
A) | Ion |
B) | Valence electron |
C) | Impurity |
D) | Hole |
223. What happens to the voltage drop across the diode when current flow increases rapidly in a forward-biased diode?
A) | Decreases |
B) | Remains relatively constant |
C) | Increases |
D) | Becomes zero instantly |
224. Present atomic theories place the mass and positive charge of an atom in a central nucleus composed of protons and
A) | Magnetron |
B) | Holes |
C) | Neutrons |
D) | Core |
225. Which of the following choices is an advantage of a MOSFET over a BJT in an RF amplifier circuit?
A) | Low noise |
B) | Low voltage operation |
C) | Low amplification of signals |
D) | Compatibility |
226. The nucleus of a copper atom contains how many protons?
A) | 2 |
B) | 29 |
C) | 18 |
D) | 1 |
227. For either germanium or silicon diodes, the barrier potential decreases ​_____​ for each Celsius degree rise.
A) | 2 Mv |
B) | 1 mV |
C) | 3 mV |
D) | 4 mV |
228. A heavily doped semiconductor has
A) | More heat dissipation |
B) | High resistance |
C) | Low resistance |
D) | No effect on the semiconductor characteristics |
229. Impedance matching in circuit is important for ​_______ transfer of energy.
A) | Limited |
B) | Maximum |
C) | Minimum |
D) | Enough |
230. An emitter resistor is used for ______ in most amplifier circuits.
A) | Current limitation |
B) | Temperature stabilization |
C) | Voltage amplification |
D) | Biasing a bipolar junction transistor |
231. What electronic circuit converts AC to DC where the DC output peak value can be greater than the AC input peak value?
A) | Rectifier |
B) | Clipper |
C) | Voltage multiplier |
D) | Clamper |
232. A ​______ is considered a current controlled device.
A) | Resistor |
B) | Diode |
C) | Field effect transistor |
D) | Transistor |
233. How many electrons are there in the fourth orbit of a copper atom?
A) | 2 |
B) | 4 |
C) | 1 |
D) | 3 |
234. The forward resistance crystal diode is in the order of
A) | ​mΩ​ |
B) | ​kΩ​ |
C) | ​µΩ​ |
D) | ​Ω​ |
235. What refers to the annihilation of a hole and electron?
B) | Doping |
C) | Bonding |
D) | Diffusion |
236. The equation for JFET’s transconductance.
A) | ​​gm = VGS / IC |
B) | ​​​​gm = IC / VDS |
C) | ​​​​gm = IG / VG |
D) | ​​​​gm = VGS x IC |
237. A large signal amplifier which is biased so that collector current flow continuously during the complete electrical cycle of the signal as well as when no signal is present
A) | Class B |
B) | Class A |
C) | Class C |
D) | Class AB |
238. A full-wave signal has a period of
A) | 16.7 ms |
B) | 8.3 µs |
C) | 16.7 µs |
D) | 8.3 ms |
239. What is associated with random motion due to thermal agitation in the movement of holes and electrons in a silicon crystal?
B) | Drift |
C) | Diffusion |
D) | Doping |
240. What is the reason why a common collector is used for impedance matching?
A) | Its output impedance is very low |
B) | Its input impedance is very high |
C) | Its input impedance is very low |
D) | Its output impedance is very high |
241. With PNP voltage divider bias, you must use
A) | Negative power supplies |
B) | Ground |
C) | Resistors |
D) | Positive power supplies |
242. The property or ability of a material to support charge flow or electron flow
A) | Conductance |
B) | Permeance |
C) | Resistivity |
D) | Resistance |
243. What is considered as the key electrical conductivity?
A) | The number of protons in the nucleus |
B) | The number of protons plus the number of electrons in the atom |
C) | The number of neutrons in the nucleus |
D) | The number of electrons in the valence orbit |
244. What diode gives off light when energized?
A) | Photoconductive cell |
B) | Photodiode |
C) | Tunnel diode |
D) | LED |
245. What is the largest region of a bipolar transistor?
A) | Emitter |
B) | Collector |
C) | Base |
D) | P-region |
246. Defined as random motion of holes and free electrons due to thermal agitation
A) | Ionization |
B) | Fission |
C) | Fusion |
D) | Diffusion |
247. When both emitter and collector junctions are reverse biased, the transistor is said to be at ​ ____​ region.
A) | Cut-off |
B) | Active |
C) | Saturation |
D) | Amplifying |
248. An equivalent circuit of a diode in which it is represented as a switch in series with a barrier potential.
A) | Fourth approximation |
B) | Second approximation |
C) | First approximation |
D) | Third approximation |
249. If the input frequency of a full-wave rectifier is 400 Hertz, the ripple frequency will be ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ .
A) | Equal to the input frequency divided by two |
B) | Quadruple of the input frequency |
C) | Twice as great as the input frequency |
D) | Equal to a quarter of its input frequency |
250. The charge of proton has the same value to that of an electron but
A) | Usually not important |
B) | Lesser than in some cases |
C) | Opposite in sign |
D) | Greater in some cases |
251. Mass of proton or neutron is ​ ​_____ times that of an electron.
A) | 1836 |
B) | 2000 |
C) | 1386 |
D) | 10 |
252. A transistor configuration with the lowest current gain.
A) | Emitter-follower |
B) | Common base |
D) | Common emitter |
253. Its maximum amount of reverse voltage which can be applied on a diode before breakdown point is reached.
A) | Breakdown voltage |
B) | Peak inverse voltage |
C) | Zener voltage |
254. Each pair of positive and negative ions at the junction is called a/an
A) | Cation |
B) | Anion |
C) | Positron |
D) | Dipole |
255. What is approximate mass of an electron at rest?
A) | 9.1096 x​​ 10-31 kg |
B) | 1.6726 x​​ 10-27 kg |
C) | 1.6762 x​​ 10-31 kg |
D) | 1.7588 x​​ 10-11 kg |
256. A ​_____​ is considered a voltage controlled device
A) | Diode |
B) | Transistor |
C) | Capacitor |
D) | FET |
257. Pure silicon crystal atoms contain how may valence electrons as a result of covalent bonding?
A) | 16 |
B) | 1 |
C) | 8 |
D) | 4 |
258. A unijunction transistor is a three terminal consisting of ​____​ semiconductor layers.
A) | One |
B) | Two |
C) | Four |
D) | Three |
259. Thermal voltage Vt is approximately equal to ​ _____​ at room temperature (20ºC)
A) | 100 mV |
B) | 25 mV |
C) | 100 V |
D) | 25 V |
260. What is the number of protons in the nucleus or the number of electrons in an atom?
B) | Atomic weight |
C) | Atomic mass |
D) | Atomic number |
261. Valence orbit is the other form for
A) | ​​2nd orbit |
B) | ​​4th orbit |
C) | Outer orbit |
D) | ​​3rd orbit |
262. in an n-type semiconductor, holes are called
A) | charge carriers |
B) | majority carriers |
C) | protons |
D) | minority carriers |
263. What is the typical operating current of an LED?
A) | 50 mA |
B) | 10 mA |
C) | 20 mA |
D) | 5 mA |
264. A manufacturer quotes in his specifications that a germanium diode conducts 50 mA at 1 volt. Determine the bulk resistance.
A) | 100 ohms |
B) | 14 ohms |
C) | 60 ohms |
D) | 20 ohms |
265. The time it takes to turn off a forward-biased diode is called the
B) | Recombination |
C) | Forward recovery time |
D) | Turn-off time |
266. Which of the item below does not mean a VARACTOR diode?
A) | VARICAPS |
B) | Voltage variable capacitors |
C) | Variable resistance diode |
D) | VOLTACAPS |
267. A microwave diode in which the carriers that transverse the drift region are generated by minority carrier injection from a forward-biased junction instead of being extracted from the plasma of an avalanche region.
A) | IMPATT |
B) | TRAPAT |
C) | Esaki diode |
D) | BARITT diode |
268. When a transistor is fully saturated,
A) | The transistor alpha is at its maximum value |
B) | The collector current is at its maximum value |
C) | The beta of the transistor is at minimal value |
D) | The emitter current is at its minimum value |
269. A mechanism for carrier motion in semiconductors which occurs when an electric field is applied across a piece of silicon
A) | Diffusivity |
C) | Carrier diffusion |
D) | Carrier drift |
270. A MOSFET is sometimes called ____ FET
A) | Shorted gate |
B) | Metallic gate |
C) | Insulated gate |
D) | Open gate |
271. The preferred form of biasing a JFET amplifier is through the
A) | Gate bias |
B) | Self bias |
C) | Voltage divider bias |
D) | Source bias |
272. What is the dc resistance of the JFET in the ohmic region if the drain to source current at gate shorted is equal to 20 mA and the pinch off voltage is 5 \ volts?
A) | 250​​ Ω |
B) | 100​​ Ω |
C) | 300​​ Ω |
D) | 1​​K Ω |
273. when a factor a junction transistor is 0.98, the factor would be equivalent to ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ value of transistor’s beta.
A) | 49 |
B) | 20 |
C) | 38 |
D) | 60 |
274. What device whose internal capacitance varies with the applied voltage?
A) | Zener diode |
B) | Tunnel diode |
C) | Photodiode |
275. A nuclei with a common number of protons, but with different number of neutrons
A) | Isotope |
B) | Atom |
C) | Fission |
D) | Core |
276. What is the point of intersection between a diode characteristic and a load line?
C) | Operating point |
D) | Q point |
277. The maximum forward current in a junction diode is limited by its
A) | Junction temperature |
C) | Leakage current |
D) | Maximum forward voltage |
278. The gate-to 0 source on voltage if an n-channel enhancement mode MOSFET is
A) | Greater than​​ VDS(on) |
B) | Greater than​​ VGS(th) |
C) | Equal to​​ VGS(off) |
D) | Less than​​ Vth |
279. When an atom has bound electrons, it is described as
A) | Valence electrons disappear due to vaporization |
B) | All charges do recombination |
C) | Merging of electrons and other particles |
D) | Filled or saturated since valence orbit can hold not more than 8 electrons |
280. A silicon crystal is an intrinsic semiconductor
A) | If the crystal is undoped |
B) | If every atom in the crystal is a silicon atom |
C) | If majority of the atoms in crystal is a silicon atom |
D) | If the crystal contains 14 silicon atoms |
281. The creation of free electrons through zener effect is also known as
A) | Thermionic emission |
B) | Avalanche emission |
C) | Low-field emission |
D) | High-field emission |
282. What is the net charge if a certain semiconductor gains one valence electron?
A) | +1 |
B) | +4 |
C) | -4 |
D) | -1 |
283. The peak inverse voltage of a full wave center tapped rectifier circuit is equal to ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​______ of the input signal.
A) | Twice the peak |
B) | Thrice the peak |
C) | One half |
D) | One third |
284. The drift transistor has a high frequency cut off
A) | Due to its low inherent internal capacitance and low electron transmit time through the base |
B) | Due to the large area |
C) | Since high collector voltage can be used |
D) | Due to the resistance of the base area |
285. Which of the following has the least noise level?
A) | Tetrode |
B) | Triode |
C) | BJT |
D) | FET |
286. The merging of a free electron and a hole inside the silicon crystal
B) | Merged electron |
C) | Valence bond |
287. In an amplifier, the emitter junction is
A) | Shorted |
B) | Reverse biased |
C) | Forward biased |
D) | Grounded |
288. What are the three terminals of a FET?
A) | Plate, cathode and grid |
B) | Gate source and battery |
C) | Gate, source and drain |
D) | Input, output and ground |
289. The arrow in semiconductor symbol
A) | Is not a significant symbol |
B) | Always points towards the N region and away from the P region |
C) | Always points toward the PN junction |
D) | Always points towards the P region and away from the N region |
290. K shell means
A) | ​3rd ​orbit |
B) | ​4th ​orbit |
C) | First orbit |
D) | ​2nd ​orbit |
291. Zener diodes can be primarily classified as
A) | Gaseous and hot-carrier |
B) | Forward and reverse biased |
C) | Voltage regulation and voltage reference |
D) | Varactor and rectifying |
292. A silicon crystal is a/an _____ ​ of a semiconductor if every atom in the crystal is a silicon atom.
A) | Intrinsic |
B) | P-type |
C) | Extrinsic |
D) | N-type |
293. At room temperature, a silicon crystal acts approximately like a/an
A) | Conductor |
C) | Insulator |
294. A method of connecting amplifiers in cascade
A) | Stages |
B) | Configuration |
C) | Coupling |
D) | Link |
295. The holding of one extreme amplitude of the input waveform to a certain amount of potential is called
A) | Limiting |
B) | Slicing |
C) | Clamping |
D) | Rectifying |
296. What capacitors are used in transistor amplifiers?
A) | Air |
B) | Paper |
C) | Mica |
D) | Electrolytic |
297. It is also known as a solid state lamp which utilizes the fall of an electron from the conduction level to the valence level to develop an energy release in the form of heat or light.
A) | LCD |
B) | LED |
C) | Photoconductive cell |
D) | Photodiode |
298. Lifetime is the amount of time between the creation and disappearance of a/an
A) | Free electron |
B) | Proton |
C) | Neutron |
D) | Ion |
299. An effect that occurs within the entire bulk of a semiconductor material rather than in a localized region or junction
A) | Dember effect |
B) | Silicon effect |
C) | Destriau effect |
D) | Bulk effect |
300. If the input power of a half wave rectifier has a frequency of 400 Hertz, then the ripple frequency will be equal to ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ ​ .
A) | 400 Hertz |
B) | 100 Hertz |
C) | 200 Hertz |
D) | 800 Hertz |
Click Here for Answers
Next Quiz:
- Circuit Measurement Questions
- Electrical Welding Questions
- Electronic Devices & Circuits Quiz
- Electrical Machine Design Questions
- illumination Multiple Choice Questions
