Reading: Single Phase versus Three Phase Power
Inst Tools > Blog > Electrical Basics > Single Phase versus Three Phase Power
In this article, we will learn the difference between single-phase and three-phase power supply and their comparison.
Last updated: September 28, 2022 4:09 pm
Electrical Basics
6 Min Read
In this post, we will see the difference between single-phase and three-phase power supply.
Single-Phase Power SupplyThree-Phase Power SupplySingle Phase versus Three Phase Power
Most of us are familiar with AC (Alternating current) power supply. It is used in our day-to-day life for getting electricity.
AC supply means current changes, in both the terms of magnitude and phase direction. It means that it is not always positive; and switches between positive and negative output. It is in total contrast with DC (Direct current) power supply system where the phase does not change and the output is always positive.
In AC power supply, there are two types of systems used – single-phase and three-phase.
Earlier, there used to be the third one too – a dual-phase power supply. But, it has become obsolete now and is not used anymore.
Our normal life revolves around these two power supply systems. In this post, we will understand what are they and what is the difference between them.
This system consists only of two wires – line (phase) and neutral. It must be noted that an AC current flows in phase theory (distribution of load).
Basically, let us consider a sinusoidal wave.
Refer to the above image. As shown, the wave peaks in the positive form at 90 deg. and peaks in the negative form at 270 deg.
The voltage supplied between phase and neutral is 230V. It is found that due to a single waveform and positive cycle is not the whole duration (presence of negative cycle in every interval), constant power is not supplied to the load. This shows that a single-phase system will supply less output power.
This system consists of four wires – 3 wires of the line (phase) and neutral.
Refer to the below image. As shown, the wave peaks in the positive form at every angle. Let us understand it more properly. In the first stage, phase 1 leads in a positive form while the other two are in the negative phase (120 deg. apart from each other).
At the second stage, phase 2 leads in a positive form while the other two are in a negative phase.
At the third stage, phase 3 leads in a positive form while the other two are in a negative phase. This is a very good result as compared to single-phase supply; where a leading-edge comes after a long interval.
The voltage supplied between phase and neutral is 230V and the voltage between two phases is 440V. It is found that due to a good amount of positive edges in regular intervals, constant power is supplied to the load. This shows that a three-phase system will supply more output power.
Due to low power output from single-phase supply, it is more used for domestic purposes like residential homes and offices. A normal power socket that you use at home for charging your mobile or turning on your TV is a 230V supply.
Due to the high output from the three-phase supply, it is more used in industrial applications and other heavy-duty processes which draw a large amount of current for driving their loads. It is to be noted that raw power from distribution grids is a three-phase supply; it is distributed to your homes for single-phase use through normal distribution boards.
The design, handling, and maintenance of a single-phase power supply are easier as compared to a three-phase supply.
The torque handling capacity and current carrying capacity are larger in a three-phase supply system than in a single-phase supply system.
The efficiency of a three-phase system is higher than a single-phase system.
Single-phase supply is ideal for small loads like lighting, heating, cooling, fan system, etc., whereas a three-phase supply is ideal for larger loads like heavy motors.
The neutral wire is compulsory in single-phase supply; otherwise, it cannot function. But, the neutral wire is optional in three-phase supplies. It can be found that the delta connection has no neutral wire, but a star connection may or may not have a neutral wire.
A big lagging in single-phase supply is that if the phase wire fails, then the system will break down. But, in a three-phase supply, even if one phase fails, the remaining two can be used to supply power.
  • What is a VFD?
  • UPS Working Principle
  • Stop Switch Spurious Trip
  • Motor Control Timer Circuit
  • Compare Alternator & Generator
Testing and Inspection of Bonding and Grounding Systems
VFD Pros and Cons – Variable Frequency Drives
Cells and Batteries – Types, Applications, Explanation
Basics of Electrical Transformer
Motor Control Timer Circuit – Automatic Motor START and STOP
What is a Motor Disconnector Switch? – Purpose, Principle, Factors
Pros and Cons of Soft Starter
What is Electrical Conduit? Types, Advantages, Disadvantages
What is Power Cable? Types of Power Cables
What is a Submersible Pump? Principle Advantages Disadvantages
Difference between UPS and Stabilizer?
What is a Power Transformer? – Components and Types
Why is Motor Control Required in Control Systems?
Emergency Stop Push button
How to Read and Understand an Electrical Single Line Diagram?
Wave Trap in Power Line carrier Communication
What is a Wave Trap? – Power Line Carrier Communication
What is Switchgear and Electrical Substation?
What is an Electrical Drive
What is an Electrical Drive? Types, Advantages, Disadvantages
Simplified Induction Motor - Cross Section
Siemens Standard Drives Application Handbook (PDF)
Burst Transformers Root Cause Analysis
Root Cause Analysis – Burst Transformers and 11 kV Input Breakers
Gas-Insulated Transmission Line
What is Gas-Insulated Transmission Line? Principle Advantages
Dynamic Characteristics of Power Diode
Power Diode – Characteristics, Construction, Working, Advantages
Flip-Flop PLC Program for Lamps Application
Example of Flip-Flop PLC Program for Lamps Application
electronics-questions-and-answers
Electronics Questions & Answers
Micro PLC
Micro PLC Hardware Configuration
Flow Transmitters Questions and Answers
Flow Transmitters Questions and Answers – Instruments Test
Gases LEL and UEL
What is Lower Explosive Limit & Upper Explosive Limit ?
What is an Electromechanical Relay
Difference Between Solid State Relay and Electromechanical Relay
Stepper Motor Construction
Stepper Motor Basics, Types, Modes, Wiring, Questions
