Reading: Short Notes on Rectifiers & Filters
Inst Tools > Blog > Electronic Devices & Circuits > Short Notes on Rectifiers & Filters
Last updated: September 28, 2016 11:49 am
6 Min Read
The device which operates at above 30V is called an electrical device and the device which operates with less than 30V is called electronic voltage. Even though the electronic devices like transistors are used to amplify the analog signals, they eventually need DC voltage biasing to perform that task. Likewise so many electronic devices operate on only DC which cannot sustain any voltage changes. The DC sources like batteries can be used to power these electronic devices but the batteries will be drained with the time which provides interruption.
In our electricity generation all the generated energy is alternating in nature, so this alternating energy should be converted in to direct energy to provide DC supply to the electronic components. This is an online process where the generated AC is converted into proper regulated DC. It is so important to learn the two devices called rectifiers and filters which are used to convert AC to DC.
Rectifiers
The device which converts alternating (bidirectional) voltage to pulsating (Unidirectional) voltage is called rectifier. As the name specifies it rectifies some portion of the alternating signal and provides a unidirectional signal at the output. This is achieved by the electronic element called semiconductor diode. The semiconductor diode is the element which allows the signal in one direction and blocks the signal in reverse direction i.e. converting bidirectional into unidirectional.
Half Wave Rectifier
However a simple diode can acts as rectifier which also can be called as Half wave rectifier. But the half wave rectifier can convert half of the input signal to pulsating DC and the remaining half will be lost as heat. So the efficiency is less.
Full wave Rectifier
To increase the efficiency two diodes are placed to convert each AC cycle into pulsating DC cycle. I.e. two unidirectional pulsed for one AC cycle will be produced at the output. The full wave rectifiers are divided as Center-taped full wave rectifier and Bridge Full wave rectifier.
Center Taped full wave rectifier
In this the center taped transformer is used to perfectly divide the AC signal in to half cycles and to give as an input to the two diodes which produces the pulsating DC.
Bridge Rectifier
Four rectifier diodes arranged in the form of bridge in which two diodes conducts per one half AC cycle and provides the pulsating DC output with two pulses per cycle. Here the need of the transformer is eliminated.
However the rectifier output is unidirectional pulsating current which has variation in magnitude. This variation in magnitude should be eliminated before giving to any electronic component. So to eliminate this, the devices called filters are introduced.
Filters
The devices which converts the pulsating DC in to pure DC is called filter. As the name specifies it filters the oscillations in the signal and provides a pure DC at the output. The electronic reactive elements like capacitor and inductors are used to do this work.
Inductive Filter (L)
The property of the inductor is that it opposes any sudden change that occurs in a circuit an provides a smoothed output. In the case of AC, there is change in the magnitude of current with time. So the inductor offers some impendence (opposing force) for AC ((XL = jwL) and offers shot circuit for DC. So by connecting inductor in series with the supply blocks AC and allows DC to pass.
Capacitor Filter
The elegant quality of the capacitor is it stores the electrical energy for short time and discharges it. By controlling the charging and discharging rate of the capacitor the pure DC can be obtained from the pulsating DC. In simple the capacitor allows AC and blocks DC, so the capacitor can connect parallel to the power supply so that the AC is filtered out and DC will reach the load.
LC Filter
In the above two filters the reactive components are singly connected, however no element will be perfect in doing the job i.e. inductor in series may pass small quantity of AC and Capacitor in parallel may not block all the AC component. So for better filtering two components are connected as filter which provides less ripple factor at the output compared to the above filter.
 CLC or π filter
In L and LC filter the inductor connected in series to the power supply drops more AC voltage which reduces the efficiency. So to avoid this increase the efficiency a capacitor is connected at the input of the LC filter. The input capacitor charges & discharges and provides a ripple DC at the input of inductor. Then the drop at the inductor is less and provides a ripple less DC which again filtered by capacitor at the output.
Multiple connection the above filter provides better efficiency and less ripple factor at the output.
Difference between Schottky Diode and PN junction Diode
Operation of Zener Diode Voltage Regulator
Summary Of Transistor Bias Circuits
Half Wave Voltage Doubler using Diodes
Transistor as an Amplifier in Common Emitter
Series and Parallel Resistors
Different Types of Diodes
Types of Resistors
Light Emitting Diode Operation
Energy Diagrams of PN Junction & Depletion Region
Classification of Bridge Circuits
Basic Electronics Questions & Answers
How a Multi Color LED Works ?
Full Wave Bridge Rectifier Peak Inverse Voltage
Basic Transistor Amplifier Circuit Principle
Troubleshooting a Biased Transistor
phototransistor symbols
Phototransistor Working Principle
What is a Filter Circuit
What is a Filter Circuit ?
transistor-emitter-bias
Transistor Emitter Bias
kirchhoffs-voltage-law
What is Kirchhoff’s Voltage Law
Capacitor Filter Operation
energy-diagrams-for-insulator-semiconductor-and-conductor
Band Gap for Semiconductor Materials
NO2 Analyzer Questions & Answers
Advantages of HVDC transmission
Series - Wound DC Motor
Series-Wound Motor
Renewable Energy Projects
200 Renewable Energy Projects for Students and Engineers
User Defined Function Blocks in PLC
What are User Defined Function Blocks in PLC?
Group of Induction Motors
How to Operate a Group of Induction Motors using PLC Logic?
Surface Grinding Process using PLC Program
