Reading: Selection Guidelines for Cable Glands
Inst Tools > Blog > Erection & Commissioning > Selection Guidelines for Cable Glands
Last updated: March 15, 2025 5:25 pm
2 Comments
3 Min Read
There are many factors to consider when selecting cable glands for industrial installations. Neglecting to pay due attention to some of these factors may cause unnecessary anxiety at a future point in time when the equipment and cables have been delivered on site, but for example the cable glands have either been forgotten to be ordered or it is discovered that they are the incorrect type or size at the very point when they are needed the most.
Good advice would be to allocate some value added planning and preparation time to the subject of cable gland selection so as to avoid the great inconvenience which is likely to occur at a critical point in time. In the event that a user or contractor is in possession of a cable schedule that requires a cable gland selection and sizing process to be carried out.
Here is a summary of some aspects to carefully consider when selecting cable glands.
  1. Identify the type of cable to be used.
  2. Check the construction, size & material properties of the cable.
  3. When the cable is armoured, verify the following :-
  4. Check the type and material of the cable armour
  5. Check the short circuit fault current rating of the cable armour
  6. Check the actual diameter of the inner bedding.
  7. Check the actual diameter of the lead covering.
  8. Check the actual size of the overall cable diameter.
  9. Check the size and type of armour or braid.
  10. Check any special environmental requirements in relation to corrosion protection.
  11. Check the material of the mating electrical enclosures to eliminate dis-similar metals.
  12. Consider whether any protective plating is required to be applied to the cable gland.
  13. Check the type and size of the cable entry hole in the mating electrical equipment.
  14. Check the ingress protection rating of the electrical equipment or site standard
  15. Check whether a single seal or double seal cable gland is required.
  16. Check whether an entry thread seal is required for IP66 (or IP67/IP68) conditions.
  17. Check whether fixing accessories such as locknuts and serrated washers are required.
  18. Check whether earth tags are required.
  19. Check whether shrouds are required.
For installations in Hazardous Areas, special considerations should be taken into account to ensure compliance with national or international codes of practice.
Check whether a thread conversion adaptor / reducer is required to make the installation.
Check whether any stopper plugs are required to close unused cable entries.
DP Level Measurement Problems
What is an O-Ring?
P&ID Guidelines for Pumps
Installation & Commissioning Tips for HART Devices
Good and Bad Wiring Practices
2 Comments
  • Roquito Gajol Bagotsay says:
    August 1, 2016 at 12:39 am
    I want to know about all cable Electrical and Instrumentation.
  • Undefined says:
    August 7, 2020 at 10:18 pm
    how many types gland in use instrument cables.
Installation Precautions of Thermocouple and RTD
Tips for Reducing the Noise Signals
P&ID Guidelines for Pig Receivers
Tube Fitting Types
Flow Meter Installation Guidelines
Cable Trays Glossary
How to Solve Cable Tray Sagging ?
Direct Mounting of Diaphragm Seals Level Transmitter
What are the Mounting Techniques of Diaphragm Seals?
Pressure Transmitters Installation Factors
Pressure Transmitters Installation Tips
How to Install a Rotameter
Basics of Ground Loops
Triangle A-B-C- with Arc “A-C”
Instrument Tube Fitting Installation – Part 2
What is Instrument Air Manifold
What is Instrument Air Manifold ?
Gas Detectors Location Installation
Gas Detectors Installation Techniques
Material Certificate versus Positive Material Identification (PMI)
Resistance Temperature Detectors Troubleshooting Tips
Ideal Diode Characteristics Curve
Difference between ideal diode & conventional diode
Can a PLC Function Without an HMI or SCADA
Can a PLC Function Without an HMI or SCADA?
Microsoft MS-200 certification
Best Preparation Tool You Can Get Online for Microsoft MS-200
Raspberry Pi Projects
200 Raspberry Pi Projects
Instrumentation Colleges in United States
Colleges to Study Instrumentation Engineering in United States
Semi Conductor or Piezo Resistive Strain Gauge Principle
Electronic Devices & Circuits Quiz – Set 11
