Reading: What is a Segmental Wedge Flow Meter?
Inst Tools > Blog > Flow Measurement > What is a Segmental Wedge Flow Meter?
The segmental wedge flow meter element has a V-shaped restriction cast or welded into a flanged meter body that creates a differential pressure.
Last updated: November 2, 2023 10:45 am
Flow Measurement
2 Comments
2 Min Read
Segmental Wedge Flow MeterWedge Flow Meter
wedge Flow meter
The functional principle of this measuring instrument is based on the Bernoulli principle (continuity and energy balance equations).
Using a wedge, a differential pressure is generated which can be equated with the mass or volume flow rate. The flow range is determined through the H/D ratio.
segmental wedge Flow Meter Working
The restriction is characterized by the h/D ratio, corresponding to the β ratio of an orifice plate, where (h) is the height of the opening below the restriction (the only critical dimension) and (D) is the inside diameter of the pipe.
It can be used for a variety of corrosive, erosive, and highly viscous fluids and slurries. The discharge coefficient (Cd) is a stable for Reynolds numbers of less than 500 – allowing it to be used down to laminar flow regimes.
The upstream and downstream pressure taps are usually in the form of remote diaphragm seals eliminating the need for lead lines.
Wedge Flow Meter
segmental wedge Flow element
Image Courtesy: controlplusinc
The differential pressure transmitter will be installed on the tapping points as shown in above figure.
The wedge creates a differential pressure as like orifice and this differential pressure is measured using the DP transmitter and measures the flow rate.
Theory of segmental wedge Flow Meter
Image Courtesy: Wika
  • Flow switch Principle
  • Coriolis flowmeter Advantages
  • Impeller Flow Sensor Principle
  • Nutating Disc Flow Meters
  • Interferometer Principle
Flow Nozzle Principle, Advantages, Disadvantages, Applications
Annubar Flow Meter – Principle, Advantages, Disadvantages
Orifice Plate Tapping – Orifice Plate Taps
Flow Transmitters Questions and Answers – Instruments Test
Pitot Tube Problems and Troubleshooting Steps – Flow Instrument
What is a Square Root Extractor? – DP Flow Measurement
2 Comments
  • GAMA SONKAR says:
    May 14, 2019 at 10:20 am
    segmental wedge flow element
    please provide full detail like
    where is used what application what line means oxygen , nitrogen, co gas , water etc
  • Chiranjib Dutta says:
    June 12, 2020 at 10:23 pm
    It usually used for high viscous material.. like bitumen, vaccume residue etc… Where if u use orifice that may be choke…
Measure Flow rate using Level Sensors
Gas and Liquid Measurement: Processes and Solutions for the Industrial Sector
Troubleshooting DP type Transmitter Common Problems
Basics of Flow Measurement
Orifice Plate Turndown ratio
Classification of Flow Measurement Techniques
Particle Image Velocimetry (PIV) Principle
Integral Orifice Parts
What is Integral Flow Orifice Assembly?
Flow Meter Reading Unstable
What Factors Affect the Stability of Flow Meter Readings?
What is an Orifice Flange ?
What is an Orifice Flange? – Purpose and Applications
Insertion flow meters
What is an Insertion Flow Meter? – Types, Principle, Advantages
difference between invasive and non-invasive and intrusive and non-intrusive
Vortex Flow Meters
All About Vortex Flow Meters
Venturi Flow Meter
Venturi Flow Meter – Working Principle, Advantages, Animation
Magnetic Flow Meters
DC Machines Excitation Quiz
Fire Extinguishers Mock Test
Emergency Stop Push button
Artificial intelligence in supply chain management
PID parameters
PID in Siemens TIA Portal
Analog Electronics Objective Questions – Set 10
Valve Safety Factor
Valve Safety Factor
Pressure Gauges Common Problems
Pressure Gauges : Common Causes for Failures and Their Effective Solutions
