Reading: Why Restriction Orifice is some distance from Blowdown valve ?
Inst Tools > Blog > Control Valves > Why Restriction Orifice is some distance from Blowdown valve ?
Last updated: September 1, 2019 9:12 am
Control Valves Process
4 Comments
2 Min Read
Very basic does not imply obvious…i really like this statement. Very often the answer is very fundamental and basic to us, somehow it always does not obvious to us.
Restriction Orifice after Blowdown valve
Lets look at the above sketch. It is a typical arrangement for a Blowdown Valve (BDV) with Restriction Orifice (RO) , located downstream of the Blowdown valve. This arrangement typically used to depressurized a system inventory to a safe level within a limited time to minimized catastrophic scenario. Between the Blowdown valve and Restriction orifice, there 600 mm spool piece between them.
What the main purpose of this 600mm spool piece ?
Is this spool for straightening and smooth flow ?
Is this spool to avoid secondary choke ?
Guess what ?
Reasoning…Major pressure drop will take place at Restriction Orifice, downstream of Blowdown valve during blowdown. Joule-Thompson (JT) effect results fluid temperature downstream of Restriction Orifice drops below subzero (Less than zero degree Celsius). Latent heat in the piping will transfer to cold fluid and slowly approaching this subzero temperature. The “coldness” will travel back to upstream of Restriction orifice and probably reaches Blowdown valve.
It potentially cause the upstream Blowdown valve body temperature drops below subzero as well. Moisture from atmosphere will freeze at the Blowdown valve body and potentially cause the stem stuck at position. Operator may not possible to close the Blowdown valve after blowdown activities and may potentially lead to back flow. Those “general good engineering practice is to locate Restriction orifice, 600mm downstream of Blowdown valve.
Difference between RTJ and T&G Flange Facings
Control Valve Selection Guide
5 Port 2 Position Valve Working Principle
Applications of Needle Valves
Summary of Valve Types Characteristics
4 Comments
  • Ogbe says:
    August 29, 2018 at 12:54 pm
    The failure position of the BDV in the diagram should be FO not FC. A FC valve will prevent blowdown on instrument air failure if it happens when there is a demand for blowdown. This will lead to a catastrophic condition developing.
  • Peter Obasi says:
    September 2, 2018 at 10:33 am
    why is the BDV not a fail to open(FO)type?
  • Moazzam says:
    November 20, 2022 at 4:30 pm
    BDV should be Fail to Open not Fail to Close
  • Ahmed messallam says:
    November 25, 2022 at 1:06 pm
    very important subject.
Bellows Seal Valve Working Principle
Heat Exchanger Root Cause Analysis (RCA)
What is a Disc Valve ?
The Replacement Procedure for Control Valve Stem Packing
Backwashing
Control Valve Testing for Noise Measurement
Valve Actuator Bench Set
Control Valve Positioners
Solenoid Valve Troubleshooting
Solenoid Valve Troubleshooting Tips
Positive Displacement Pumps
What are Positive Displacement Pumps and their Types?
Direct & reverse actions control valve
Direct Acting Control Valves & Reverse Acting Control Valves
Valves Pressure Loss - Questions and Answers
Valves Pressure Loss – Questions and Answers
Direct operated (direct acting) solenoid valves
Solenoid Valves Types & Functions
Basics of Butterfly Valves
Chocked flow
Control Valve Cavitation and Flashing
control valve parts
Common Terms Used in Control Valves
Free Download PLC Book
#10 PLC Best Practices – Assign Register Blocks by Function
Brushed DC Motor Working Animation
Preventa XPS MC, XPS MP - Safety controllers
High-end Programmable Logic Controller – Schneider PLC
Panel Ground Noise
Floating Vs. Grounded Voltage
Profibus network
How Profibus Communication Works
Working of Stepper Motor
Types of Stepper Motors
Mass Flow Calculations of flow measurement
valve trim
