Reading: Rectifiers, Forward Bias and Reverse Bias
Inst Tools > Blog > Electrical Theory > Rectifiers, Forward Bias and Reverse Bias
Last updated: July 22, 2018 10:16 pm
Electrical Theory
3 Min Read
Rectifiers
Most electrical power generating stations produce alternating current. The major reason for generating AC is that it can be transferred over long distances with fewer losses than DC; however, many of the devices which are used today operate only, or more efficiently, with DC. For example, transistors, electron tubes, and certain electronic control devices require DC for operation. If we are to operate these devices from ordinary AC outlet receptacles, they must be equipped with rectifier units to convert AC to DC. In order to accomplish this conversion, we use diodes in rectifier circuits.
The purpose of a rectifier circuit is to convert AC power to DC. The most common type of solid state diode rectifier is made of silicon. The diode acts as a gate, which allows current to pass in one direction and blocks current in the other direction. The polarity of the applied voltage determines if the diode will conduct. The two polarities are known as forward bias and reverse bias.
Forward Bias
A diode is forward biased when the positive terminal of a voltage source is connected to its anode, and the negative terminal is connected to the cathode (Figure 4A). The power source’s positive side will tend to repel the holes in the p-type material toward the p-n junction by the negative side. A hole is a vacancy in the electron structure of a material. Holes behave as positive charges. As the holes and the electrons reach the p-n junction, some of them break through it (Figure 4B). Holes combine with electrons in the n-type material, and electrons combine with holes in the p-type material.
Forward Bias
Figure 4 A – Forward-Biased Diode
Forward Bias Diode
Figure 4B (Left) & 4C (Right)
When a hole combines with an electron, or an electron combines with a hole near the p-n junction, an electron from an electron-pair bond in the p-type material breaks its bond and enters the positive side of the source. Simultaneously, an electron from the negative side of the source enters the n-type material (Figure 4C). This produces a flow of electrons in the circuit.
Reverse Bias
Reverse biasing occurs when the diode’s anode is connected to the negative side of the source, and the cathode is connected to the positive side of the source (Figure 5A). Holes within the p-type material are attracted toward the negative terminal, and the electrons in the n-type material are attracted to the positive terminal (Figure 5B). This prevents the combination of electrons and holes near the p-n junction, and therefore causes a high resistance to current flow. This resistance prevents current flow through the circuit.
Reverse-Biased Diode
Figure 5 Reverse-Biased Diode
Types of Capacitors
Parallel Short Circuit Faults
Ground Detector Principle
Transformer Turns Ratio
Losses in AC Generator
Reading Electrical Schematics
What is Electricity ?
Transformer Operation Under No-Load
Electrical System Components and Protection Devices
Battery Terminology
DC Generator Theory
Shunt-Wound DC Generators
AC Generation
Low Voltage Air Circuit Breaker Principle
Unbalanced 3 Phase Loads
Calculate Power in Series RCL Circuit
Leading Power Factor
Power Factor
Schematic Diagram
Schematic Diagram
Half-Wave Rectifier Circuit
Left-Hand Rule for Generators
Starting of DC Motors
3-Wire, Three-Phase Delta Wiring System
Inductor Principle
Inductor
Flow Transmitter Readings mismatch with DCS
LIC and FIC Controllers
What LIC and FIC Controllers will do?
Run 4 Motors Sequentially from Same Push button PLC Program
Difference between LVDT and RVDT
Difference between LVDT and RVDT?
Filtering and Dynamic Compensation Objective Questions
Single Beam and Double Beam Instruments
Control Valves Chemical attack Problems
Difference between Force and Power
