Reading: Questions on Chemical Reactor Vessel P & ID
Inst Tools > Blog > Common > Questions on Chemical Reactor Vessel P & ID
Last updated: January 27, 2020 9:42 am
Common
4 Comments
2 Min Read
Examine this portion of a P&ID. This particular diagram shows some of the piping and instrumentation associated with a chemical reactor vessel:
Chemical Reactor Vessel P and ID
Question 1:
Which direction does process fluid flow through this reactor vessel? How can we tell from the diagram?
Question 2:
Identify the functions of all instrument “bubbles” shown in this diagram, as well as the meanings of their identifying tag letters (e.g. “PDT”).
Question 3:
How are piping flanges shown in a PFD or P&ID?
Question 4:
What is the meaning of the trapezoidal symbols with two sizes (e.g. 10” × 24”)?
Question 5:
Two places on this diagram show the placement of a blind, used to positively seal off a pipe at a flange for maintenance purposes. Locate these two blind installations in the diagram.
Note: If a blind or another other safety device needs to be left in its safe state for any specific reason, the person engaging that safety device must lock it in place and tag it with an informative tag stating the reason and duration of the lock-out. This is commonly referred to as a lock-out, tag-out procedure.
Question 6:
Some of the indicators shown in this P&ID serve double-duty as process alarms. Identify which of the indicators also have alarm functions, and which of those are high alarms, low alarms, or both.
Question 7:
Based on what you see in this P&ID, what do you think the purpose of PDT-145 is?
Question 8:
Based on what you see in this P&ID, what do you think is the purpose of having three temperature transmitters at the top of the vessel?
Share Your Answers with us through comments.
Credits: Tony R. Kuphaldt
  • Instrument Hook Up Diagram
  • Instrument Loop Diagram
  • What is Block Diagram
  • Control Loop Wiring
  • Process Variables in P&ID
3 Valve Manifold Operation
Types of Tachometers – Mechanical and Electrical Tachometers
Measurement of POL, pH, and BRIX in the Sugar Industry
Difference between Standards, Codes, Specifications, Regulations
Self-balancing Pneumatic Instrument Principles
What are the Advantages & Disadvantages of CNC Milling?
4 Comments
  • jitendra meena says:
    January 22, 2020 at 8:22 pm
    Ans.1
    process fluid flows from top of the vessels to bottom of the vessels or from unit 3-22 to unit 5-01.
    process fluid flow is indicates by arrow sign at the top and bottom of the vessels.
    Ans 2.
    TI : TEMPERATURE INDICATOR
    TE: TEMPERATURE ELEMNT
    PDT: DIFFERENTIAL PRESSURE TRANSMITTER
  • ELUDU DAVID says:
    January 24, 2020 at 9:02 am
    1. from the top of the reactor
    2. PDT means Differential pressure transmitter
    3. with a vertical line
    4. Enlarger
    5.
    6. TIR-202 High alarm and PDI-145 high and low alarms
    7. PDI-145 is to check the differential between the inlet and outlet pressure
    8. To effectively monitor the temperatures on the reactor. Paraventures one of the transmitters fails, the other two serves as reference.
  • Sonny says:
    January 24, 2020 at 10:12 am
    Answer 8: as it is a critical process control, so requires 2oo3 voting logic connected to ESD. You need minimum 2 transmitters to detect the process temperature to make a trip of the respectie logic/plant section
  • Ahmed seif says:
    February 2, 2021 at 3:48 am
    Ans 1
    Process lines heavier than instrument lines
    Input from top of vessel from unit 3-22
    Arrows direction also appear process flow direction
    Ans 2
    TI temperture indicator
    PI pressure indicator
    TE Temperature element
    TT Temperature transmitter
    TIR Temperature indicator recorder
    PDT pressure differential transmitter
    PDI pressure differential indicator
    TY Temperature high select
    Ans 3
    With verticale line
    ANSI/ISA symbol
    Ans 4
    Expander which enlarge the pipe from 10 inch to 24 inch
    Ans 5
    At note 2 hahhaha
    Ans 6
    PDIHL
    TIRH
    Ans7
    PDT – 145 measue differential pressure between input and output of vessel lines
    If Dp greater than certain value it will give alarm for clogged in vessel
    If DP less than certain value mean that vessel not work efficiently
    Ans 8
    Firstly send three reading to DCS
    Insure reading because they are measure same point
    Make voting in case of one transmiter failure thats will make system not stopped in case of one transmitter failure
    Also make interlock for system in case of temperture of greater sensor value more than certain value
    Also indicate Temperature on DCS
    Also used for SIS system safty instrument system
Look Listen Feel of Instruments – Instrumentation Engineer Maintenance
Instrumentation Loop Diagrams
Capacity Control of Absorption Chillers
Procedure for Crimping the Connector
Difference Between Resistive Touch and Capacitive Touch
Auto Cane Feed Control System using DCS – Sugar Factory
Difference between LVDT and RVDT?
How Does Starlink Work?
Heavy Equipment Transport
4 Tips For Shipping Large Construction Equipment
Automation in Agriculture
Automation in Farming & Agriculture
Learning Programming
How to Begin Learning Programming and Succeed?
Cable Gland Parts
What is a Cable Gland ?
AI Technology in Video Surveillance
Next-Generation Security Surveillance Systems – AI Technology
PCB Making Machine
Beyond FR-4: Exploring Novel Materials for PCB Fabrication
Confined Space
AC Generator Nameplate Ratings
Measurement Unit Conversions
Introduction to Fieldbus Function Blocks
Field Instrument package
liquid flow control system
Practical Process Control System Questions & Answers – 7
Fluidic Systems Objective Questions
Industrial Networking Interview Questions
Industrial Networking and Wireless Interview Questions
High and Low Ports on Pneumatic DP Transmitter
Identify High and Low Ports on Pneumatic DP Transmitter
