Reading: Process Control Loop Testing
Inst Tools > Blog > Control Systems > Process Control Loop Testing
Last updated: October 25, 2019 9:37 am
Control Systems Practical Questions Process
2 Min Read
A very useful technique for testing process control loop response is to subject it to a “step-change” in controller output. In other words, the process is perturbed (the highly technical term for this is “bumped”) and the results recorded to learn more about its characteristics.
What practical concerns might surround “bumping” a process such as this? Remember, the process variable (PV) is a real physical measurement such as pressure, level, flow, temperature, pH, or any number of quantities. What precautions should you take prior to perturbing a process to check its response?
Answer :
Some processes may not take well to “bumps,” especially large bumps. Imagine “bumping” the coolant flow to a nuclear reactor or the fuel flow to a large steam boiler: the results could be catastrophic! Not only is it a potential problem to exceed an operating limit (PV too high or too low) in a process, but it may be dangerous to exceed a certain rate of change over time.
Short of catastrophe, unacceptable variations in product quality may result from perturbations of the process. Again, these may be functions of absolute limit (PV too high or too low), and/or rates of change over time.
Remember, the purpose of regulatory control systems is to maintain the PV at or near setpoint. Any time the control system is disabled and the process purposely “bumped,” this purpose is defeated, if only momentarily. It is essential that operations personnel be consulted prior to manually perturbing a process, so that no safety or operating limit is exceeded in the tuning process.
Share Your Comments
Articles You May Like :
Setpoints and Alarms
Normally-open Switch Contacts
4-20mA Current Failure Alarm
What is Circular Chart Recorder ?
PLC Data Compare Instructions
Calculate the Thermocouple Output millivolts
Simple Pressure Repeater
Difference Between Single-stage and Multi-stage Compressor
Define Normal Status of a Process Switch ?
Filters in Compressors
Heat Exchanger Differential Pressure Transmitter
How-to do Security of SCADA Systems?
Commissioning Checklists for Industrial Automation Systems
Speed Control of Ship Electrical Motor Propulsion
Design View of Supplying Process Control and Safety Systems
Instrumentation and Electrical Teams Interactions (Detail Design Engineering)
Question on Analytical Controller
What is Process Automation? – Simple Automation Example
Industrial Automation Mobile Apps
Direct digital control principle
Direct Digital Control (DDC) Systems
Ladder Diagram circuit
PLC Practice Questions
PV Tracking in PID Controllers
What is PV Tracking ?
Safety Control System
What is Safety Control System ?
Boiler Intelligent Control Cabinet
IoT based Smart Boiler Control System with Cloud PLC and SCADA
Purpose of Stop in a Pressure Measuring Instrument
Marshalling Panel
What is Marshalling Cabinet?
Fire Extinguishers Mock Test
Why CT Secondary Should Never Be Kept Open?
ISO 5167 Orifice Plate Types
Readers Questions on Flow Transmitter
Count the Number of Bottles
Count the Number of Bottles in Packaging Carton PLC Logic
DP Transmitter Problem
Digital Electronics Objective Questions – Set 9
PLC Totalizer
PLC Program for Flow Totalizer
Valves Pressure Loss - Questions and Answers
Valves Pressure Loss – Questions and Answers
