Reading: What is a Process Alarm? Types of Alarms
Inst Tools > Blog > Common > What is a Process Alarm? Types of Alarms
A process alarm is used to alert the user of any critical or non-critical condition in an industrial automation & control system.
Last updated: March 10, 2024 3:37 pm
Common
6 Min Read
An alarm is a condition that is used to alert or warn the user of any critical or non-critical condition that can be important or dangerous for further operation. In industrial automation, it is virtually impossible to design any system without alarm configuration.
Process AlarmTypes of AlarmsNuisance alarmFrequent alarmNormal alarmSuppression alarmImportant points to consider in a process alarm
Various types of alarms can be configured in a process system of automation. It is called a process alarm. In this post, we will see the concept of a process alarm and understand how it works.
Process Alarm
A process alarm, as the name implies, caters to various alarms that can occur in a process of industrial automation. Automation is a very critical application and if any abnormal condition is ignored, then it can hamper the whole process or worst case, the whole plant.
So, it is important to understand the alarms that have occurred and treat them accordingly. Usually, a process alarm comes in the way of a bright message. In conjunction with that, a hooter is turned on. This alarms the user of any abnormal condition that has occurred. Now, the user can either acknowledge the alarm or rectify the alarm.
If the alarm has been acknowledged, then it means the user has seen it and is now going to check and correct it. If the user has rectified the alarm, then it means the user has corrected it and will now acknowledge the alarm.
Types of Alarms
The popular types of process alarms are mentioned below.
  • Nuisance alarm,
  • Frequent alarm,
  • Normal alarm,
  • Suppression alarm
Nuisance alarm
Nuisance means disturbance. In alarm conditions, a nuisance alarm occurs frequently in a very short period of time. It is also known as chattering.
For example, consider a differential pressure switch mounted before the filter. When the airflow starts initially, the fluctuations are very high. Due to this, the alarm will come and go frequently in a very short time.
After that time, the airflow will become normal and the alarms will stop coming. So, these types of alarms need to be handled carefully. Because the hooter will trigger repeatedly and can annoy the user. So many times, a programmer gives a window time during which the alarm will not occur at all, irrespective of the air changes.
Frequent alarm
This alarm will come after some period of time, but will come for sure. It will not chatter and harass the user but will come in a fixed or average set of time.
This alarm is of great importance, as it tells the user that the abnormal condition is happening frequently and needs to be addressed. It will prepare the operator for any next alarm coming.
Normal alarm
This alarm will not come frequently. It will occur properly based on an abnormal condition that can happen.
For example, a tank level when going low-low will trigger an alarm and then, it will take time to fill the tank. After some time, the tank will be filled till a low level and a low-level alarm will occur.
Suppression alarm
Many times, equipment or a sensor fails. In that case, the alarm will come constantly and give wrong ideas to the user. In that case, that alarm will be suppressed.
It means the logic will identify such conditions and suppress the alarm until the condition becomes healthy again. At that time, the alarm will not occur at all.
A process alarm is configured in the program as two types –
  1. Analog
  2. Digital.
Digital alarm gives a single value option (0 or 1), whereas analog alarm gives multi value option. It will be like HH, H, L, and LL. This gives the flexibility to design an alarm condition accordingly.
Every alarm must not be made analog. Too many and unwanted alarms can confuse the user and instead create a mistake. This is dangerous for plant operation.
Generate an alarm only if required in the logic. This means, that if a natural process is happening which is correct, and an alarm is written for that, then it is wrong.
Create groups of alarms or prioritize them according to criticality. This helps the user to deal with the alarm accordingly.
  • DCS Alarm Summary
  • PLC Alarm Acknowledge
  • Categorization of Alarms
  • What is Alarm Prioritization?
Hysteresis
Pneumatic Sensing Elements
7 Investments for Single Mothers
What is Circular Chart Recorder?
Conveyor : Belt, Screw, Pneumatic, Hydraulic, Roller, Chain, Bucket, Vibratory
What is a Thin Film Deposition System? How do they work?
Heat Transfer Loops in HVAC System
Career Scope in Civil Engineering
Pharmaceutical Industry: The Role of Precision Tools
What are Oil Burners? Types, Advantages, Applications
HVAC Questions & Answers
Types of Air Conditioning Systems
What is Chemical Vapor Deposition? – The Ultimate Guide
Battery in Vehicle
Why is a Battery used in a Vehicle?
Batch Pan Automation in the sugar industry
Batch Pan Automation in the Sugar Industry
NPT Connections
Difference Between NPT, BSPP and BSPT Seals
HVAC Refrigeration Cycle
Saybolt Viscometer
Saybolt Viscometer
Automation in Agriculture
Automation in Farming & Agriculture
Diaphragm Pump
What is a Diaphragm Pump?
MEASURING AN NPT CONNECTION
NPT Connection Measurement Size
Control Methods in Servo Motor Drives
Various Control Methods in Servo Motor Drives
Ion Transducers Questions & Answers
Transistor as an Amplifier in Common Emitter
PLC Questions & Answers
Programmable Logic Controller Questions and Answers
Pressure Manometer
Types of Manometers
Hazard Identification and Risk Assessment
Network Theorems Objective Questions and Answers
CNC Machining Glass Industry
5 Ways CNC Machining is Benefiting the Glass Industry
