Determine what will happen at the following steps in the sequence (when prompted for a response) in this pressure transmitter calibration setup:
Pressure Transmitter Calibration Setup
The sequence of steps as follows:
Step 1:
Open valves 1 and 2
Step 2:
Close valves 3 and 4
Step 3:
Operate hand pump until manometer registers maximum pressure
Step 4:
Quickly open and close valve 4 – does the manometer indication drop greatly, slightly, or not at all?
Step 5:
Close valve 2
Step 6:
Step 7:
Close valve 1
Step 8:
Quickly open and close valve 3 – does the manometer indication drop greatly, slightly, or not at all?
Answer:
Step 4: Manometer indication drops slightly
Step 6: Manometer indication does not drop at all
Step 8: Manometer indication drops greatly
- Calibration of Pressure Transmitter
- Loop Powered Pressure Transmitter
- Water Filter Discharge Pressure Gauge
- Differential Pressure Transmitter Questions
- PLC Calculation for Pressure Transmitter
- Installation of Pressure Transmitter
Its a very nice exercise, thanks.
