Reading: Pressure Gauges with Bourdon Tube Principle
Inst Tools > Blog > Pressure Measurement > Pressure Gauges with Bourdon Tube Principle
Last updated: September 15, 2017 1:37 pm
2 Min Read
Pressure gauges with bourdon tube
Bourdon tubes are circular-shaped tubes with an oval cross-section. The pressure of the media acts on the inside of this tube which results in the oval cross section becomes almost round. Because of the curvature of the tube ring tension occurs which bends the bourdon tube. The end of the tube, which is not fixed, moves, this movement being a measurement for the pressure. This movement is indicated by a pointer.
The bourdon tubes bent at an angle of approx. 250° are used for pressures up to approx. 60 bar. Used for higher pressures are bourdon tubes with a number of superimposed coils of the same diameter (i.e. helical coils) or helical-shaped coils (i.e. helical springs) at one level. Bourdon tubes can only be protected against overload to a limited extent.
For particularly difficult measuring operations the pressure gauge can be provided upstream with a chemical seal as separation or protection system. The pressure ranges are between 0 ~ 0.6 and 0 ~ 4000 bar with a reading accuracy (or class) from 0.1 to 4.0 %.
The pressure is shown in standard measuring ranges over 270 angle degrees on the dial. Liquid-filled pressure gauges offer optimal protection against destruction by high dynamic pressure loads or vibrations as a result of their cushioning. Switching operations can be carried out when combined with alarm contacts and electrical output signals (for example 4 ~ 20 mA) can be used for industrial process automation in combination with transmitters.
Also See : Bourdon Tube Animation
What are Impulse Lines? – Impulse Line Problems & Solutions
Pressure Gauge Syphons Principle
Pressure Gauge Water Traps and Pigtail Siphons
Basics of Pressure
Uncertainty Calculations of Pressure Calibration
Pressure Gauge Maintenance and Troubleshooting
  • Harpreet Singh says:
    April 3, 2019 at 11:21 am
    How C Type Bourdon tube manometer for monitoring of SF6 gas pressure in GIS or RMU tank compensates the temperature while showing the pressure reading. How to verify please. Could you suggest on this.
    Thanks
    Harpreet Singh
Information on the Pressure Gauge Dial
Difference Between Absolute and Gauge Pressure
Advantages of Pneumatic Systems in the Automotive Industry
Pressure Transmitter Troubleshooting Tips
Differential Pressure Switch Calibration Procedure
What are Pressure Sensing Lines? – Causes of Errors in Measurement
Impulse Line Pressure Testing Procedure
Vacuum Gauges Working Principle
Types of Pressure
Basics of Pressure Measurement
Instrumentation Impulse Lines
All About Instrumentation Impulse Lines
pressure-gauge-animation
Bourdon Tube Pressure Gauge Working Principle Animation
Pressure and Temperature Gauges
Pressure Gauge Datasheet Preparation
How to Prepare Pressure Gauge Datasheet ?
Hammer Effect in Gauges
What is Hammer Effect in Gauges ?
Pressure Transmitter Working Principle
Gage and Absolute Pressure Transmitters Principle
Differential Pressure Switch Principle
P&ID arrangement for Control Valves
P&ID Guidelines for Control Valves
Batch Mixing with PLC Ladder Logic Program
Memory Devices Objective Questions – Part 3
Motor Library in Studio 5000 PLC
Create User-Defined Data Types and Function Blocks in Studio 5000
Overview of Tank Gauging Technologies
Electrical Engineering Documents
Electrical Engineering Documents – Engineers Questions
Electricity Generated From Wind Energy
How is Electricity Generated From Wind Energy?
Two out of Three Logic Analogy
