Reading: Practical Process Control System Questions & Answers – 9
Inst Tools > Blog > Practical Questions > Practical Process Control System Questions & Answers – 9
Last updated: July 27, 2018 10:24 am
Practical Questions
3 Min Read
In this process, maple syrup is heated as it passes through a steam heat exchanger, then enters an evaporator where the water boils off. The purpose of this is to raise the sugar concentration of the syrup, making it suitable for use as a food topping. A level control system (LT, LIR, LIC, and LV) maintains constant syrup level inside the evaporator, while an analytical control system (AT, AIR, AIC, and AV) monitors the sugar concentration of the syrup and adjusts steam flow to the heat exchanger accordingly.
Examine the live variable values shown in the above diagram, and then determine where any problems may exist in this syrup concentrating system.
Extra Question :
A valuable principle to apply in a diagnostic scenario such as this is correspondence: identifying which variables correspond at different points within the system, and which do not. Apply this comparative test to the variables scenario shown in the diagram, and use the results to defend your answer of where the problem is located and what type of problem it is.
Answer :
The one glaring discrepancy we see here is between the laboratory’s measurement of syrup concentration and what the AIC and AIR indicate. Given that both the AIC and AIR agree with each other on PV value, we may conclude that the signal to both of these instruments corresponds to a 34% measurement. The problem is either the transmitter (AT) mis-measuring the syrup concentration, or else it is sensing the concentration okay but outputting the wrong 4-20 mA signal nonetheless, or else the laboratory made a measurement error of their own and incorrectly reported a syrup concentration that is too high.
We also see some minor discrepancies between controller output indications and actual valve stem positions, but these are small enough to ignore. Likewise, the discrepancy between the level gauge (LG) indication and the level controller/recorder indications is small enough that it does not pose a serious problem.
Share Your Answers via Comments
More Questions & Answers :
Practical Process Control System Questions & Answers – 1
Practical Process Control System Questions & Answers – 2
Practical Process Control System Questions & Answers – 3
Practical Process Control System Questions & Answers – 4
Practical Process Control System Questions & Answers – 6
Practical Process Control System Questions & Answers – 7
Practical Process Control System Questions & Answers – 10
Flapper Nozzle Questions
Draw Limit Switch Symbol ?
Identify the Purpose of Flow Ratio Controller
Identify the Pressure Gauge Error
Practical Level Sensors Questions and Answers
DP Transmitter Problem
Differential Pressure Transmitter with 5 Way Manifold Valve
Stripper Overhead Temperature Control System
Programmable Logic Controller (PLC) Questions and Answers – 3
Analytical Process Control Question
Pneumatic Moment-balance Differential Pressure Transmitter
Identify all Spool Valve Positions
Allen-Bradley MicroLogix controller
Programmable Logic Controller (PLC) Questions and Answers – 16
float-type level switch control a pump
Smart DP transmitter Formula
DP Transmitter Error Calculations
Alternative Vessel Level Indication
What is the Simple Alternative Vessel Level Indication?
Problem on Tachogenerator
Calculate DPT Calibrated Range
Calculate the Transmitter Values
Solenoid-controlled Valve Problem
Solenoid Valves Questions
Solenoid Valves Questions & Answers – 3
Advantages and Disadvantages of Slip Ring Induction Motor
Swiss Screw Machining
Things You Should Know About Swiss Screw Machining
power-electronics-interview-questions
Power Electronics Interview Questions Part-1
Common Mistakes in Dead Weight Tester
Common Mistakes to Avoid When Using Dead Weight Tester
Electrical and Instrument Engineers Job Profile
Instrumentation and Electrical Teams Interactions (Detail Design Engineering)
Process Plant Risk and Safety Management
Safety Roles & Responsibilities of Process Engineering (Detail Design)
Global Data Blocks in PLC
What is a Data Block? Global Data Blocks in PLC
Standard Operating Procedure
