Reading: Analytical Control System of Heat Exchanger Questions
Inst Tools > Blog > Practical Questions > Analytical Control System of Heat Exchanger Questions
Describe in detail the effect this heat exchanger problem will have on the performance of the analytical control system.
Last updated: March 10, 2021 11:45 am
Practical Questions
3 Min Read
In this process, maple syrup is heated as it passes through a steam heat exchanger, then enters an evaporator where the water boils off.
The purpose of this is to raise the sugar concentration of the syrup, making it suitable for use as a food topping.
A level control system (LT, LIC, and LV) maintains constant syrup level inside the evaporator, while an analytical control system (AT, AIR, AC, and AV) monitors the sugar concentration of the syrup and adjusts steam flow to the heat exchanger accordingly.
Suppose the steam tubes inside the heat exchanger become coated with residue from the raw maple syrup, making it more difficult for heat to transfer from the steam to the syrup. This makes the heat exchanger less efficient, which will undoubtedly affect the process.
More Questions :
  1. Suppose the operations personnel of this maple syrup processing facility wished to have an automatic method for detecting heat exchanger fouling. What variable(s) could be measured in this process to indicate a fouled heat exchanger?
  2. What economic effect will this fouling have on the process? In other words, does the process become more or less profitable as a result of the heat exchanger fouling?
Answer:
The analytical control system should still be able to maintain sugar concentration at setpoint, unless the heat exchanger fouling is so extreme that even a wide-open steam valve does not heat the incoming syrup enough to sufficiently concentrate it.
Follow-up question: suppose the heat exchanger fouling really is this bad, but we cannot fix the heat exchanger with the tools we have available. What would you recommend the operator do to make this system produce on-spec syrup?
Share Your Answers via Comments
  • Questions on Piping and Instrumentation Diagrams
  • Inspecting the Trends of PV and SP
  • Analytical Measurement Multiple Choice Questions
  • Analytical Standards
Credits: Tony R. Kuphaldt
Problem on Solar Hot Air Collector and Variable Speed Fan
Programmable Logic Controller (PLC) Questions and Answers – 4
How much Pressure is applied to Inclined Water Manometer?
Calculate the Voltage across Voltmeters of Thermocouple
Type E thermocouple Calculations
  • saleem ahmad says:
    March 11, 2021 at 12:56 pm
    By reducing flow rate of Maple syrup, required heat exchange can be achieved alternatively by reprocessing the concentrated syrup quality can be maintained. In either way the capacity of the plant will be reduced which will reduce the plant profatibility.
Determine the functions of Pressure Switches ?
Identify Level Control Loop Tuning Problems
How Manometer Measures Differential Pressure for Different Fluids?
Determine Resistance value of Resistors
Draw the Symbols for Liquid Level Measuring Instruments
Questions on DP Transmitter Wet Leg Compensating Impulse Line
Practical Level Sensors Questions and Answers
Identify Faults in PID Control Loop
Pneumatic Relay
Pneumatic Relay Questions
Allen-Bradley MicroLogix controller
Programmable Logic Controller (PLC) Questions and Answers – 16
Alternative Vessel Level Indication
What is the Simple Alternative Vessel Level Indication?
reactor vessel
Loop Diagram
PT Loop Diagram Faults
Pitot tube
Pitot Tube Flowmeter Calculations
Liquid Level Measurement using Pressure Transmitter
Liquid Level Measurement using Pressure Transmitter Questions
Programmable Logic Controller (PLC) Questions and Answers – 7
harmonics-effect-on-induction-motor
Harmonics effect on Induction Motor
Inter Discipline Check (IDC)
What is Inter Discipline Check (IDC)?
Control System
The need for automatic controls
What is an ELV System - Extra Low Voltage
What is an ELV System? – Extra Low Voltage
Differential Pressure Transmitter Question
Differential Pressure Transmitter Questions
Hydraulic Motor Forward and Reverse Control with Simulation
Full Bore or Reduced Bore Valves
When to choose Full Bore Valve or Reduced Bore Valve ?
Micro 870 Rockwell PLC
Rockwell Automation Allen Bradley PLC for Smaller and Medium Projects
