Reading: Troubleshoot Allen Bradley PLC Logic
Inst Tools > Blog > PLC Tutorials > Troubleshoot Allen Bradley PLC Logic
Last updated: March 4, 2021 3:51 pm
PLC Tutorials Practical Questions
3 Min Read
A engineer needs to write a program for an Allen-Bradley CompactLogix PLC to control a pressure relieving solenoid valve in a gas processing system.
Allen Bradley PLC LogicAnswer :
A pair of high-pressure control switches signals the PLC when to open the solenoid valve: one telling the PLC to open the valve after a 3-second time delay and the other (called the “high-high” switch, with a higher trip setting) telling the PLC to open the valve immediately.
A pushbutton switch serves as a manual override to open the solenoid valve immediately when pressed.
In all cases, the solenoid vent valve will remain open (energized) until pressure falls below the setting of a low-pressure gas switch.
The operating statuses of these switches are listed here:
  • Override pushbutton (normally-open): open when unpressed, closed when pressed
  • Low gas pressure (normally-closed): closed when pressure is less than 10 PSI, open when pressure exceeds 10 PSI
  • High gas pressure (normally-closed): closed when pressure is less than 30 PSI, open when pressure exceeds 30 PSI
  • High-high gas pressure (normally-open): open when pressure is less than 40 PSI, closed when pressure exceeds 40 PSI
The engineer’s first attempt is shown here, but it contains a serious error. Identify and correct this error:
Answer :
The High pressure contact instruction should be drawn as normally-closed rather than normally-open as shown in the engineer’s first draft of the PLC program.
This particular switch signals a high-pressure condition by opening its contacts, since the real-world switch is normally-closed (NC).
We want the 3-second timer to begin timing when this switch senses a high pressure, and so we need the contact instruction to color when the real-world high-pressure switch trips (opens).
A PLC contact instruction that colors when it senses a “0” bit condition is a normally-closed (NC) instruction.
Share Your Answers
How to Check Address Overlapping in Tia Portal?
Down Counter PLC Program
InTouch SCADA Login Password Security
Practical Process Control System Questions & Answers – 12
Structured Text PLC Code for Sequential Process Data Storage
Open Platform Communication (OPC)
PLC FBD Program for Bottle’s Capping with Rotating Mechanism
PLC Programmer Salary and Future Career Scope
Thermocouple Measurement and Reference Junction Temperatures
Car Parking System using PLC Programming
Problem on Weigh feeder
PLC Mixing Process with Adjustable Timer and Valve Control
Measure the Temperature of the RTD
FIFO and LIFO Sequences in PLC
What are FIFO and LIFO Sequences in PLC?
VFD Commissioning and Testing Procedure
Group of Induction Motors
How to Operate a Group of Induction Motors using PLC Logic?
OpenPLC - PLC Training for Students - Free Tutorials & Courses
PLC program for bread oven
Bread Oven Control in Auto and Manual Modes PLC Program
Differential Capacitance Pressure Sensor Circuit
Comparison Instructions in PLC Programming
PLC Programming for Tank Farm Management
How to Safely Design Automation System for Hazardous Environments?
Rupture Disc
Working of Rupture Disk
Basic AC Generator
AC Generator Parts
Analog Electronics Objective Questions – Set 10
Venturi Flow Meter
Venturi Flow Meter – Working Principle, Advantages, Animation
PLC Motor Control Circuit
Motor Trip Logic using PLC Programming
On Delay Timer using PLC
ON Delay Timer using PLC
