Reading: #9 PLC Best Practices – Validate indirections
Inst Tools > Blog > PLC Tutorials > #9 PLC Best Practices – Validate indirections
PLC best practices - Validate indirections by poisoning array ends to catch fence-post errors.
Last updated: September 21, 2021 4:49 pm
7 Min Read
PLC best practices – Validate indirections by poisoning array ends to catch fence-post errors.
PLC Validate indirectionsInstruction List (IL) Programming1. Create array mask2. Insert poisoned ends3. Record value of indirection address without a mask4. Execute AND mask and compare values (=indirection validation)5. Execute fault/programmer alert
Security ObjectiveTarget Group
The integrity of PLC variablesProduct Supplier Integration / Maintenance Service Provider
An indirection is the use of the value of a register in another register. There are many reasons to use indirections.
Examples for necessary indirections are:
  • Variable frequency drives (VFDs) that trigger different actions for different frequencies using lookup tables.
  • To decide which pump to start running first based on their current run times
PLCs do not typically have an “end of an array” flag so it’s a good idea to create it in software; the goal is to avoid unusual/unplanned PLC operations.
Example
The approach can be turned into a few function blocks and possibly even reused for other applications.
Check if the array is binary-sized. If it is not binary-sized, create a mask to the next size up on a binary scale. e.g., if you have a need for 5 registers (not binary-sized):
[21 31 41 51 61]
define an array of 8:
[x x 21 31 41 51 61 x]
Next, take the index value to pick up for the indirection – in this example, it is 3.
Caveat: Index begins at 0!
[21 31 41 51 61]
       _____ ^
Index: 3
add an offset to it making up for the poisoned end. The offset can be 1 or higher, in this case it is 2:
        ______     ^
Index including offset: 3 + 2 = 5
and then AND the index including offset with a mask that equals the array size.
In this example the array size is 8, thus index 7, so the mask would be 0x07. The mask makes sure the maximum index you can get is 7, for example:
6 AND 0x07 would give back 6.
7 AND 0x07 would give back 7
8 AND 0x07 would give back 0.
9 AND 0x07 would give back 1.
This ensures you always address a value in the array.
Poisoning ends is optional. You would be able to detect manipulated indirections without the poisoning, but poisoning helps to catch fence-post errors because you get back a value that does not make sense.
The point is that at index 0 of the array, there should be a value that is invalid – such as -1 or 65535. This is “the poisoned end”. Likewise, at the last elements of the array you do the same:
So, for the array above, the poisoned version could look like this:
[-1 -1 21 31 41 51 61 -1]
Then record the value of the indirect address without AND mask and offset:
In this example, you’d record 51 for index 3.
[21 31 41 51 61]
     _____    ^
Index 3
Compare your recorded value to the value after you have done the offset and the AND mask.
4a. Case A: Correct Indirection
First, offset:
Index + Offset = 3 + 2 = 5
Second, mask:
5 AND 0x07 = 5
Third, indirection check:
    _______          ^
Index including offset: 5
Value = 51 equals the recorded value, so everything is fine.
4b. Case B: Manipulated Indirection
If you now had a manipulated indirection, let’s say 7, let us see what happens:
First, offset:
Index + Offset = 7 + 2 = 9
Second, mask:
9 AND 0x07 = 1
____^
Index including offset: 1
Value = -1 does not equal the recorded value and also indicates your poisoned end, so you’d know your indirection is manipulated.
If this validated value is different from your recorded one, then you know something is wrong. Raise a software quality alarm.
Then, check the indirection value. If it is a poisoned value, you should raise another software quality alarm. This is an indication of a fence-post error.
Why?
Beneficial for…?Why?
              SecurityMost PLCs do not have any feature to handle out-of-bounds indices for arrays. There are two potentially dangerous scenarios that can stem from indirection mistakes:
First, if an indirection leads to reading from the wrong register, the program executes using the wrong values.
Second, if a wrong indirection leads to writing to the wrong register, the program overwrites code or values you want to keep. In both cases, indirection errors can be hard to spot and can have serious impacts. They can be caused by human error but also be inserted maliciously.
ReliabilityIdentifies non-malicious human errors in programming.
Maintenance/
References
Standard/frameworkMapping
  MITRE ATT&CK for ICSTactic:  TA010 – Impair Process Control
Technique:  T0836 – Modify Parameter
  ISA 62443-3-3SR 3.5: Input Validation
SR 3.6: Deterministic Output
  ISA 62443-4-2CR 3.5: Input Validation
CR 3.6: Deterministic Output
  ISA 62443-4-1SI-2: Secure coding standards
SVV-1: Security requirements testing
MITRE CWECWE-129: Improper Validation of Array Index
Source: PLC Security
Toggle Switch & Sensor: Conveyor and Puncher PLC Program
Drilling Process using PLC Program
What are Faceplates? How to Create a Faceplate? HMI Visualization
Count and Pack Objects from Conveyor using PLC Ladder Logic
PLC Program to Drain Same Products from Two Tanks
Troubleshoot the Status of a PLC Via CPU Indicators
How to implement SR Flip Flop using PLC Ladder Logic
SCADA Communication and Protocols
Electrical Switches Principle & Types
PLC Programmer Salary and Future Career Scope
PLC Digital Inputs
PLC Digital Input and Digital Output Modules
PLC Program for fan control unit system
PLC Programming for Fan Control Unit System for Industry
S7 1200 PLC Program
Automatic Coffee Machine
Automatic Coffee Vending Machine – PLC Logic Programming
Advanced Skills Required for a PLC Programmer to Get a Job
PLC programming for clothes washing machine automation
LS Electric PLC Program Example: Clothes Washing System
If Else Statement in SCL Language
Industrial PLC Communication Network
Basics of Industrial Communication Networks
Feedback Accelerometer System Objective Questions
Allen-Bradley PLC Program
Substation Safety Clearances
Differential Pressure Gauge Principle
Convert-Linear-%-to-Square-root-%
Formula for Linear % to Square root % conversion
Control Valves Chemical attack Problems
Power Flow Through an Inductive Impedance Questions
Air Pressure Regulator cut-away diagram
Air Pressure Regulator Questions
