Reading: #11 PLC Best Practices – Instrument for Plausibility Checks
Inst Tools > Blog > PLC Tutorials > #11 PLC Best Practices – Instrument for Plausibility Checks
Instrument the process in a way that allows for plausibility checks by cross-checking different measurements.
Last updated: September 22, 2021 6:22 am
3 Min Read
Security ObjectiveTarget Group
The integrity of I/O valuesProduct Supplier Integration / Maintenance Service Provider
There are different ways of using physical plausibility for validating measurements:
a) Compare integrated and time-independent measurements
Plausibility checks can be done by integrating or differentiating time-dependent values over a period of time and comparing to time-independent measurements.
b) Compare different measurement sources
Also, measuring the same phenomenon in different ways can be a good plausibility check.
Different measurement sources do not necessarily have to be different physical sensors, but can also mean using alternative communication channels (see examples).
Example
Metered pump and tank level gauge: volumetric change should equal integrated flow.
The burner in a boiler: added caloric heat should equal temperature rise.
Using air-speed, artificial horizon, vertical speed, and altitude in the airplane to measure the phenomenon of the climbing / descending airplane.
Comparing process parameter values from independent data loggers (tied into 4-20mA loops or relay contacts and transmitted via independent communication channels) to SCADA system data (coming in the “normal” way through PLC and HMI) and alerting on deviations and significantly off-specified values.
Why?
Beneficial for…?Why?
  SecurityFacilitates monitoring for manipulated values (assuming not all sensors are manipulated at once).
  ReliabilityPrevents acceptance or identifies (for future action) corrupted / wrong measurements as inputs.
MaintenanceRules out the possible physical causes for failures more quickly.
References
Standard/frameworkMapping
  MITRE ATT&CK for ICSTactic:  TA010 – Impair Process Control
Technique:  T0806 – Brute Force I/O
  ISA 62443-3-3SR 3.5: Input Validation
SR 3.6: Deterministic Output
  ISA 62443-4-2CR 3.5: Input Validation
CR 3.6: Deterministic Output
MITRE CWECWE-754: Improper Check for Unusual or Exceptional Conditions
Source: PLC Security
How to Configure PID in Siemens PLC?
Problem on PLC, HMI, VFD, and Motor Circuit
#10 PLC Best Practices – Assign Register Blocks by Function
Difference Between Normal Counters and Fast Counters – Learn PLC
1 to 8 Demultiplexer PLC ladder diagram
How to Configure PID Controller in Various Schneider PLCs?
How to Create Faceplate in FactoryTalk View Studio?
#4 PLC Best Practices – Use PLC Flags as Integrity Checks
Tank Level Control in PLC
Control Speed of Induction Motor using Analog Output of PLC
Learn PLC in Hindi
Factory I/O PLC Automation Training Course (Free)
Structured Text PLC Programming for Automatic Gate Control
Retentive ON delay timer using PLC Logic
Retentive ON Delay Timer using PLC
RSLogix 5000 PLC Programming Procedure
Flip-Flop PLC Program for Lamps Application
Example of Flip-Flop PLC Program for Lamps Application
Free Allen Bradley PLC Training Course
Free Allen Bradley PLC Ladder Logic Training Course
Siemens PLC Simulator and Plant Simulation Software
ControlLogix
Difference Between CompactLogix and ControlLogix
Three phase induction motor nameplate
How to Size a Cable for Industrial AC Motors?
Double-acting cylinder - 2
Fluid Power Systems
Automated Test Bench - Complex PLC Programming Examples
Automated Test Bench – Complex PLC Programming Examples
Types of Cables
Types of Cables, Purpose, Advantages, Disadvantages, Applications
Flow Switch Working Principle Animation
Working Principle of Flow Switch with Animation
Types of MCB
Types of MCB
Why is White Powder Used in Electrical Cables
Why is White Powder Used in Electrical Cables?
Digital Control Systems
Z & S Domain Relationship
