Reading: Pitot Tube Flowmeter Calculations
Inst Tools > Blog > Practical Questions > Pitot Tube Flowmeter Calculations
Last updated: June 6, 2018 9:51 am
Practical Questions
1 Min Read
A Pitot tube measuring the flow of glycerin (78.6 lb/ft3 ) produces a differential pressure of 35 inches W.C. at a mass flow rate of 450 pounds per minute.
Calculate the differential pressure produced by this same Pitot tube at a flow rate of 310 lb/min.
Calculate the mass flow rate at a differential pressure of 12.6 ”WC.
If the glycerin density happens to change from 78.6 lb/ft3 to 75.1 lb/ft3 , calculate the mass flow rate at a differential pressure of 24.8 ”WC.
Answer :
Differential pressure produced by this same Pitot tube at a flow rate of 310 lb/min = 16.61 ”WC
Mass flow rate at a differential pressure of 12.6 ”WC = 270 lb/min
Mass flow rate at DP of 24.8 ”WC, assuming density of 75.1 lb/ft3 = 370.3 lb/min
More DP Transmitter Questions
Flow Transmitter Readings mismatch with DCS
DP Transmitter Calibration Errors
DP Transmitter Error Calculations
Smart DP Transmitter Flow Meter Calculations
Questions on Pneumatic Transmitter and Repeater
Questions on Resistive Tape Level Sensor
LRV and URV of PT for Extreme Limits of Empty and Full
Calculate Hydraulic Pressure of a Process Vessel
DP Transmitter Problem
Hydrostatic Level Measurement – Temperature related Density Change Effects
Determine Resistance value of Resistors
Troubleshooting PLC Permissive Inputs
Solenoid Valves Practical Problems
Solenoid Valves Questions & Answers – 2
Programmable Logic Controller (PLC) Questions and Answers – 14
Thermocouple Terminal block Questions
Sketch a Ladder Diagram for PLC to Energize the Lamp
What is the Purpose of Chemical Seals Pressure Transmitter?
Practical Level Sensors Questions and Answers
Current-to-Pressure Transducer Calibration Table
Questions on Level Switches
PLC program Permissive Circuit
PLC Electric Motor Interlocks
Dry Leg
Calculate 0%, 50%, and 100% Calibration Points for ΔP transmitter
pressure switch ladder-logic diagram
Draw the appropriate Pressure Switch Symbol ?
Steam Eductor Question
A Series of False Pressure Alarms
Hydraulic Actuated Lift
Oil and Air Pressure Actuated Lifts Questions
DeltaV Tune Tutorial
How to Tune a Loop in DeltaV System
Mechanical Vibration Switch
Vibration Switch Working Principle
Guided-wave Radar Asset Management Parameters
Analog Demodulators Objective Questions
HVAC System
What is HVAC System?
Electronic Meters Questions & Answers
Weinview HMI
Self Actuated Pressure Control Valve Principle
