Reading: Oval Gear Meter – Principle, Advantages, Limitations, Applications
Inst Tools > Blog > Flow Measurement > Oval Gear Meter – Principle, Advantages, Limitations, Applications
Oval Gear Meter measures flow by using a geared rotor to pass known volumes of fluid through a housing. (Positive Displacement Flow Meter)
Last updated: October 31, 2023 12:46 pm
Flow Measurement How It Works
2 Comments
3 Min Read
Oval gear meters are traditional, mechanical, positive displacement (PD) flow meters, first invented more than 50 years ago by OVAL Corporation of Japan and now widely used for flow metering applications.
Oval Gear MeterAdvantages of OVAL Gear MeterLimitations of OVAL Gear MeterApplications of OVAL Gear Meter
Oval gear meters measure flow by employing a geared rotor to pass known volumes of fluid through a housing.
Oval Gear Meter
A very precisely adjusted gear pair within the casing forms the measuring element. The in-flowing medium causes the gear pair to rotate.
The rotary motion is scanned by contactless sensors. Since each individual tooth generates a pulse, this results in a very high resolution.
Consequently, even the smallest volumes can be measured or dosed precisely. The measurement unit contains two pick-offs that are circumferentially offset by ? a tooth pitch to generate a 2-channel flow-proportional frequency signal.
Suitable processing of the signal provides a greater resolution and the option to identify the flow direction. Basically, the measurement accuracy increases with an increase in the viscosity of the media.
Oval gear Flow Meter Principle
The oval gear flow meter comprises oval-shaped, geared rotors that rotate within a housing of specified geometry. Fluid differential pressure causes the intermeshing gears to rotate, trapping a ‘pocket’ of fluid between the gear and the outer housing and subsequently emptying the fluid pocket into the downstream flow.
The capillary action of the metered fluid forms a liquid seal. Each ‘pocket’ holds a precise and known volume of fluid so counting the pocket frequency gives a measurement of the volumetric flow rate. This is typically achieved by embedding magnets in the rotors, which then actuate a reed switch or provide a pulse output as they rotate.
Oval Flow Sensor principle
  • Traditional proven flow technology
  • Simple to install
  • No straight pipe runs are required so flow meters can be installed in restricted areas
  • Not suitable for steam or multi-phase fluids
  • Fluid slippage adversely affects accuracy; this varies with flow rate, differential pressure, temperature, viscosity, and clearance
  • Not recommended for low-viscosity fluids, including water or water-like fluids (because of an increase in fluid slippage)
  • Accuracy is adversely affected by bubbles present in fluids
The oval gear flow meter is designed primarily for use with higher-viscosity fluids, which has led to applications such as the flow metering of oils, syrups, and fuels.
  • Flowmeter Control Strategy
  • What is Averaging Pitot Tube?
  • Basics of Venturi Flow Meter
  • Differential Pressure Flowmeter
  • Flow Transmitter Square-Root
Piston Flow Meters Working Principle with Animation
Flow Meter K-factor and Calculations
Interview Questions on Flow Measurement
Hot Wire Anemometer Principle and Types
What is Differential Pressure Flow Meter?
Metal Tube Variable Area Flow Meters Principle
2 Comments
  • Yogi says:
    December 3, 2017 at 8:53 am
    In oval gear type flow meter,relation between frequency and flow
  • David C Wishon says:
    June 7, 2019 at 5:35 pm
    Is the flow affected by the down stream pressure?
What is a Magnetic Flow Meter?
Flow Switch : What is it? – Applications
Types of Flow Meters MCQ – Instrumentation and Control
What is an Orifice Meter?
Area Velocity Flow Meter Principle
Microwave Flow Sensor – Working Principle and Applications
Configure the Instruments in Flow Control Loop
Pressure Transmitter
Pressure Transmitter Animation
Location of Pressure Taps
Design Considerations of Orifice Plate
Air Filter Regulator Working Principle Animation
Heat Tracing Problems
mass flowmeters
What is a Thermal Flow Meter?
What is an Averaging Pitot Tube? – Principle, Advantages
Weigh feeders Principle
What is a Weigh Feeder?
Flow Transmitters Questions and Answers
Flow Transmitters Questions and Answers – Instruments Test
Open Diode in a Full-Wave Rectifier
Power Supply Circuit Fault Analysis
Establish Communication Between Two PLC Via PROFIBUS Protocol
Example of feedback principle
Example of Feedback System
Factors Affecting Inductance
Types of Potentiometers
Types of Potentiometers – What is a Potentiometer? – Applications
Basics of Sinking and Sourcing
Siemens Communication between PLCs using I-Device
Tutorial: Siemens Communication between PLCs using I-Device
Comparison of Flowmeters
Difference between Different Types of Flow Meters
