Reading: What are the Orifice Plate Flow Requirements?
Inst Tools > Blog > Flow Measurement > What are the Orifice Plate Flow Requirements?
Orifice Plate Flow Requirements are to use straight run pipe length or a flow conditioner to reduce the straight run requirement.
Last updated: November 2, 2023 12:31 pm
Flow Measurement
2 Min Read
The orifice flow meter is a well-established flow measurement method. The sizing, dimension, and installation requirements are dictated by ISO 5167-1 & ISO 5167-2.
Basically, the orifice sizing involves a coefficient that was determined from the empirical test. This coefficient is the coefficient of discharge.
During the test, the fluid flow is required to be a fully developed flow condition which means a fluid flow that is not a swirl-flow.
Orifice Plate
This requirement is proved to be effective enough to produce the lowest uncertainty of coefficient of discharge which can lead to an accurate flow measurement reading.
If the fluid flow isn’t fully developed, it is proved also that the uncertainty of the coefficient of discharge is high which can lead to an inaccurate flow measurement reading.
The swirl flow itself can be caused by an elbow, control valve, or any other equipment in the upstream and downstream of the orifice plate.
There are two methods to establish the swirl-free conditions, by putting a certain straight run pipe length and by using an additional flow straightener or flow conditioner to reduce the straight run requirement.
ISO 5167-2 has already specified the requirement of this straight run with or without a flow conditioner. The straight run on that standard was determined experimentally and give a practical number that shall be followed to get the required flow meter uncertainty.
  • Integral Flow Orifice Assembly
  • What is an Orifice Flange?
  • Types of Orifice Tappings
  • What are the different Orifice Plates?
  • Turndown ratio of Orifice Plates
Types of Flow Meters MCQ – Instrumentation and Control
V Cone Flow Meter – Principle, Advantages, Disadvantages
Types of Variable Area Flow Meters
Swirl Flow Meters Working Principle
Heat Tracing Problems
Coriolis Flow Meter Construction
Laminar Flow Meter Working Principle
Ultrasonic Flow Meters Animation
Oscillating Piston Flow Meters Working Principle
Orifice Plate Tapping – Orifice Plate Taps
Why Flow is Directly Proportional to the Square Root of DP?
What is a Vortex Flow Meter?
Coriolis Mass Flow meter as a Multi Variable Transmitter - 2
Coriolis Flowmeter Advantages and Limitations
Turbine Flow Meter Installation Procedure
Impulse line - Purpose & Tapping Point Location
Impulse Line – Purpose & Tapping Point Location
Magnetic Flow Meter Corrosion Effects
Flow Switch Symbol
Principle of Flow Switch
Magnetic Flow Meters
Beta ratio ( β )
Important Factors in Flow Measurement
Pressure and Temperature Compensation for Flow Transmitter
Free Download Industrial Control System Book
Cable Shield
High-frequency Signal Cables
What Do You Learn in Software Engineering
What Do You Learn in Software Engineering?
Data Instance in PLC
Tia Portal – Different Instances of Calling a Function Block
Surge Protection for the Fieldbus System
Traffic Barrier Control
PLC Programming for Traffic Barrier Control
Arduino Zero
What is Arduino? Different Models of Arduino Controllers
Electric Motors Noises
Electric Motors Noises – Types, Possible Sources, Reasons
