Reading: Orifice Plate Questions and Answers
Inst Tools > Blog > Flow Measurement > Orifice Plate Questions and Answers
Learn the essential questions and answers on orifice plates for flow measurement in industrial instrumentation.
Last updated: July 25, 2024 3:22 am
Flow Measurement Instrumentation MCQ
6 Min Read
Orifice PlateWhat is the primary purpose of an orifice plate in a fluid system?Which principle is used to calculate flow rate using an orifice plate?What type of orifice plate is commonly used for measuring clean liquids, gases, and steam?How does an orifice plate affect the velocity of the fluid passing through it?Which flow regime is ideal for accurate flow measurement using an orifice plate?What is a major disadvantage of using an orifice plate for flow measurement?Which part of the orifice plate is used to measure differential pressure?Why is a concentric orifice plate not suitable for measuring slurry or dirty fluids?What is the main purpose of the vena contracta in an orifice plate setup?How does fluid density affect the flow rate measurement using an orifice plate?What type of orifice plate is designed to handle fluids with high particulate content?What is the role of beta ratio (β) in orifice plate calculations?How can the accuracy of an orifice plate measurement be verified?What material is commonly used for manufacturing orifice plates?Why is it important to ensure proper installation of orifice plates in a piping system?What is a key advantage of using orifice plates over other flow measurement devices?What is the impact of flow profile on orifice plate accuracy?How does temperature affect orifice plate measurements?What is the function of flow straighteners in orifice plate installations?In what applications are segmental orifice plates typically used?
Orifice Plate
This orifice plate video provides clear-cut explanations for each question. We recommend you watch the below video to access the complete learning materials.
Question 1
A. Measure fluid density
B. Regulate temperature
C. Measure flow rate
D. Filter impurities
Show the Answer
Measure flow rate
Question 2
A. Archimedes’ principle
B. Pascal’s law
C. Bernoulli’s principle
D. Boyle’s law
Show the Answer
Question 3
A. Eccentric orifice plate
B. Concentric orifice plate
C. Quadrant edge orifice plate
D. Segmental orifice plate
Show the Answer
Question 4
A. Keeps velocity constant
B. Increases velocity
C. Reverses velocity direction
D. Decreases velocity
Show the Answer
Increases velocity
Question 5
A. Transient flow
B. Laminar flow
C. Oscillatory flow
D. Turbulent flow
Show the Answer
Turbulent flow
Question 6
A. High cost
B. Pressure loss
C. Complex installation
D. High maintenance
Show the Answer
Pressure loss
Question 7
A. Downstream side only
B. Both upstream and downstream sides
C. Side of the plate
D. Upstream side only
Show the Answer
Question 8
A. Too expensive
B. Prone to clogging
C. Requires frequent calibration
D. Too complex
Show the Answer
Prone to clogging
Question 9
A. Maximize flow area
B. Minimize turbulence
C. Increase fluid pressure
D. Create maximum velocity
Show the Answer
Question 10
A. Affects the pressure drop
B. Decreases flow rate
C. No effect
D. Increases flow rate
Show the Answer
Question 11
A. Orifice flange
C. Segmental orifice plate
D. Eccentric orifice plate
Show the Answer
Question 12
A. Ratio of orifice diameter to pipe diameter
B. Indicates pipe diameter
C. Measures fluid density
D. Determines fluid viscosity
Show the Answer
Question 13
A. Checking fluid color
B. Estimating visually
C. Using a flow calibration rig
D. Comparing to a standard table
Show the Answer
Question 14
A. Aluminum
B. Copper
C. Plastic
D. Stainless steel
Show the Answer
Stainless steel
Question 15
A. To reduce cost
B. To increase flow rate
C. To ensure accurate flow measurement
D. To prevent noise
Show the Answer
Question 16
A. Low initial cost
B. No maintenance required
C. Instant readings
D. High accuracy
Show the Answer
Low initial cost
Question 17
A. Enhances accuracy
B. Distorted profiles can cause errors
C. Reduces noise
D. No impact
Show the Answer
Question 18
A. Changes orifice size
B. No effect
C. Alters fluid viscosity and density
D. Reduces flow rate
Show the Answer
Question 19
A. Decrease flow rate
B. Ensure a uniform flow profile
C. Create turbulence
D. Increase pressure drop
Show the Answer
Question 20
A. Clean gas measurement
B. High-temperature fluids
C. Fluids with suspended solids
D. Low-pressure systems
Show the Answer
  • How does an Orifice Measure Flow?
  • Field Instrumentation Interview Questions
  • Why was RTD installed after the Orifice Plate?
  • Orifice Pressure Temperature Compensation
  • Orifice Sizing Guidelines and Thumb Rules
Electronics and Instrumentation Students Quiz
Control Valves Multiple Choice Questions
Gyroscope Objective Questions
Oval Gear Flow Meters – Principle, Advantages, Animation
Encoders and Decoders Objective Questions
Top 10 Industrial safety Objective Questions
All About Turbine Meters
Pneumatic Systems Objective Questions
Inverse Transducers Objective Questions
Troubleshooting Magnetic Flow Meters Common Problems
What is a Positive Displacement Flow Meter?
Square-root characteristics of Differential Pressure Flow Meters
Fiber Optic Sources and Detectors Questions and Answers
Photo Electric Transducers Objective Questions
Tomography Objective Questions
Flow Switch Working
Flow Switch : What is it? – Applications
Stepper Motor Parts
Stepper Motor MCQ
Feedback Accelerometer System Objective Questions
Multiple Choice Questions on Sensors & Transducers
Measurement of Resistance Objective Questions
Instrumentation Engineering Documents
Instrumentation Engineering Documents Questions Answers
STL Programming - SET, RESET, ASSIGN
STL Programming – SET, RESET, ASSIGN
PLC Program Upload
How to Upload Siemens PLC Programs?
Homebrew CNC Machine
Embarking on a Homebrew CNC Project: A Journey of Creativity
Magnitude Comparator Objective Questions
Aluminum Cable Terminations
Aluminum Cable Terminations Repeat Failures
Weir Flow Meter Principle
Measure Flow rate using Level Sensors
Ultrasonic Sludge Blanket Level Meter Animation
What is Chemical Vapor Deposition
What is Chemical Vapor Deposition? – The Ultimate Guide
