Reading: What is the Purpose of Orifice Plate Drain Hole and Vent Hole?
Inst Tools > Blog > Flow Measurement > What is the Purpose of Orifice Plate Drain Hole and Vent Hole?
Orifice Drain hole is required in gas flow service where liquid entrapment may occur. Orifice Vent hole is required in liquid flow service where gas entrapment may occur.
Last updated: November 2, 2023 5:50 am
Flow Measurement
3 Comments
2 Min Read
In this article, you will learn the purpose of the orifice plate drain hole and the vent hole.
What is the Purpose of Orifice Plate Drain Hole?What is the Purpose of Orifice Plate Vent Hole?
A drain hole is a small hole that is provided in the lower region of the orifice plate.
A drain hole is required in gas flow service where liquid entrapment may occur.
Drain hole size could affect the accuracy of flow measurement.
However, if the diameter of the drain hole is less than 10% of the orifice bore, then the unmeasured flow is less than 1% of the total flow.
A drain hole is not recommended in dirty fluid service or slurries as the hole could be plugged.
In this application, the use of an eccentric orifice plate becomes an alternative.
The vent hole is a small hole that is provided in the upper region of the orifice plate.
The vent hole is required in liquid flow service where gas entrainment may occur.
Vent hole size could affect the accuracy of flow measurement.
However, if the diameter of the vent hole is less than 10% of the orifice bore, then the unmeasured flow is less than 1% of the total flow.
The vent hole is not recommended in dirty fluid service or slurries as the hole could be plugged.
orifice plate vent hole
  • Classification of Orifice plates
  • Types of Flow Instruments
  • RTD installed after Orifice
  • Wedge Flow Meter
  • Basics of Flow Measurement
Variable Area Flow Meters – Principle, Advantages, Disadvantages
Oval Gear Meter – Principle, Advantages, Limitations, Applications
What is Integral Flow Orifice Assembly?
DP Flow Transmitter Re-Ranging Calculation
Coriolis Meter Explained with Animation
3 Comments
  • D.N.Sharma says:
    May 14, 2018 at 11:21 pm
    Your statement regarding decrease in accuracy due to drain and vent hole is not correct.There is no change in accuracy as it is taken care during orrifice design
  • Naran Parmar says:
    June 9, 2020 at 9:57 am
    We have orifice , DP range : 0-2500 MMWC and flow range 0-250 M3/Hr. Can we used it for measurement of 0-10 M3/Hr. is it impact on accuracy of measurement ?
    • Shaleen Dave says:
      September 25, 2021 at 6:57 pm
      You cannot unless you want to sacrifice accuracy.
      A basic orifice gives a turndown ratio of 1:3 i.e for your case you can measure 83 m3/hr with an accuracy below ±0.5 %.
      However, in order to measure 10 m3/hr, you need to install a 2nd and 3rd DP transmitters in parallel on same orifice by Tee joint to measure flow ranges of 28 to 84 m3/hr (Tx2) and 10 to 30 m3/hr to maintain flow accuracy of ±0.5% throughout measuring range
Laminar Flow Meter Working Principle
Orifice Plate Turndown ratio
Metal Tube Variable Area Flow Meters Principle
Mass Flow Calculations
Types of Variable Area Flow Meters
Differential Pressure (DP) Flow Meters Range Calculation Methods
All About Vortex Flow Meters
Flow Meter K-factor and Calculations
types of Orifice Plates
Types of Orifice Plates & Orifice Plate Tappings
Reasons to Calibrate Flowmeters
Reasons to Calibrate Different Types of Flow Meters
Flow Measurement
Continuous Flow Measurement
Heat Tracing Problems
Difference between Fixed Area and Variable Area FlowMeters
Difference between Fixed Area & Variable Area FlowMeters
Magnetic Flow Meters
Electro Magnetic Flow Meter Animation
What is Averaging Pitot Tube
What is an Averaging Pitot Tube? – Principle, Advantages
Microprocessors Objective Questions – Set 4
Flip Flops Objective Questions – Part 2
Brushed DC Motor Working Animation
DHCP
Difference Between BOOTP and DHCP
Library of PlantPAx Process Objects
Corona Discharge
Corona Discharge in Power Transmission Lines
Analog Electronics Objective Questions – Set 7
Manual Call Point Testing Procedure
