Reading: On/off Control Theory
Inst Tools > Blog > Control Systems > On/off Control Theory
Last updated: November 10, 2019 2:23 pm
Control Systems
Once while working as an instrument technician in an aluminum foundry, a mechanic asked me what it was that I did.
I began to explain my job, which was essentially to calibrate, maintain, troubleshoot, document, and modify (as needed) all automatic control systems in the facility.
The mechanic seemed puzzled as I explained the task of “tuning” loop controllers, especially those controllers used to maintain the temperature of large, gas-fired industrial furnaces holding many tons of molten metal. “Why does a controller have to be ‘tuned’?” he asked.
“All a controller does is turn the burner on when the metal’s too cold, and turn it off when it becomes too hot!”
In its most basic form, the mechanic’s/engineers’s assessment of the control system was correct: to turn the burner on when the process variable (molten metal temperature) drops below setpoint, and turn it off when it rises above setpoint.
However, the actual algorithm is much more complex than that, finely adjusting the burner intensity according to the amount of error between PV and SP, the amount of time the error has accumulated, and the rate-of-change of the error over time.
In his casual observation of the furnace controllers, though, he had noticed nothing more than the full-on/full-off action of the controller.
The technical term for a control algorithm that merely checks for the process variable exceeding or falling below setpoint is on/off control. In colloquial terms, it is known as bang-bang control, since the manipulated variable output of the controller rapidly switches between fully “on” and fully “off” with no intermediate state.
Control systems this crude usually provide very imprecise control of the process variable. Consider our example of the shell-and-tube heat exchanger, if we were to implement simple on/off control :
Note : To be precise, this form of on/off control is known as differential gap because there are two setpoints with a gap in between. While on/off control is possible with a single setpoint (FCE on when below setpoint and off when above), it is usually not practical due to the frequent cycling of the final control element.
ON OFF Control Principle
As you can see, the degree of control is rather poor. The process variable “cycles” between the upper and lower setpoints (USP and LSP) without ever stabilizing at the setpoint, because that would require the steam valve to be position somewhere between fully closed and fully open.
This simple control algorithm may be adequate for temperature control in a house, but not for a sensitive chemical process! Can you imagine what it would be like if an automobile’s cruise control system relied on this algorithm?
Not only is the lack of precision a problem, but the frequent cycling of the final control element may contribute to premature failure due to mechanical wear.
In the heat exchanger scenario, thermal cycling (hot-cold-hot-cold) will cause metal fatigue in the tubes, resulting in a shortened service life.
Furthermore, every excursion of the process variable above setpoint is wasted energy, because the process fluid is being heated to a greater temperature than what is necessary.
Clearly, the only practical answer to this dilemma is a control algorithm able to proportion the final control element rather than just operate it at zero or full effect (the control valve fully closed or fully open). This, in its simplest form, is called proportional control.
Types of System Architecture used in Industrial Automation
Difference between DCS, PLC, and RTU ?
Alarm Simulator for Annunciator Logic
Troubleshooting Current Loops with Voltage Measurement
Loop Controller HART Signal Noise
Setpoints and Alarms in Control System
PID Controllers with Output High Select Logic
Difference between SR Flipflop and RS Flipflop ?
Heat Exchanger Temperature Control
Types of Noise in Electronics
Problem on Pressure and Level Control Loops
What is Open Systems Interconnection?
Industrial Automation Solution
How to Choose the Right Industrial Automation Solution?
Building Management System
Understanding-a-Process-Control-Loop
Understanding a Process Control Loop
Advanced Process Control
What is Advanced Process Control (APC)?
What is FAT and SAT?
Types of Industrial Control Systems
What is a Floating License - Automation Software Systems
What is a Floating License? – Automation Software Systems
What is Ground
What is Ground, and importance of a Grounding System?
single-acting-vs-double-acting-control-valve-actuators
Single Acting Vs Double Acting Actuators
Level-Transmitters-Animation
Level Transmitter Animation
Reasons to Calibrate Flowmeters
Reasons to Calibrate Different Types of Flow Meters
Welding Machine Fail in Dusty and Corrosive Areas
How to Activate the Schneider PLC Software License
How to Download EcoStruxure Machine Expert? Schneider PLC Software
Modbus Poll and Modbus Slave
How to Use Modbus Poll and Modbus Slave Software?
Globe Valve Disk and Stem Connections
Globe Valve Seat and Disk
Inclined-limb Manometer Formula - 2
Inclined-limb Manometer Principle
